Question about Sony FD Trinitron WEGA KV-32FQ70 32" TV
KV-F29MH31 THE TV GOING ON OFF AND SHOW A HORIZONTAL LINE ONLY VERTICAL PROMBLEM!
  • 1 more comment
  • TASSOS Mar 11, 2008
    jjjjjjjjjjjjjjjjjjjjjj
  • TASSOS Apr 21, 2008
    I have change the stv 9379 and i test the vertical circuit but i dont find the promblem
    The voltages are ok.,and the YOKE
  • 2,326 Answers
If you already replace the vertical amplifier IC. I would suggest to measure if the voltage is getting all the way to the IC.
Next will be to check the YOKE for proper functionality.
Let me know if you need further assistance.
Posted on Apr 21, 2008
  • Jaime Hernandez Apr 21, 2008
    Check Q5404 and any other parts associated with the vertical section of the TV. I would suggest to also check the vertical drive circuitry if you have the service manual.
    Guru:
  • 1,894 Answers
Horizontal IC problem
just replace it sir
  • dewan nafees ahmed Apr 21, 2008
    horizontal IC the probelm sor sure.
Have lines up and down screen
If your lines are vertical, you have horizontal problem. Vertical lines are a result of an aging TV. It would not be feasible to repair this. There has been an overworked Flyback transformer, Horizontal transistor and regulator and an aging picture tube. It is time to find another TV.
Sep 27, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Turned tv on - picture came on for a moment - then horizontal lines - then went black - had sound
You must resolder the vertical IC on this unit. You will find the pins are separated from the TV board. Look very close, and you will find rings around the Vertical IC pins. A very common problem with this model! Thanks for asking and show a few hands of support.
Dec 13, 2010 | Sony KV-32S42 32" TV
6 horizontal lines
I would look for a Vertical circuit failure. Most likely is the vertical output IC and or open resistor off the hv transformer. Definitely look for any loose solder connections around the Vertical output IC.
Hope this helps,
Skyassoc
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-27FS200 bright horizontal line problem
try to replace all filter capacitor on vertical section area that can solve your problem.
Mar 07, 2009 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Sony KV-27S10
is it vertical problem or retrace lines can you tell
Aug 06, 2008 | Sony KV-27S10 27" TV
Sony tv model no. KV - 19 APR 2
This is for a different model, but I had thin horizontal lines in red and had to adjust the tube for red. You may have a similar adjustment on your set.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Aug 01, 2008 | Sony KP-48V80 48" Rear Projection...
Green lines
Due to vertical section failure horizontal line apprears. You did not mention about picture. Green horizontal line means with picture or without picture. With picture means there is some leakage. Without picture only singe horizontal line means vertical section totally not working. Particularly green horizontal line means maybe leads to jungle ic failure. Please mention your simptom clearly what you get and what you will not get both video and audio. It will be helpful to answer. Based on your question this is my small information.
May 24, 2008 | Sony KV-35S42 35" TV
Sony tv there is sound but no picture only horizontal line
hi there, one horizontal line means a vertical section prob., check some resistor with low value and a defective diode, possible ic part is defective. do some test and check up. ty
Feb 25, 2008 | Sharp 27C-240 27" TV
Picture broken and shrinking
You need to change your vertical IC, along with some capacitors around the vertical IC. Capacitor with value 220UF, 10uf, 470uf and finally 1000uf. Doing this will fix the set. Total cost under $40
Best regards
Circuitcity
Nov 29, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony FD Trinitron WEGA KV-32FQ70 32" TV Logo
71 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
