How to convert FAT32 to NTFS
Cannot play NTFS on an old 250 GB Recorder.
    Genius:
  • 1,665 Answers
Hi have a nice day!
To convert FAT32 to NTFS advice microsoft support.
Is that you want?
Posted on Mar 08, 2008
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Mar 08, 2008
    To convert an existing FAT or FAT32 volume to NTFS, follow these steps:
    1.
    Click Start, point to All Programs, point to Accessories, and then click Command Prompt.
    2.
    At the command prompt, type the following, where drive letter is the drive that you want to convert:
    convert drive letter: /fs:ntfsFor example, type the following command to convert drive E to NTFS:
    convert e: /fs:ntfsNote If the operating system is on the drive that you are converting, you will be prompted to schedule the task when you restart the computer because the conversion cannot be completed while the operating system is running. When you are prompted, click YES.
    3.
    When you receive the following message at the command prompt, type the volume label of the drive that you are converting, and then press ENTER:
    The type of the file system is FAT.
    Enter the current volume label for drive drive letter
    4.
    When the conversion to NTFS is complete, you receive the following message at the command prompt:
    Conversion complete
    5.
    Quit the command prompt.
    See also
How do i remove parameters from a kanguru 4 g usb flash drive?
Which format fat32 or ntfs make sure its fat32 Indeed, FAT32 only supports files up to 4 GB. I ran into the same problem when copying an ~4.5 GB file to an 8 GB flash drive. There is a quicker solution that doesn't require you to reformat or lose data on the drive, using the command-line "convert" command. Suppose the flash drive is mounted to g:\. Open up a command window (start menu -> run -> cmd), and type: convert G: /FS:NTFS. Personally, I don't need the "security descriptors" on the flash drive file system, so I use the variant: convert G: /FS:NTFS /NoSecurity. The conversion should be very quick, and of course it has the benefit of not needing to move any files off the flash drive (since you don't need to reformat it). Hope this helps.
Dec 18, 2012 | Kanguru 4GB FlashBlu II USB 2.0 Flash...
Tip
Convert FAT or FAT32 File system into NTFS
You can increase the performance of your computer using NTFS (New Technology File System) hard drive volume with windows XP, because this advance file system provides some extra features, for example security, reliability, file encryption and Compression features.
But if you are still using old file systems like FAT or FAT32, you can covert it into NTFS with a simple command. The interesting thing is that you can convert your hard drive volumes file system without losing data on the drive. Follow the giving steps to convert FAT or FAT32 partition to NTFS:
  • First go to Start button then click on Run option.
  • Now type here “CMD” and press Ok to open command prompt.
  • At the command prompt type convert drive letter name: /fs:ntfs
  • For example if you want to convert drive E to NTFS then the command will be “convert e: /fs:ntfs”.
  • Now restart your computer and enjoy NTFS features, but keep in mind you cannot covert back it to FAT or FAT32 again.
on Jan 29, 2010 | Computers & Internet
How to change transcend external harddisc fat32 to NTSC
HI you mean NTFS if YES, then there is step for xp or win 7
1. click Start, click Run, type cmd, and then press ENTER.
2.In the command prompt window, type: convert drive_letter: /fs:ntfs
Regards,
Chandrakanth
Oct 07, 2012 | Buffalo Technology 250GB USB SATA 2.0 HD...
The parameter is incorrect
which format fat32 or ntfs
make sure its fat32
hope this helps
Mar 03, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
Im copying a game that is 5 Gb and my free space is 160Gb why does it say that the "there is no disk space" is there anything i could do?
1.plz check your hardisk about any virus..
scan your hardisk a good antivirus
and check your partition type FAT or NTFS, FAT32 only support maximum file size 3gb
if FAT32 please convert as NTFS.
please letme know this helpful
Feb 01, 2011 | Western Digital WD Passport 250GB Portable...
I am trying to update my back up but I get a message the disc is full (although it does not appear to be when I look at its porperties). I am instructed to delete and backup the files again and when I try...
I thing your file system is FAT32.fat 32 can only store file size of maximum of 4GB.change file system to NTFS.
To convert a volume to NTFS from the command prompt
  1. Open Command Prompt. Click Start, point to All Programs, point to Accessories, and then click Command Prompt.
  2. In the command prompt window, type: convert drive_letter: /fs:ntfs
For example, typing convert X: /fs:ntfs would format drive X: with the ntfs format.
