Question about Frigidaire GLER642A Electric Dryer
Model # NGSG74DASO Frigidaire gas dryer (P/N 131883500 (9907))
Dryer runs with cold air only. Trouble shooter says it's a fuse, PDF's don't show any fuses...only thermostat...what part should I be concentrating on?
  • rufusfrja Mar 08, 2008
    Having the same problem only with a GE
What fuses? circuit breakers? they all seems ok
Posted on Mar 08, 2008
Why wont my dryer stay running?
Good Morning Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not stay running. Please check to make sure the door is staying closed. If the door is opening in mid-cycle, then the dryer will stop running. Also, make sure the plug is in the socket tightly. Your dryer could be shaking the plug loose, which could possibly be causing it to stop running. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FEQ1442ES Electric Dryer
Fridarire affinity FAQE7001LW dryers runs no heat
I understand that your Frigidaire Affinity dryer, model# FAQE7001LW, is running but there is no heat. Before calling a technician, check the following solutions:
    1)Make sure that the two house fuses your dryer is attached to. If one of the two fuses is blown, the drum may turn but you won't receive any heat.
    2)For Gas Models Only: Make sure the gas supply valve is open, make sure there is enough air supply to support the burner flame, and make sure the LP gas supply tank is not empty or there has been a utility interruption of the natural gas.
    3)Check the lint filter, the ducting that leads outside, as well as the outside vent for any lint that might be clogged inside. This can cause a no heat issue, due to your dyer is not getting a good air flow.
    4)For Electric Dryers Only: Make sure your dryer is connected to a 208 volt circuit.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
May 29, 2014 | Frigidaire FAQE7001LW Dryer
My frigidaire gas dryer will not heat
Good Morning Margie,
I see that you are having trouble with your Frigidaire gas dryer heating. I also see that the vent is plugged. You definitely do not want that vent plugged. Your dryer needs proper ventilation in order for it to work correctly. The reason it might not be heating is due to the fact that that vent is plugged and is not getting enough ventilation. Unplug that vent, make sure that there is gas going to the appliance, and that the gas supply valve is open.
-Best Regards-
WP
Apr 01, 2014 | Frigidaire AGQ6000ES Gas Dryer
1997 Frigidaire gas dryer
check the blower cage they crack then the air dosent move it gets hot and shuts off for safety and when i say gets hot only at the cage very little at dryer drum
Aug 28, 2012 | Frigidaire Dryers
Frigidaire aeq7000eg0 motor doesn't run
Most of your fuses for a Frigidaire dryer are upper right hand side of the rear bulkhead. Here is a westinghouse dryer video I made In the video I look for failed components and show the various parts, explain their function, and location.
Frigidaire service manual
https://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101
Jul 23, 2012 | Frigidaire Dryers
Gas dryer not heating
Check the following to address this issue.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Jun 22, 2009 | Frigidaire Dryers
No heat - long time to dry clothes.
Hi, Is this an electric dryer? The model# shows that is it. If it is gas, you need to change the coils on the top of the gas valve. This is a very common problem with the newer gas dryers. We have them for $27.95. Our # is 1 866 798-4375 Make sure and check the venting to the ouside and make sre that it is clean and has no kinks.
If I can assist you further, please let me know.
Thanks
Vic
May 15, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Cold dryer?
I would bet on a bad ignitor. An appliance parts store should help you thru the install. Should be about $20.00 for the part.
Apr 22, 2009 | Frigidaire GLGR341AS Gas Dryer
1317150009709 frigidaire dryer0how do i get at the pilot light or
There are 2 house fuses in the dryer circuit. If
1 of the 2 fuses is blown, the drum may turn
but the heater will not operate.
Gas supply valve is not open (gas models).
Dryer does not have anough air supply to
support the burner flame (gas models).
LP gas supply tank is empty or there has been
a utility interruption of natural gas (gas
models).Replace fuse.
Check to make sure supply valve is open. See INSTALLATION
INSTRUCTIONS for procedure.
See INSTALLATION INSTRUCTIONS.
Refill or replace tank.
Dryer should heat when utility service is restored
Feb 16, 2009 | Frigidaire FGQ332ES Gas Dryer
Frigidaire Dryer WOn't Heat
I have a frigidaire frontal dyer that is 3 yrs old. The dryer works properly, it tumbles, but it is only cold air ???? What's the problem ?
Mar 15, 2008 | Frigidaire GLER642A Electric Dryer
Frigidaire GLER642A Electric Dryer Logo
238 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
