Question about Mitac Mio C210 GPS Receiver
Mio c 210
When switched on blank screen on one side
  • 45 Answers
Replace the display or verify it's conenctor to mainboard
Posted on Apr 10, 2009
My garmin 210 just went to blank screen
saving activity is due to a voltage problem check your connections and don't leave it in the sun!
Sep 06, 2012 | Garmin Forerunner 210 - Unit Only
When switched on my navman m420 screen is blank even after charging
Try this: 1. Connect your device to the computer 2. Make a backup of your addresses and favorites if you wish 3. In File Explorer, right click on the device (removable drive) >> Format 4. Start the Desktop 5. Go to My Mio >> Reinstall the software 6. Go to My Mio >> Recover Keys 7. You can now reinstall the maps from the Maps tab. If you downloaded a map update, make sure to use the downloaded file. 8. Go to My Mio / Voice Transfer and re-install the voice files
Jan 17, 2011 | Navman Mio M400 Car GPS Receiver
How to open mio P560 for changing battery
I have just replaced my battery in my Mio p560. On the back of the Mio at the top - remove the two small rubber bungs, you will see the screws underneath. On the back at the bottom you must remove the alluminium strip to get at the remaining two screws. This is the only tricky bit! The strip has the hole for the pointer on the right, with a small screwdriver prise up the LEFT side of the strip, it is stuck down but will come if you are gentle! Then you can detatch the strip at the right side. The two bottom screws will be under this strip. remove the four screws now. The FRONT of the Mio can then be separated from the back, it just clips along the sides. The battery can then be got at and exchanged. When you re-assemble make sure the on/off switch locates properly. Thats it! Regards David Harford
Oct 09, 2009 | Mitac Mio P550 Pocket PC
Problem to connect in My PC the MIO C220
put a 2gb blank sd card in a computer that accepts sd cards. transmit the map from the cd directly to the blank card. Then put the new map into the C220 and reboot by holding the "ON" button down until it reboots.
Jun 30, 2009 | Gomadic (RTC122921) Power Adapter, Power...
Mitac mio 168 problem
call the techie. That'll the best
Mar 25, 2017 | Mitac Mio 168 Pocket PC
Display problem mio 168
After battery changing is usually needed to reboot a device (on the side of the device).
firo
Sep 16, 2008 | Mitac Mio 168 Pocket PC
Mitac Mio DigiWalker 168, Pocket PC PDA w/ GPS
mijn probleem is dat ik deze pc/pda in het nederlands wil zetten hoe doe ik dat
Sep 09, 2008 | Mitac Mio 168RS GPS Receiver
Black screen
This problem has happened to me before turn the gps unit over and clean off the gold colored conductors on the bottom take a paper clip and touch the 1st and 4th pins together this resets the unit be sure it is the 1st and 4th pins on the opposite side of the little power connector though.
Jun 26, 2008 | Mitac Mio C320 Car GPS Receiver
Blank scren
That because your PPC don' have a CMOS. Solution is a Jtag flashing.
Jun 30, 2007 | Mitac Mio 168 Pocket PC
Mitac Mio C210 GPS Receiver Logo
251 people viewed this question
Top Mitac GPS Experts
gerry bissi
Marvin
Marvin
Computer Links
Are you a Mitac GPS Expert? Answer questions, earn points and help others
