Question about Acer Aspire 3100-1405 Notebook
Keyboard problems when booting up
I run Windows XP home edition with a SP2 Logitech keyboard. 50% of the time I have no problems but 50% of the time when I boot up my computer the keyboard does not respond at all and I have to reboot sometimes twice before it works. There are no problems with the actual keyboard as this is a new one and I have the same problems. Can anyone help please ?
  • Chrismart Mar 08, 2008
    Hi Mike, Thanks for this help. I have checked the device manager - no exclamation marks and it states keyboard working properly. Also gone through the update the driver process - all ok. Will check the bios config. and then restart. I'll let you know if it works. Thanks
    Genius:
  • 1,019 Answers
i can advise you with this.
it may help if you disable the original keyboard, as you may have a device conflict between the 2. you can do this from within windows.
ensure your drivers are correctly installed, for the keyboard, and the motherboard. Go into My Computer/ Control Panel/System/Device Manager And see if you have any yellow exclamation Marks. this will determine that the Device is functioning correctly. And if not you can update the driver or find the conflicting device.
Finally ensure this is the first keyboard that the computer sees, adjustment in the bios configuration.
Mike @ Compurepair.
Posted on Mar 08, 2008
  • Mike Waldron Mar 08, 2008
    Youre welcome chris.
    I hope one of these solutions work for you.
    The keyboard is all part of the computers bios setup.
    it,s configuration consists of locating several hardware devices, before it will launch the systems os.
    your computer is probably seeing, the keyboard as being present and already setup with no faults.
    Mike @ Compurepair.
  • Mike Waldron Mar 09, 2008
    Chris just one more question, Did you rate this post.
    It,s been rated, but not by yourself i don,t think.
    Many Thanks Mike @ compurepair.
My daughter (aged 12) has loaded a copy of Vista (which were discs from a computer her grandmother no longer owns and has been scrapped) onto her laptop which had Windows XP installed. She does not have a...
Hi.
If she did not format the hard disk, then the Windows XP startup option will be present in boot option. When computer startup you will get a choice like this:
1 Microsoft Windows Vista Home Edition.
2 Microsoft Windows XP Professional SP2
In that case you can restore XP, starting on XP and editing the file winboot.ini, that is an hidden system file located on C:/ drive.
See:How to edit the Boot.ini file in Windows XP.
If instead Windows XP does not start, or if you do not get the boot option, that means that Windows XP system file had been deleted.
In that case the only way to get back Windows XP is reinstalling the system from scrap, using a Windows XP install disk, and the number listed on the licence sticker.
Regards.
Oct 23, 2009 | Microsoft Windows XP Home Edition
Tip
Mamimum RAM for User @ 3GB using boot.ini switch on 4GB Physical RAM
The DOS will always take a percentage of the physical RAM on the motherboard leaving the rest for the User. By default the Windows Operating System will use 50% of the physical RAM installed on the motherboard leaving the user the remaining 50% this can be changed using a switch in the boot.ini file
The /3GB was originally meant to be used in systems that have 3GB or more of RAM something that is no longer quite as rare as it used to be Windows XP SP3 will support upto 4GB although on a 32bit (x86) version of Windows will acually see 3.25gb that is the limitation.
However, even if you don't have 3 GB or more of memory, you can still use the /3GB switch. the switch can have any value between 2048 (2 GB) and 3072 (3 GB) megabytes. It needs to be expressed in decimal notation.
The /3GB switch applies to 32-bit systems only (x86).
Example with Windows XP SP3 Home Edition with the recovery console installed this gives you the option of default 50-50% split or the 3GB switch 75-25% split.
The /noexecute parameter enables, disables, and configures Data Execution Prevention (DEP), a set of hardware and software technologies designed to prevent harmful code from running in protected memory locations using the optin switch enables DEP only for operating system components, including the Windows kernel and drivers. Administrators can enable DEP on selected executable files by using the Application Compatibility Toolkit (ACT).
The /burnmemory parameter specifies the amount of memory, in megabytes, that Windows cannot use in this example, /burnmemory=128 will reduce the physical RAM memory that is available to Windows by 128 MB.
[boot loader]
timeout=10
default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition 3GB Switch" /noexecute=optin /3GB /fastdetect
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition " /noexecute=optin /burnmemory=128 /fastdetect
C:CMDCONSBOOTSECT.DAT="Microsoft Windows Recovery Console" /cmdcons
Check out the noexecute and the 3GB switch plus all available boot.ini switches HERE
I suggest that you use AnalogX MaxMem it is a realtime physical memory management program that automatically ensures that you always have as much physical memory available as possible used with the 3GB switch you should never have memory issues ever again.
on Mar 14, 2010 | Microsoft Windows XP Home Edition for PC
Windows XP - need to restart Wireless Zero Configuration
type this in command window sc config wzcsvc start= auto
Oct 07, 2009 | Microsoft Windows Xp Home Edition Sp2...
Scandisk error, scandisk stops on system beetup
I'm not sure what you're referring to. In XP, the utility that was known as scandisk in windows 98, ME, etc is known as chkdsk, and doesn't normally run on boot unless you have set it up to do so. If you're running scandisk from dos, don't. (See this forum.)
For instructions to run chkdsk, see here and here. (and see the article above for details on how to find and read the log)
If you have a restart or shutdown issue, please consult this article and links within it to troubleshoot the problem...Or see these links for MS articles that deal with boot sequences and problems.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 08, 2009 | Microsoft Windows XP Home Edition SP2
Win xp log on failed
to avoid this problem you run in safe mode option to your system.to run in safe mode follow the step...
restart the system and then press on start F8 key from keyboard then choose safe mode option...
your windows has corrupted.
so you can also restore the system in previous date.....further detail on live chat
Apr 14, 2009 | Microsoft Windows XP Home Edition
Xp sp2
no isn't virus
i advice you to clean you Ram
and change you cd xp2
Jan 26, 2009 | Microsoft Windows Xp Home Edition Sp2...
XP RESTARTS
this is caused because a file of your pc has become corrupt and your XP needs to be reinstalled.
Dec 31, 2008 | Microsoft Windows Xp Home Edition Sp2...
Compaq 4400us windows install fails on errors
Microsoft Windows XP help Windows XP is available in the below versions:. Home Edition - Full / Upgrade ... Computer
Additional information and help with the boot.ini. If multiple operating systems are setup in the boot.ini, as the computer is booting you will ... Microsoft Windows XP Home Edition Microsoft Windows 2000 .
Good Luck, Please dont for get to Vote/Thank You.
Dec 23, 2007 | Compaq (388746-001)...
Acer Aspire 3100-1405 Notebook Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