Aug 29, 2010 | LaCie (300770) 250 GB Hard Drive
My new 500 G external hard drive seems to limit the file size under 5 G. Is there somewhere I can reset this to larger file size?
A disk may be formatted using different file systems. The ones used by Windows PCs are FAT32 (an extension of the old MS-DOS FAT) and the newer NTFS.
If the drive is formatted as FAT32, the maximum file size is 4.294 million bytes (some systems report this as 4.294 GB; it is actually 4 GB minus one byte).
If this is the case (Start -> Run Command -> DISKMGMT.MSC and look for your external drive, it will say something like 489 GB NTFS or 489 GB FAT32), my suggestion is to back it up somewhere else and reformat it as NTFS. There also are utilities to convert FAT32 into NTFS, but if anything goes wrong during the conversion, you can say goodbye to all your data.
Note that you won't be able to access a NTFS formatted external drive except from Windows PCs (and most Linux, usually read only), while FAT32 disks are readable from Mac OS X too.
Nov 03, 2009 | Acomdata HybridDrive E5 Hard Drive
How can I format my newly bought Seagate 250 GB External Portable Drive into FAT32 system. Are most dvd players now with usb support for divx cannot access external drives that are in NTFS format such as...
You can specify the format type on the option page for format before you press the format button when displaying the drives in "My Computer"
Additionally, you can CONVERT an existing FAT or FAT32 partition to NTFS. Follow the steps below for Windows XP:
  1. Click Start, point to All Programs, point to Accessories, and then click Command Prompt.
  2. At the command prompt, type the following, where drive letter is the drive that you want to convert: convert drive letter: /fs:ntfs For example, type the following command to convert drive E to NTFS: convert e: /fs:ntfsNote If the operating system is on the drive that you are converting, you will be prompted to schedule the task when you restart the computer because the conversion cannot be completed while the operating system is running. When you are prompted, click YES.
  3. When you receive the following message at the command prompt, type the volume label of the drive that you are converting, and then press ENTER: The type of the file system is FAT.
  4. When the conversion to NTFS is complete, you receive the following message at the command prompt:Conversion complete
  5. Quit the command prompt.
Sep 21, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a 250 Gig WD hard drive originally hooked up to Mac OSX 10.5.6.  I put files on it and then a co-worker looks at those files on a PC. Now, she's given the drive back to me to add more files. These...
Greetings.
files bigger than 4 gigs cannot be save on fat32 drives. NTFS file system is capable of saving files bigger than 4 gigs.
The MAC - to PC did nothing to change it. It did not change while she look it at her pc.
If u want to be able to copy files bigger than 4 gigs to your drive, change the format to ntfs.
  • It is easy to convert partitions to NTFS. The Setup program makes conversion easy, whether your partitions used FAT, FAT32, or the older version of NTFS. This kind of conversion keeps your files intact (unlike formatting a partition). If you do not need to keep your files intact and you have a FAT or FAT32 partition, it is recommended that you format the partition with NTFS rather than convert from FAT or FAT32. Formatting a partition erases all data on the partition and allows you to start with a clean drive. Whether a partition is formatted with NTFS or converted using the convert command, NTFS is the better choice of file system. For more information about Convert.exe, after completing Setup, click Start, click Run, type cmd, and then press ENTER. In the command window, type help convert and then press ENTER.
Link to steps and other info
http://technet.microsoft.com/en-us/library/bb456984.aspx
Hope that helps.
Jan 10, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Recently bought a Maxtor portable 250 GB HDD, need to format it to FAT32 so that my Playstation 3 can recognise it, but Vista will not allow it, can only format it to NTFS and exFAT. How can i format the...
You must be logged on as an administrator to perform these steps. Before you begin, note that the FAT32 file system has size limitations. In this version of Windows, you cannot create a FAT32 partition greater than 32 gigabytes (GB). In addition, you cannot store a file larger than 4 GB on a FAT32 partition. For more information, see Comparing NTFS and FAT file systems.
blank.gif Converting a hard disk partition or volume from NTFS to FAT32 requires that you reformat the partition, which will destroy any data on it. Be sure to back up any data you want to keep before you begin.
Nov 04, 2008 | Computers & Internet
Computers & Internet Logo
102 people viewed this question
Alun Cox
David Payne
David Payne
