Question about InFocus Proxima DP6155 Multimedia Projector
I have an alignment problem with colors and i've found a little mesh screen
My proxima dp6155 had a bulb burn out and was working perfectly. I went to replace the bulb and hears something rattling around inside. in rocking the projector back and forth a little silver screen - rectangularly shaped with hundreds of holes fell out. - it appears that it was just glued in place somewhere inside the projector. I powered up the projector and now seem to have a convergience problem. Does this little screen matter or does it pull all the colors together? thanks for your help
  • 2 more comments
  • Joema888 Mar 13, 2008
    I have the exact same problem, while replacing the bulb I found a little silver screen loose inside, not I am seeing ghosting.. can anyone help?
  • dwgraham1950 Jul 17, 2008
    Same problems. After an hour or so of using the projector, I begin to
    get ghosting. If I shut the projector off and unplug it, it will be fine for
    another hour or so before it begins again. ????? I also found the
    metal screen part of the bulb housing lying inside the projector. It
    appears heat from the bulb dried out the glue on the screens and
    they simply fell off.
  • Munkee_B Sep 01, 2008
    I have the same exact problem. After a wile of use the colors kinda separate. The little screen that everyone is talking about is a part of the lamp itself. Its a filter, preventing big dust particles from entering the lamp. It has nothing to do with the ghosting image. I think its a heat issue or something. I've fully dismantled my projector and found nothing physical burned out. I know a little about electronics but have no idea how this thing works. The LCDs work fine, the cooling system has no obstructions, the processor seems fine, the lenses and mirrors are in place. So my conclusion is that it has to be an electrical component on the main board. video cards do something similar when a memory module is going bad or the GPU is overheating. I dought its the problem though because it seems to start happening after a couple of thousands of hours of use, so it has to be something that wears out. It could be a capacitor or censer of some kind. IF anyone els understands this better please help! I'm vary frustrated because I know its simple, I'm just not seeing it. If it works fine at time it just means its one tiny malfunction throwing the rest of the system off.
  • rpm1970 Mar 31, 2009
    I had this same problem, I just glued the screen back on. You can fix the ghosting in the service menu.
    Problem Solver:
  • 5 Answers
Yr previous buld is it burn out or explode ?
if explode might be the tiny glass neeed to service (cleaning)
please do a tilt correction
do manually
Posted on Jul 10, 2008
Image looks doble in colors.Gren,Blue Red
Depending on how severe it is, it can be fixed. I can do the repair if you'd like.
Mar 10, 2010 | InFocus Proxima DP6155 Multimedia...
I'm trying to replace the lamp
all [parts small or large are in place for a reason and if it does not go back on then the chances are that yu have the wrong bulb as this is a common occurance. also you will have a counter for the bulb hours on the inbuilt menu on screen, this will need resetting for full functionality to be returned.
Feb 25, 2009 | InFocus Proxima DP6155 Multimedia...
Bulb hours?
The lamp timer hours can be found at the very first thing in the "ABOUT"menu
Cheers
Feb 20, 2009 | InFocus Proxima DP6155 Multimedia...
ALIGNMENT Problem - InFocus Proxima DP6155 Multimedia Projector
if the lcd panels have become misaligned, it is time for a new projector, the parts are no longer available for this unit, and it needs the most expensive part, the LCD block
Jul 19, 2008 | InFocus Proxima DP6155 Multimedia...
Projector getting too hot
comman to a projector to get hot in front and top center part
but not at the rear side
this might be
fan not working
filter need to clean
bulb life getting lower
open the cover check safety paper
might be burn out
replace new one.any hard paper
Jul 10, 2008 | InFocus Proxima DP6155 Multimedia...
Color alignment
how to know the bulb is weak?
is the replace bulb indicator up?
more then 1000 hrs?
picture get blur?
colour line out .nothing to do with bulb
u must check the colour filter inside
loose contact or have to do recorrection by technically
May 14, 2008 | InFocus Proxima DP6155 Multimedia...
Color Alignment
reset the settings to factory default. then re-solder the fingers on the edge of the power supply board where it goes into the main board edge connector.
Nov 14, 2007 | InFocus Proxima DP6155 Multimedia...
Hot to adjust the convergence on the DP6155
resolder the fingers on the edge of the power supply where it goes into the main board edge connector.
Oct 16, 2007 | InFocus Proxima DP6155 Multimedia...
InFocus Proxima DP6155 Multimedia Projector Logo
358 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
