Question about Yamaha DSP-AX1 10-Channel Amplifier
B speaker doesnot get on.
Hi
can please advise i can on speaker B. when i press the button on there is only found diplay but no relay comes nor in gets on. please confirm any body how i soloved this problem.
thanks
Noshad
    Novelist:
  • 236 Answers
Switch fiorst your A speakers to B. see if nothing is changed and the speakers connected to B still doesnt work.
The switch for the speakers could not be cleaned my friend. it is a microtac switch only sending a small signal to the relay circuit to activate the speaker relay. but still good chance of microswitch malfunction since set A is working, no problem with your amp.
redrivera0314@yahoo.com
Yamaha tech
Posted on Mar 19, 2008
  • 682 Answers
Apply a good contact cleaner in this button and press it many times.confirm good connection between amplifier output and speaker b.connect speaker A insted of speaker B if it is working the problem will be in cabel and speaker B if not the problem in your amp output stage.
Posted on Mar 10, 2008
Hi, i own a Nokia 5310 Xpress Music...Recently i dropped my mobile down and from that I have problem with my mobile i.e : whenever i get a call,the caller is able to hear my voice but i cant hear the...
First check the speaker or replace it. if this doesnot work then check or change ringer ic.....this has to be done by an expert using hot air gun 4bf42d39-d9c1-4c7d-b217-96cbf6bbe095.jpg
Jul 21, 2011 | Nokia 5310 Cellular Phone
Resendly purshased a casio 4772 watch. diplay time and city. trying to get it set for dst. read manual and cant get button (A) to flash. can u help
Hi ...
your watch supports Time Zones , Automatic time Updates, Automatic adjustments of DST.
First Verify Correct Home City Is Selected
1. In Time Keeping Mode (That is The Digital Display shows time and Day of week)
2. Press Button (A) long enough to country code start to flash on digital display.nightflare_4.png
3. Press Button (B) or Button (D) to change Country code to current one.
4. After Selecting Desired Country, Press button (A) TWICE.
Now Country Code will be saved on watch.
Supported Country codes are:-
To Activate DST (Daylight Saving Time).
2. Press Button (A) long enough to Digital Display start to flash.
3. Press Button (C) TWICE to Display DST Settings.
4. Press Button (D) repeatly to cycle through three DST Options:-
A --> DST is set on Automatic Mode. If Your country uses DST, the watch will Adjust DST Accordingly.
OFF --> DST is set to disabled. No DST is applied to Main Time Settings
ON --> DST is Set to On. DST is applied even if your country doesnot follow DST.
5. Press Button (A) TWICE to save Selected Option.
Default values (Factory Settings) when you bought this watch is
This way you can set DST
Mar 13, 2011 | Watches
Hi, I have ViewSonic VX2235wm-5 22"
It appear the monitor has been connected to another system unit than the default. disconnect the entire systems and reconnect altogether, restart the computer to allow the unit to recognise the new monitor. should diplay possible soluiton, else follow the instrcutions below
1.locate the control panel where the options of systems setting is displyed.
2. a click should dispaly a list among which is device speaker options
3. the computer speaker could be updated by clicking to install drivers or codes acquirable from the network.
alternately
1. click on the hardware icons located after locating and clicking into control panel.
2. on the list of add delete hardware provides the option to attempt to delete the speaker codes
3. a delete of the speaker drivers on system restart would prompt the user to update the speakers. A click on the prompt should acquire the necessary installation kit patches from an internet connection if any.
Dec 06, 2010 | ViewSonic VX2235WM Monitor
Surround audio system: only 2 speakers work
Finally solved it. Push the "prologic" button several times until 4 channel appears in the display.
Sep 19, 2009 | Audio Players & Recorders
Amp Err
please check all speakers cables for short circuit-disconnect all speaker-put volume low-wait and observe it if no shut down -go to next step-connect your speaker one by one until you find the bad one,start with speaker cable(try another good cable) and then speaker.if shut down happened again while you connect nothing to your system you will have inside problem and ask for service center to fix it.
Jul 07, 2008 | Audio Players & Recorders
I believe an amplifier problem
I had a problem with no audio and I recently found the fix. When thesub still worked and you turn it on you hear one relay click and thenabout 5 seconds later a second relay clicks and the audio comes on. Theproblem I had lies with that second relay. When you take the case apartthere are 4 circuit boards. The big board with the two big bluecapacitors is the main board. Well next to the two blue capacitors is ablue relay. That relay had a pin that came un-soldered from the circuitboard. I re-soldered that pin and the sub works just like new. If yougo here http://www.eserviceinfo.com/downloadsm/20627/sony_sawm500.htmlyou can find a free service manual that has the wiring schematics forthe amp. Hope this helps!
Apr 15, 2008 | Sony SA-WM500 Subwoofer
Ipod is not diplayed properly
tyr resetting ur ipod by pressing the center key and menu key together till u see an apple logo on the screen if it doesnot work try taking it to a service outlet
Mar 31, 2008 | Apple iPod nano
NO SOUND
I had a similar problem with my Navman F20 (no sound through speakers but OK on headphones, through the T1 module). When I opened the back up, I found that the speaker connector had come loose from the PC board - it looks like it's a **** fit anyway.
Undo the two screws holding the case together and gently prise the two shells apart, I used a broad bladed kitchen knife. I found that the speaker plug had fallen out of the socket, popped it back in and Bob's ***********'s brother.
Nov 03, 2007 | Navman F20 GPS Receiver
Yamaha DSP-AX1 10-Channel Amplifier Logo
160 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
