Question about Tomtom One Europe v2 GPS Receiver
Tomtom fault My tomtom will not power up! The battery went dead and now even aftter charging it will not power up
  • ENTA Mar 19, 2008
    My Tom TOM One Europe turns on but only displays Flashing letter X
  • dimon7 Jan 09, 2009
    When I connect charger and it not working but the green lights is on screen is black and, nothing still not working.
Having upgraded my Tom Tom ONE Europe with the latest application download and the latest Europe Maps, the device will not now switch on using battery power. The battery is fine, but the device will only switch on when power is present at the USB port. As I performed the two upgrades one after the other I do not know which introduced the change (poor practice by me I'm afraid!) No solution as yet.
Posted on Mar 18, 2008
My TomTom GO shows another page while speaks the right direction. It keeps flicking through some police station or city page and type 0000000 whithout anyone touching it... I have reseted but is still doing it... Help me!!
Posted on Jun 14, 2011
I have the same problem. I uploaded nearly the full capacity of maps to it on a new 1Gb card, and have not changed the application software, so assume the maps are the problem. Will be deleting some to see if that works...
Posted on Mar 19, 2008
Why does my tom tom keep going the shut down page every 10 seconds I have pressed reset but makes no difference I ride bmw r1200rt
One possible cause is that your battery is low or the battery can no longer hold a (good) charge. In this case, the TomTom is shutting down because there's not enough battery to keep it running, even though it is plugged into a power source.
To determine if the battery is the cause, try to charge the TomTom battery .... using a (USB) connection to your computer, or a direct power source (i.e. while the TomTom is not being used). Let it charge for a few hours until the batter charge indicator shows that it is fully charged (or just leave it charging overnight).
Then, unplug the TomTom from the "charger" and power it up. If the TomTom (battery) doesn't hold a (good) charge, the device will shut down within a few minutes, e.g. 10 mins or much less.
When you (then) plug the device into a power source, and it doesn't stay on (i.e. it keeps shutting down after 10 seconds), you can safely conclude that the battery is the cause of your problem.
Apr 24, 2016 | Tomtom GPS
I have a tomtom xl 330. the device will not start up. I tried to update the application. it still does not work. Please help.
A likely cause is that the battery is "dead" ... i.e. no longer holds a charge. The GPS runs on battery power, even if it is plugged in. It will work even if the battery holds a (small) charge. But if the battery doesn't a charge anymore, the device will not start up, even when it is plugged into a power source.
If this is the case, you'll want to change the battery.
Sep 04, 2013 | Tomtom XL 330 Car GPS Receiver
My Tomtom 300 Go won't charge?
It appears that the battery will not hold a (good) charge anymore. If it is still under warranty, contact TomTom to address that problem. They may replace the unit for you.
It is not unusual for (rechargeable) batteries to loose it's capability to hold a good charge if it is plugged in (to a power source) all the time, even while it is not in use.
May 06, 2012 | Tomtom GO 300 GPS Receiver
My TomTom One V3 won't switch on. The green light shows it as charging but it won't power up. Tried reset as discussed with TomTom
If reset not worked, then must open up, take out battery and then reset, then you must hook up USB and upgrade software, also maybe need to get new battery too, often battery seems OK, but not,.
Apr 10, 2010 | Tomtom ONE 3rd Edition GPS
Tomtom wont come on, tryed the reset still wont work, it has been chargeing for three hours
You battery is dead. Even though it is saying charging, your battery is not accepting the charge.
Nov 26, 2009 | Tomtom ONE GPS Receiver
I have not used my tomtom for a few months , an when attempting to use it today , it was dead . nothing at all help tomtom xl roseden@telus.net
connect it to a power supply and leave it for a few hours A battery that is totally depleted will take some time to recover and not show that it is even being charged as power is too low to light the LED.
It will require a full charge of about 10 hours to get it fully back into service. But the LED will ( or should turn on) after about 1-2 hrs depending on the condition of the battery. If after the charge the battery does not hold a charge lasting on average about 2 hrs , then change the battery.
Please rate our help++++Thanks for using FIXYA
Sep 25, 2009 | Tomtom One XL GPS Receiver
TOMTOM kept on losing signal... now lost for ever..!!!!!!! my tomtom lost the signal for ever... after two years.... also the battery is dead......... cannot charge at all.............. what is tomtom...
TOMTOM is doing nothing! If the battery is dead change it, that was and is the problem low battery no sync no battery no work and defimnitely wont charge means it has to be replaced
Jul 20, 2009 | Tomtom One XL GPS Receiver
Lack of Battery
First make sure it is your battery. Check to see if when you are charging your device and wiggle the USB cable a little if the green charge light starts blinking. If it starts blinking on and off you have a loose USB connector. This is an easy fix if you have some soldering skills. Your device should not turn off when it is hooked up to power even if you have a dead battery.
Jan 29, 2009 | Tomtom ONE GPS Receiver
Tomtom
If the battery is dead it will not turn on. Even for a second. Make sure you have it plugged in. If its dead you may want to let it charge a minutes or two. If that doesnt work you will need contact TomTOM.
Apr 15, 2008 | Tomtom ONE GPS Receiver
Re battery life??
the battery should last 3/4 hours without a charger.
I think tomtom are aware of a ton of units with faulty batteries / poor life span.
arrange for it to be returned asap.
http://www.tomtom.com/support/support.php?ID=2
Dec 04, 2007 | Tomtom One Europe v2 GPS Receiver
Tomtom One Europe v2 GPS Receiver Logo
1,640 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
