Question about Samsung ML 2010 Laser Printer
How to remove or change toner
Hello. i want to ask for assistance to please tech me how to remove the toner of my ML 2010 Laser Printer. thanks
  • Anonymous Mar 20, 2014
    After removing and returning the toner the message ask for instalment of toner
    Sniper:
  • 60 Answers
If you dont have the user's manual, here you have it online :
http://downloadcenter.samsung.com/content/UM/200602/20060216163720484_ML-2010_English.pdf
Look at page 24 - "Installing the toner cartridge" where you'll find this, but also pictures to illustrate how to do it.:
"1 Grasp the front cover and pull it toward you to open.
Note: Because the printer is very light, it may be moved when you
use it; for example, when opening/closing the tray or installing/
removing the toner cartridge. Be careful not to move the printer.
2 Remove the toner cartridge from its bag and remove the
paper protecting the cartridge by pulling the packing tape.
3 Gently roll the cartridge 5 or 6 times to distribute the toner.
Thoroughly rolling the cartridge will assure maximum
copies per cartridge.
Note: If toner gets on your clothing, wipe it off with a dry cloth
and wash clothing in cold water. Hot water sets toner into fabric.
Cautions:
• To prevent damage, do not expose the toner cartridge to light for
more than few minutes. Cover it with a piece of paper, if left
exposed for more than a few minutes.
• Do not touch the green underside of the toner cartridge. Use the
handle on the cartridge to avoid touching this area.
4 Locate the cartridge slots inside the printer, one on each side.
5 Unfold the toner cartridge handle and grasp it. Insert the
cartridge in the printer until it snaps into place.
Note: Carefully insert or pull out the toner cartridge not to scratch
against the printer.
6 Close the front cover. Make sure that the cover is securely
closed. If the cover is not firmly closed, printing errors may occur when you print.
Rate the answer please.
Posted on Mar 10, 2008
Hello! My Samsung ML 2010 Laser Print has started to print pages with streaks of ink across them. This makes the pages more difficult to read, and certainly cannot be used for formal letters. It also...
there must be waste toner in your toner cartridge
the waste toner box is fitted above the drum in toner cartridge with 2 no screw open it and empty then try to print
Jan 26, 2011 | Samsung ML 2010 Laser Printer
ML 2010 Laser Printer: have aquired a samsung ml-2010, have installed dri...
have you tried replace a new toner. If new toner also giving out noise. it is most likely the main drive issue.
May 17, 2010 | Samsung ML 2010 Laser Printer
Ineed samsang ml-2010 original drum
This printer has integrated Laser Toner and Drum.
here is the part: Innovera Laser Toner/Drum for Samsung ML 2010
May 16, 2009 | Samsung ML 2010 Laser Printer
Faint vertical lines on Samsung ML-2010
Was the toner remanufactured/ compatible?
Sounds to me like the doctor blade in the cartridge is 'gummed' up and not allowing the toner to flow evenly across the Developer roller......try another cartridge
Apr 10, 2009 | Samsung ML 2010 Laser Printer
I have put new toner, switch printer on and it shawing arror on line. Could you tell me please what the problem is? Thank yoou.
Is the printer actually the "ML2010"?
Was it asking for toner and functioning properly prior to replacement?
Is the cartridge remanufactured? It could be defective.
I would try another one, especially if it was 'ok' before changing.
Mar 20, 2009 | Samsung ML 2010 Laser Printer
SAMSUNG ML-2010
Hello Liz,
I've worked with one of these before, it's really not too bad. Looking at the printer from the front, you can pull on the plastic panel with the SAMSUNG logo from the sides, and it will unsnap and flip down. The toner cartridge has a big handle on it that sticks way out in front. Give it a firm pull, and it should slide right out.
Pay attention to the direction the toner cartridge is in, because you'll push your new cartridge in the same way.
~Cactus
Sep 16, 2008 | Samsung ML 2010 Laser Printer
Fain printing
I'm using remanufactured toner provided with my ML-2010 by Discount City when I purchased the printer and I'm having the same problem.
I have used non OEM toner in other laser printers also with disasterous consequnces so I think you'll have to 'bite the bullet' and purchase a new Samsung toner cartridge unless you can find out who manufactures the cartridge in which case you might be able to souece one directly avoiding the extorionate mark up.
Jun 19, 2008 | Samsung ML 2010 Laser Printer
Samsung ML 2010 Laser Printer Logo
720 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
