Question about Canon PC-940 Black and White Copier
How do I get the fuser out of the Canon PC 940?
I have a T-Shirt transfer stuck to my fuser assembly and can not get it out.
  • 15 Answers
Open the unit, remove the power supply cover in the back left by removing 1 ***** and releasing two hooks. Remove 2 *****s securing the fuser. The *****s are located just in front (inside) of the fuser.
Disconnect the fuser power cable and logic cables and then rotate the fuser up and toward the exit area. The fuser should just lift out.
You can then open the fuser by removing two *****s and releasing two release hooks. This should allow you enough released tension to remove your transfer. Be careful not to damage the fuser film.
Posted on Mar 09, 2008
Where are fuser are stand
The fuser is located after the paper exit section(hot area).
May 01, 2013 | Canon PC-940 Black and White Copier
My PC 745 comes up with an error code of a paper jam but I cannot find any jammed paper. Any suggestions.
completely remove the paper cassette and look for A SMALL PIECE OF PAPER stuck inside the machine in the paper path. Also use a flashlight to check for tiny bits of paper in the exit section of the machine where the fuser (hot) rollers are.
Dec 16, 2010 | Canon PC-940 Black and White Copier
Copies are coming out wrinkled - always in the same spot.
You can try to stop the process mid-print. That way if the paper is un-wrinkled before it hits the fuser, then it must be the fuser causing your problem.
The PN for the fuser is FG6-3720-000 and sells new for about $175
Whit
Item, inc.
Sep 16, 2010 | Canon PC-940 Black and White Copier
Canon copier 940 trouble code EO?
Odds are that you are getting a error code E000. It is saying that you have a problem with your fuser unit. You can try to unplug the copier for a short time. But you will mostly need a new fuser unit. Good Luck
Sep 07, 2010 | Canon PC-940 Black and White Copier
Canon PC 940. replaced a $6.00 roller because bushing broke. Now I get code "EO". any ideas
the heat element is not heating up check the connections at either end of upper fuser roller. unpluging copier for 20 minites should reset the error
Aug 19, 2010 | Canon PC-940 Black and White Copier
Canon pc940 error code e261
try turning the machine off and then on...you either had a power surge and it freaked out your machine or the fuser is shot...
Dec 17, 2009 | Canon PC-940 Black and White Copier
We have a Cannon PC 940 and the paper is stuck at the end where it should come out. There is a green up arrow and the paper is stuck under that - moving the knob up does not release the paper - it is...
When is paper stuck at the end position.You should open by unlock point in left side.There is a Green up arrow which call Fuser unite,Release it up and open paper.If every time stuck there paper,may be fixing film was broken,or other spare parts are missing.Check it and solve your problem.
Dec 08, 2009 | Canon PC-940 Black and White Copier
My iR2016 displays "system error E007, would you please help me repairing it?-
it error code means fuser unite problem please change fuser unite then solve your problem
Nov 20, 2009 | Canon PC-940 Black and White Copier
Where is the fuse on the canon pc-940 copier. It
Why would a fuse have any thing to do with a clicking sound? If the fuser or fixing unit was having a problem you would get a error code. Have you replaced the toner or drum cartridge any time? If so, was the noise there before? If it was not recheck the installation and if you put the old parts back in and you have no noise, it has to be the new cartridge.... Good Luck
Oct 14, 2009 | Canon PC-940 Black and White Copier
How do I remove the fuser assembly from my Samsung CLX 3160?
you not able to remove it as i believe it has damaged the roller.send the printer for service.
Mar 08, 2008 | Samsung CLX 3160fn All-In-One Printer
Canon PC-940 Black and White Copier Logo
182 people viewed this question
old marine
old marine
