Question about M-Audio FireWire 410 External Sound System
M-audio firewire 410 on macbook
I installed lastest betadriver for firewire 410 on macbook
i can record in garageband, but always on channel per input
input 1 always leftchannel
input 2 always rightchannel
what do i have to do to get both channels left and right to receive input signal?
  • 1 more comment
  • Smifty Mar 10, 2008
    ok thanks
    will try
  • Smifty Mar 11, 2008
    problem with signed driver is that when i used that driver i get message that there is no firewire 410 connected... is it not compatible with leopard?
  • Anonymous Mar 14, 2008
    I just switched form PC to Mac after many years. I will tell you the first cuple of days I was seriously impressed, until I started adding software. Avid Media Composer No support for Leopard. Firewire 410 No Good. Evolution Keyboard Drivers. No Good. Hmmm Just like a PC!!!!
  • 30 Answers
Use a 'Y' splitter. Usually from balanced to unbalanced. Also try looking at your device's control panel and see if you can change the channel options from mono to stereo. Beta drivers are for testing purposes, so try the signed driver also.
Posted on Mar 10, 2008
  • Jason Crowe Mar 15, 2008
    Do you have it plugged into the wall also? With the computer off plug in your 410 to the firewire port and the power adapter for your wall socket. Turn on the 410 and boot up you computer. If everything tests ok, turn off your computer and unplug the 410 from the wall outlet only. Boot computer. Hopefully this helps. Good luck.
Helpline
The guide fro properly connecting your microphone is here
GarageBand 11 Connect microphone
The problem is with OSX and its usb bus and not your settings or your usb device.
The solution to your problem is to use a firewire soundcard. That way it will use the firewire bus and all should be fine.
Feb 15, 2014 | Computers & Internet
Mic not working!
Go to logitech's website and look for the latest driver for your microphone:
http://www.logitech.com/en-us/support-downloads
Install it, plug in mic, load audacity/garageband, or any windows recording application, and ensure the mic input on the application is set to the plugged in logitech/labtec mic. Ensure the input volume is set to a level that responds when speaking into mic. Press record to see if it picks up the audio.
Apr 13, 2012 | Audio Players & Recorders
How do I record dtxpress 3 on garageband?
Your best bet is to get a "midi to usb" cable. is use the M Audio Uno and have had no problems, then it will record as midi, so you can edit the hits later if needed.
Mar 30, 2012 | Yamaha Dtxpress III Electronic Drum Set...
Has anyone come up with the mac OS-X 10.6.1 ,problem yet this **** *** for the m-audio 410
I washaving troubles with 410 in my new macbook pro osX10.6.1. I tried to update and... now is not working anymore!
Does any install snow leopard beta driver on regular leopard? Does it works?
Oct 19, 2009 | M-Audio FireWire 410 External Sound System
Samson G Track USB Mic
To get sound in both channels in Garageband for a podcast using the G-Track Microphone:    select a voice track to record into    make sure the Track Info window is open (blue i button in lower right region of screen)    at the bottom of the Track Info window you will find Input Source:    Change the default setting of Stereo to Mono 1 (USB Audio CODEC)
This assumes you have gone to Garageband preferences and changed the Audio/Midi settings for audio input to USB Audio CODEC which appears when you plug in the G-Track Mike
Apr 08, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Get sound through a Behringer 1204FX mixer & FCA202 interface
Block diagram available here:
http://www.behringerdownload.de/XENYX_GRP2/1204FX_VIEW_Rev_A.pdf
Where are the trim controls set?
Those mics use both phantom and battery power; are the mic switches set to phantom?
Try using the CD/Tape outputs to the FCA202
Nov 20, 2008 | Behringer F-CONTROL AUDIO FCA202 External...
I have an io26 firewire audio interface linked to my macbook. When i record in cubase le4n i'm only getting sound out of the left headphone and its seriously quiet. I have set the audio/midi settings to...
your audio are not in interface with your macbook it means to say, the common wire are not in the same connection. that why you only hear sound on your left headphone. in short your firewire audio is not compatible with your macbook. but you can rewire it with same audio plug. or replace the audio plug with the compatible one. when you do this, make sure that the common wire of your firewire audio and your macbook are in the same connection.
Nov 07, 2008 | Computers & Internet
Firewire audio problem
Are you using the 410 for recording or as a playback consumer soundcard? Is it connected to external speakers and if so, what type?
Keep me posted.
Dec 29, 2007 | M-Audio FireWire 410 External Sound System
Lots of noise when laptop power cord is plugged in
You must be running on pc, or it sounds like you may have a ground loop issue. If you are running a mac, then bus power over the firewire should be enough. If your running on a pc, try getting a pcmcia card with 6 pin firewire ports. If not then your pc laptop will have to power the 410 via ac adapter. That means both should be plugged in tot he wall. Ive gotten that interference before, and gett it on any audio, whether im producing or playing itunes. I find the trick is to reset the 410 via the output window in the top right. It's right above the level knob. Also, try just installing the latest driver, with the 410 disconnected, then launch it from a different file path than the icon.
I still use it for the macbook pro, and its not always top notch. I bought it 3 years ago for 500, and i see what 500 buys nowadays.......MOTU!!!!
Keep me posted.
Dec 08, 2007 | M-Audio FireWire 410 External Sound System
Firewire410
You should install service pack 2, the go to the m-audio site and upgrade the drivers again. Also, since your computer most likely have a 4 pin firewire, make sure you have the power cqble for the 410 connected. Ofcourse, do not have the 410 connected when upgrade either sp2 or the drivers. make sure you power cycle both devices before reconnecting and attempting to record....
http://www.m-audio.com/index.php?do=support&tab=driver&serie_ID=2&PID=5f35def5b4107998b11119907053a313&OS=15
keep me posted...
Nov 19, 2007 | M-Audio FireWire 410 External Sound System
Open Questions:
M-Audio FireWire 410 External Sound System Logo
373 people viewed this question
Top M-Audio Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Jim Goldsmith
Jim Goldsmith
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
