Kenmore 63682 / 63684 / 63689 Microwave Oven Logo
Posted on Mar 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lg micro appears to be working, but will not heat
Anonymous
Level 3:
  • Master 10,865 Answers
  • Posted on Mar 11, 2010
Anonymous
Master
Level 3:
Answers
10865
Questions
0
Helped
3799893
Points
33142
Hello. When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician. Just get a firm estimate before you commit to a repair because it is often better in this market place to replace as opposed to repair. it is cheaper and the new microwave is better all the way around. plus the new one is under warranty.
Joe
I have a lg microwave model lmhm2017sw. It quit heating. The lights come on everything appears to be working but no heat.
Check the supply of HT transformer if ok then check HT diode by replacement still not ok then replace magnatron.
I have LG MS3447GR Micro Wave Oven. It is functioning as before without heating. Please help?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ,.,./ll
l
4helpful
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
My LG MICROWAVE OVEN IS MODEL MC-7836M CONVECTION MICRO GRILL IT IS RUNNING BUT NOT HEATING and GRILL ALSO NOT WORKING
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Micro oven not heat blowing
Basic Microwave Oven TroubleshootingTips
heatman101';';';l;
heatman101
Unit turns on, turntable turns, but nothing heats
Classic symptoms for failed door interlock safety switches, though it could be other trouble.
Remove the cover and check the operation of the little micro switches that operate when you close the door.
DONT TOUCH THE SILVER CAN - LETHAL.
If you regularly open the door while cooking, the contacts in these little switches become burned. When burned badly enough, they cannot make contact. When they cannot make contact, the mocrowave doesnt know the door is closed and will not turn on the magnatron resulting in no heat.
If you need more help, let me know.
a
3helpful
Micro turns on but doesnot heat also turn on by self
Hello bbmasonjim,
If your micro turns on ( meaning everything seems to be working from the control panel) and you aren't getting microwave energy to heat food..you may have any number of damaged or defective components : Magnetron Tube, Filament Power Supply or HV Capacitor.. None of which are something the untrained person should mess with. Even unplugged, there is High Voltage potential inside the electronics compartment. If it is less than a year old, it may still be under warranty.. otherwise.. the cost to repair would probably be higher than the cost to replace..
Regards,
Rick
The toaster on LG LMF-9030TW combined with micro-wave is not heating. The fuse is ok and wiring also. Cannot bring it to repair shop cause I will be out of micro-wave for 2-3 weeks, until fixed. Probably...
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Top Kenmore Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
