Question about Navman F20 GPS Receiver
European maps wont load
When I insert the SD card and start the F20 unit I can see the maps loading via the message bottom LH screen. When I try to recover the maps, the unit only displays options for the pre-loaded UK/Ireland set.
How can I check that the maps are correctly loaded? and How do I change the maps?
Thank you
D
    Genius:
  • 3,587 Answers
You'll need a mandatory firmware update
click here
Posted on Mar 15, 2008
I have inserted micro SD card for Europe but have no recognition on the 1490T. Do the European maps only appear when in Europe ?
When adding maps via the SD card slot they will automatically be activated, to see this go to Tools > System > Maps > "Map Info" from here you will be able to see what mapping you have on your unit.
Hope this helps!
Apr 06, 2011 | Garmin nuvi 1490T GPS Receiver
I cannot locate topo maps loaded via sd card
If you have the TOPO maps loaded to an SD card and the card is inserted all you should have to do is go to Tools > Settings > Map > Info in this menu you will find your map sets if you see TOPO make sure it is activated if not you may need to re install them to the SD.
Hope this helps!
Feb 12, 2011 | Garmin nuvi 1490T GPS Receiver
When I turn on my nuvi 200 I get the message "no
If you got the unit from somebody they could of used a SD card and its looking for it and the ynever switched back to the regular map... to check try this..
Settings ... Map.... on he bottom of screen you will see Map Info .. press it.... it should now say what map is loaded on the gps...
It should have a checkmark in the City Navigator North American NT, if not put one there
Nov 04, 2010 | Garmin nuvi 200W GPS Receiver
Can SD Memory cards be used with my Go 720??
the "no SD required" is just letting you know that all of the important stuff to make the unit run is all on the hard drive of the unit itself. Yes you can use a SD card to hold maps, photos, or music. For instance if you were going to Europe, you will be able to get a European Map and download it onto the SD card. Another instance would be if you wanted to download some mp3 files.
Sep 28, 2009 | Tomtom GO 720 GPS Receiver
Message on screen "Insert a SD into slot...
Normally the sd card holds the programme and the maps so the satnav will not run without it. If it is already in place, take it out, wipe over the contacts with a dry cloth and reinsert it. If there is no sd card then it will not work-it has no programme.
Jun 11, 2009 | Navman F20 GPS Receiver
Tom tom Western european map
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card
  • Connect the device to your computer.
  • Open the TomTom Home application.
  • Click on 'Update My Device'.
This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you updat.
Feb 24, 2009 | Tomtom One XL GPS Receiver
European map
any SD card can be loaded with the map in a pc with a card reader,
SD cards start under $15.00
the map can be downloaded from the makers web site,
sometimes at a fee,
the site cant be determined because you did not state which GPS
Jul 04, 2008 | Shinco SDP-1850 Portable DVD Player
Loading European maps
sounds like a settings issue on the maps interface..you have a user guide?
Mar 17, 2008 | Navman F20 GPS Receiver
Garmin Streetpilot i3 GPS cannot load map to memory card
A way around this is to insert the SD Card into the computer (SD Card reader), point the directory to the card and install the maps like that. I had to do that the first time I bought my unit because I couldn't figure it out and got frustrated. So I thought of this easy work-around.
Dec 22, 2007 | Garmin iQue 3600 GPS Receiver
Nuvi 660 MapSource
Henry,
You cannot replace American maps with European maps.  Garmin does this in order to protect the European retailers.  The European SD card eliminates the need to load the maps into the 660, however, if you need to use the card slot to store extra data such as MP3s then you might be better off buying the 670.
Oct 28, 2007 | Garmin Nuvi 660 GPS Receiver
Navman F20 GPS Receiver Logo
328 people viewed this question
Top Navman GPS Experts
Marvin
Marvin
Jerry Greenberg
Jerry Greenberg
Are you a Navman GPS Expert? Answer questions, earn points and help others
