Question about Consew 199R-2A Sewing Machine
Bobbin Threading Hi, I have a new Consew 206RB-5. I followed the directions in the manuel how to thread the bobbin on the side of the machine. The only thing is I turn on the machine and nothing happens. Am I supposed to press something I don't understand. I need to know how to thread the bobbin on my Consew. The bobbin is the drop-in ,not insert to the side type. I just can't figure it out. Probably very simple... The bobbin is filled and the machine is threaded properly, but can't figure how to get the boobin thread to catch. I am doing something wrong in threading the bobbin.
  • Consew Master
  • 11,749 Answers
"turn on the machine and nothing happens"
That is the way sewing machines should work. A sewing machine should not begin running when it is turned on. There is usually a foot pedal or something (like the gas pedal in a car) that governs the start, speed, and stop.
Do you not have a manual for your machine? Very important piece of information for how to use your machine.
Posted on Jun 07, 2017
    Problem Solver:
  • 8 Answers
Divot on needle must be installed facing bobbin case.
5 Suggested Answers
SOURCE: Bobbin Threading
pree the foot pedal...
Posted on Jun 02, 2008
  • 323 Answers
SOURCE: Consew 206RB, threading problem?
This machine has a safety clutch which is designed to protect the hook mechanism.To access it, place the machine on it's back. About 8-10 inches from the right side you will see an assembly on the main shaft. You need to hold this assembly with a push button located on the bed of the machine while you turn the handwheel. It will click in place when it is in the correct position. Once you've done this the machine should be back in time so it will sew.Hold the top thread ,turn the handwheel and draw the bottom thread up before you begin sewing. Place a piece of fabric under the foot , turn the wheel by hand to make sure there is no binding and that the thread is being picked up.
sewman7
Posted on Aug 29, 2008
Michaelle
  • 65 Answers
SOURCE: Bobbin thread
You may have bent the needle, replace that first.
Have you wound a new bobbin? Sometimes they wind poorly.
Check the hook race for thread "nests". (Bobbin casing)
Posted on Jan 24, 2009
SOURCE: Threading a consew RB-1 sewing machine
Send an email to me at dbjamie@msn.com and maybe I can help. I'd need more info. on your ploblem. I'll start you off with these two things assuming that your difficulty is with the bobbin as you state "underneath & threading". Notice the white painted dot on the the machine arm at the drive pully. Notice the white dot on the pully. Allign these two. Tilt the entire machine head back so that it is resting on the word verticle finger stop (or get underneath the machine). Bobbins are loaded by pulling the small chrome lever w/ your thumb & index finger (this is an unlocking latch). Do so moving it outward to about 90 degrees. Usually while you do this the holder and bobbin just pop out. To install u just snap then on. It's placed when u hear a click. For more info email me directly. Doug
Posted on Jun 18, 2010
Threading the bobbin is not smooth and even and tends to get hung up when sewing, how do I get it to work properly ?
Please post the brand and model of your machine, and a picture of the area where you insert the bobbin.
Dec 13, 2014 | Consew 206RB
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
Stitch tension problem - bobbin thread lies flat or bunches. If you increase the needle thread tension there is no improvement - even at the highest needle thread tension the bobbin thread is a mess. Any...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 16, 2011 | Consew 7360R-1 Mechanical Sewing Machine
There are a few Consew models listed here http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm maybe one will be similar enough to help you with the threading of your machine.
Apr 19, 2010 | Consew 206RB
I need a downloadable Operating Manual for the Consew 206RB-5
I can not get the top thread to pick up the bobbin thread on a machine I have just bought .It was sewing fine and then the bobbin ran out. I have tried every which way but nothing works which way should the bobbin be winding
Apr 08, 2009 | Consew 206RB
Consew 206rb-1 thread was caught in the boobin area i removed
Had the same problen today, Remove your bobbin, the part where the bobbin is in should move a little, if it does not you have string you can not see behind that part. To get it out turn the machine backwards, it will really turn hard, but will turn, do this until you can see the thread come out or until the piece that holds the bobbin will move a little. good luck
Apr 06, 2009 | Consew 206RB
Bobbin Case will not snap into housing
Insert the bobbin case without a bobbin to see if it will go all the way into the locked position. If it does,the bobbin case and basket are okay.
Check inside the bobbin basket(where the bobbin goes) and see if there is thread or lint wrapped around the spindle the bobbin case sits on. If there is, remove it. If there isn't ,then the bobbin is probably sprung and needs to be replaced.
sewman7
Oct 14, 2008 | Consew 206RB
Consew 226 r sewing machine
do you have the user manual?
Sep 15, 2008 | Consew 206RB
sewman7
Aug 28, 2008 | Consew Sewing Machines
Bobbin Threading
Feb 02, 2008 | Consew 206RB
Consew 199R-2A Sewing Machine Logo
102 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Oloyede Monsuru
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
