Question about Samsung CLX 3160fn All-In-One Printer
How do I remove the fuser assembly from my Samsung CLX 3160?
I have a T-Shirt transfer stuck to my fuser assembly and can not get it out.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 65 Answers
You not able to remove it as i believe it has damaged the roller.send the printer for service.
Posted on Mar 14, 2008
Samsung clx-3160 fn printing ghost images
Remove the fusing unit and clean the upper and lower fuser roller.
Apr 04, 2013 | Samsung CLX-3160 All-In-One Laser Printer
Hello - I have a CLX 3160 printer. The black imaging film above the imaging unit seems to have ripped in one place. Is this fixable please?
It is the transfer belt. I don't think there is a supplier of just the belt itself. You must replace the transfer belt assembly. The part number is JC96-03611A.
Jan 18, 2011 | Samsung CLX-3160 All-In-One Laser Printer
I have a Samsung CLX-3160FN, and after every page
it is most likely that the fuser actuater arm is not sitting back to the sensor properly. open the back door you will be able to see the fuser, on your right hand side you should be able to see a fliper that sit in between a sensor. try to adjust the fliper flag and see if it works.
if it still continue to give you the same error. try remove the fuser four screw 2 side on each. adjust the flag again and fix it back. it should work and double check for any lose small pices of paper jam in the printer.
May 15, 2010 | Samsung CLX-3160 All-In-One Laser Printer
My samsung CLX-3160 says "paper jam" and yet there is no paper jam
Open the back door, and inside at the top above the fuser there is a cover that will lift up. In front of the cover will be a spike.
Life the cover, and let the spike (a paper sensor) go into place under the cover and replace the cover and close the door, and it should work.
The spike is lifted as paper passes through.
If you ever lifted the spike while the cover was open and then closed the cover, the spike can't get back so is always lifted and it thinks there is always paper
Mar 11, 2010 | Samsung CLX-3160 All-In-One Laser Printer
How do i fix a transfer belt error on my samsung 3160? where is the transfer belt?
take out the imaging unit(imaging unit is where the toners are put and a green OPC is there).
First open the front cover.
then pull the imaging unit.
after that there will be a delicate transfer belt.
Aug 17, 2009 | Samsung CLX-3160 All-In-One Laser Printer
I have a small peice of paper stuck in the fuser unit of a samsung CLX 3160- How do I remove the fuser to get it out? I removed the 4 screws holding it in, but it is attached somewhere else, is there a...
open back cover,remove 4 screws of fuser,standing at the back of printer on your lhs on the fuser there is a lock,pull lock towards right and fuser should come out.
Jul 13, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Solution for fuser....
no need to change it just wash thermostater
Jun 28, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Double printing in my samsung 3160 fn
open your prtinter from backside then open fuser asenmbley.
u need to change your roller
but pls take support of technician.
Oct 01, 2008 | Samsung CLX 3160fn All-In-One Printer
How do I get the fuser out of the Canon PC 940?
Open the unit, remove the power supply cover in the back left by removing 1 ***** and releasing two hooks. Remove 2 *****s securing the fuser. The *****s are located just in front (inside) of the fuser.
Disconnect the fuser power cable and logic cables and then rotate the fuser up and toward the exit area. The fuser should just lift out.
You can then open the fuser by removing two *****s and releasing two release hooks. This should allow you enough released tension to remove your transfer. Be careful not to damage the fuser film.
Mar 08, 2008 | Canon PC-940 Black and White Copier
Dirty printing and jamming
Usually with a small vacuum cleaner, you just suck the stuff off or you can use a can of compressed air. If you mean the green roller (which is part of the transfer) you can't, don't touch it you'll mess up the coating. Light isn't even supposed to touch that.
Dec 23, 2007 | Samsung CLX-3160 All-In-One Laser Printer
Samsung CLX 3160fn All-In-One Printer Logo
348 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
