Dvd/cd problems I ran a disc clean up and since them my dvd/cd writer has failed to work. The drawer does open but nothing happens after a disc is incerted.
  • 54 Answers
Open the dvd/cd rom & manualy clean the lense, now check the Rom if again not function then change it, there is no option other.
Posted on Mar 08, 2008
A cd broke inside my dvd writer while using it, and now it wont eject
on the left side of the front pannel just under the drawer you will see a pinhole.turn your cd unit upside down and insert a straightened paperclip in the hole keeping it straight as possible,the drawer should open enough to allow you to grip it .
if no luck you will have to remove the case top and manually remove the disc..
hope this helps.....Len..
Jan 13, 2014 | Lite On Lite-On SHM-165H6S DVD+R/RW -R/RW...
My LG DVD Writer is not reading any disk when i am inserting the disk in Drive. IT stops blinking also.
Hello Ammit,
It seems that the lens of the DVD writer is not working properly. Please try to clean the lens of the DVD writer with help of CD/DVD lens cleaner disc. The lens cleaner disc is easily available in market. After cleaning the lens try to run the CD/DVD again
May 08, 2011 | LG (GSA-H42NK) Burner
My dvd writer (secure disc )not reading cd
It could be a problem withthe lens, you should try cleaning the lens, it's already gone bad there is noharm in trying If you take a little riskcan solve . follow the instruction: Don'tpanic its very simply.
  1. When running your pc , open the drawer.>
  2. switch off the ac power
  3. remove power cable & sata or pata cable
  4. remove all the screw from the back side
  5. press clip to open the font panel
  6. reverse the CD/DVD rw
  7. just remove the cover
  8. clean the optical lance
  9. http://www.howtodothings.com/computers/a3631-how-to-clean-a-cd-rom-drive.html
  10. use a little ( not much )oil place on two steel shaft
  11. cover all the equipment
  12. now you can fit to your PC
Ifit does the same problem please change the CD/DVD rw because the lance has defected. Hopeit will help you. Don't for gate to vote me.
Dec 25, 2010 | LG SecurDisc 20x Internal Double-Layer DVD...
My CD writer will not open to insert the CD. What
Look for the small hole on the faceplate of the CD or DVD drive. This is the manual release. Straighten the paperclip and insert it into the manual release hole until resistance is felt.
Once the resistance is felt, keep pushing the paper clip until the drawer opens a little.
Remove the paper clip and gently pull out the drawer until the disc is accessible.
Mar 08, 2010 | BUSlink (RW4848FM) CD-RW Burner
Dvd writer/cd writer combo on a compaq presario has jst stopped working. when i put a dvd or cd into the drive nothing at all happens other than the green light appears on the front of the cd driver. no on...
1st of all insert the correct cd or dvd without scratch and then check it otherwise open you pc case and check your id or sata cable correctly connected or change your id or sata cable
Nov 18, 2009 | Video Game Consoles & Games
Hp dvd/rw does not read discs
If the CD or DVD disks you inserted work in some other reader, then your reader is the problem -- even though it is properly connected to your computer, and Windows has the correct device-drivers, it is the "hardware" that is the problem.
When you insert a disk, rotate it to some position, i.e., top-lettering goes in first, and close the drawer. Do you hear the drive start to spin the disk? Open the drawer. Is the disk in the same (non-rotated) position? If so, then the motor that spins the disk is the problem. If the disk does spin, but nothing happens, then it is the "laser" part of the mechanics that is not working.
Replace it.
Apr 21, 2009 | LG GSA-H55N DVD-RAM Burner
DVD had a jammed disc. Got it out but drawer stays open
You broke it. Spend $30 to buy a new CD/DVD reader/writer.
Dec 21, 2008 | Compaq (224130-001) Internal 4x CD-ROM...
Dvd cd rom not reading anything on my Dell computer
Having to use a paper clip instead of the eject button working could indicate a power source problem. Not reading anything on the drive could be either power source, connection cable or motherboard. I would start by removing the drive and checking all connections. You did not state if this is a laptop or desktop. If it is a desktop, there should be several unused power connections.If you do not have the ability to check the used connection, just switch to a different one.Also check the connection cable to the motherboard and if possible change or replace that. If all this fails, I would assume from a distance that the DVD drive is defective and try to replace it.
Dec 17, 2008 | Dell DVD-ROM for Dimension (6t903)...
Won't recognize disc-cd or dvd
The pick up or in other terms laser is faulty if its not under garrentee start by opening the tray and clip of the tray`s cover open the writer and clean the lense with a ear bud and then test it if no response it gets more technical or its time to replace, i hope these tip help you
:)craig
Jan 09, 2008 | LaCie 300722 DVD±RW Burner
Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
Computers & Internet Logo
55 people viewed this question
Alun Cox
David Payne
David Payne
