Please help me :(
As stated in the subject, I have a Lexmark 2300 and I cannot get it to print. It will print and copy when I manually push the copy button on the printer itself. However, it will not print when I try printing from a program such as word or anything else. It won't even print a test page. I downloaded drivers, checked my ports, checked my admin settings, print spooler settings, and checked my cables for bad areas or being loose. I can't think of anything else. Oh, and to make things better, Microsoft for some reason thought it was a good idea to get rid of the ability to view help files without downloading yet another driver. Good 'ole Vista.... anyway I downloaded that as well. Please help before I use the printer for other recreational uses.... like a punching bag or sighting a gun in.
  • Anonymous May 06, 2008
    cannot get my hp psc 2355 all in one to work with vista
  • 4 Answers
Hello, you should uninstall the old 'printer' and old drivers, turn off your popup blocker, and reinstall the printer with the new Vista drivers for seres X2310, X2330, X2350.>>> Driver Download <<<
Click the link for a page with several driver options for Vista.
Print this page to a PDF file and save to your desktop for reference until you can print paper documents.
If you do not have a PDF print program, http://www.bullzip.com/ has a FREE (TOTALLY) WARE program for VISTA. I have installed, tested and yes, it works.
You may need to access the Run Command to initiate printing.
How to Access the Run Command in Microsoft Windows Vista Background
The Run command, which was available in the Start menu of Windows 2000 and Windows XP, is not visible in Windows Vista.
Accessing the Run command in Windows Vista
Most keyboards have a Windows key, usually located between the Ctrl and Alt keys. If you hold down the Windows key and press 'R', a Run prompt will appear.
This may be useful if you need to start msconfig in order to limit start items, or msinfo32 to gather system information files (files with a .nfo extension).
Msconfig has added a Tools section. Several common tasks can be managed from here, including Regedit, Event Viewer, System Information, Command Prompt, and Task Manager. To open one of these tasks, highlight the task and click Launch.
Posted on Mar 09, 2008
I have a lexmark x2350 (all-in-one,2300 Series).In the troubleshoot ,said printer status ready.But when i try print,or take a print page text,i hear:printing started,printing complete,but the machine don`t...
Try to update your printer driver. Please visit the Lexmark website at http://bit.ly/qQJd8g. Select your operating system to download the file.
If that doesn't help, follow the steps below: 1. Disconnect the printer from your computer. 2. On your computer, go to Control Panel > Printers and Faxes. Delete the Lexmark X2350 print object. 3. Reboot your pc. 4. Once the pc completely boots up, reconnect the printer into the pc. Wait until your pc fully recognizes the USB connection. 5. To ensure the print object has been successfully created automatically. Go to Control Panel > Printers and Faxes. You should see a new Lexmark X2350 print object in the list. 6. Try to print again.
Jul 28, 2011 | Lexmark X2350 All-In-One InkJet Printer
Just installed a new Lexmark 2300 series ink cartridge, printer
Hello Jeanete. First off, lets make sure that you have the right cartridge model number for your Lexmark Z-2300. Your printer cartridge number should be (Number 31 for black and white). 2nd, make sure that the clear plastic tab has been removed from where the ink comes out of your cartridge to strike the paper. 3nd, make sure that you have it installed properly. This shouldn't be needed, but once you have did everything reboot PC to see if this helps...
May 17, 2009 | Computers & Internet
No power on my Lexmark X8350
That's the same printer I have.
First, make sure the blue "copy" button is lit. Printing is done there.
Then, go to the circle with the checkmark in it and hit the menu, and arrow down to copy papy size and make sure it says "letter".
Click start on your computer, then click control panel, then printers, and make sure Lexmark 8300 series is the default printer and has a green checkmark in a circle.
If all these things are right, you should be able to print a test page and the computer should work fine.
If any one of them are wrong they must be corrected. If you need help on any one of those please write back.
Sirwriter
May 14, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
HP Laserjet 2300: Prints only one copy
can you print the configuration page or selftest?
Jul 11, 2008 | HP LaserJet 2300 Printer
Lexmark 2300 all in one not scanning
I had this same problem.
For some reason when the printer installs, the scanner is disabled.
You will need to be on a user with administrative rights to complete this fix.
Also be sure you have downloaded and istalled the latest drivers from Lexmarks site.
  • Right click my computer.
  • Select manage from the dropdown menu.
  • Press continue if a UAC popup comes up.
  • In the left pane click Device Manager.
  • From the list of devices, expand "Imaging devices".
  • Right click on the lexmark xxxx-xxxx series.
  • Select enable.
Windows should automatically find the driver you installed and the scanner should would without a hitch now.
Hope this helps ya!
Sep 25, 2006 | Lexmark X2350 All-In-One InkJet Printer
426 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
