Beko 520w wasing machine
Switch on, machine lights start/ready/spin then a humming sound and nothing happens wont respond to pause etc.
  • Anonymous Mar 13, 2014
    it is a new machine. I plug in but nothing happens. Tried the safety switch and followed instructions etc.
  • Washing Mach... Master
  • 744 Answers
Hi see the last video on this it will show you test mode or if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Posted on Feb 14, 2015
  • 96 Answers
Humming sound at start usually means a door lock problem. Check that the door is actually locking.
Posted on Mar 10, 2008
My washing machine was switched off mid cycle. Now the start/pause, ready, wash & spin/end buttons are lit up. I have switched it on and off from the mains. No change. It is a beko wm6123w. Please help
Try looking in the troubleshooting section of the products user guide/instruction manual, if you have lost this, you can normally download a copy from the manufacturers (beko) website, this is normally located in the support section of the websites.
have you tried pressing the start/stop button as the cycle maybe simply paused.
WM6123 Washing Machines Beko
Jul 04, 2014 | Washing Machines
Water control valve washer
Hi carl if your Beko WM5140W washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Mar 11, 2014 | Beko WM5140W
My beko wma620a wont start the ready light is on but nothing happening?
It ispossible that the machine does not start off the cycle because there are errorsdue to feedback from the inputs. For the program to start up the main programcontroller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting fromthe flow of water into the drum as also the drain valve to open to exit thewater at the point of the program cycle. If this does not happen then thevoltage at the valve/motor/pump must be checked or the fault relates to novoltage from the controller. This meansthe controller is a suspect.If thewater flows then the flow should be good, if not the inlet valve is bad orthere is dirt in the filter. Also check the flow at the inlet of the waterline. Once the water comes into the system the WATER LEVEL SENSOR - normally apressure switch- must activate at the preset/chosen level to give the signal tothe program controller to switch on the motor. What is most important for themotor to start functioning is that the door switch must be ON when the door isshut or this will be an error for starting the motor for rinse and wash.Check thislink to replace the inlet valve:http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html Finallyafter the wash the drain valve will be activated, the water is allowed to comein to rinse and then finally the dry spin with the drain valve/pump activatedso as to drain off all the water from the clothes during the spin.Make surethat a fault in any of the cycle will relate to the specified action, so checkthe command from the program module and then the executing device be it thevalve or motor or pump. Please check the link below:http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jul 05, 2012 | Beko Washing Machines
I have a BEKO WMA 520W machine and when I turn it on it switches to wash mode, the drum fills with water and then spins once. After a short while it spins once, pauses, and spins once again. This...
I am having the same fault, please let me know if you find the cause and i shall do the same. having no luck online so may have to get a 'man' out!
Aug 24, 2010 | Washing Machines
Beko Washing Machine starts program, spins once then stops..
this is joyce
Go to the webb and download a manual to your washing machine if you are going to work on it yourself but if not I would suggest you call a techn. to look at it, sounds like problems.
thanks,
joyce
Feb 06, 2009 | Washing Machines
I have a Beko AA class WMA 520W washing machine and it won't wash, when i put it on a wash cycle it will fill up wash for about 7 mins then drain, neither will it spin unless i actually turn the dial to...
Had the same problem this week. i bought the machine of a mate and was ready for kicking his head in, but thankfully before then i found that this method resets the washer, hope it works for you also
Turn power button off (not at wall)
Select 90 degree wash
Press Start / Cancel button down for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start /Cancel button again for 3 seconds.
Machine should be re-set ready for use
Oct 19, 2008 | Washing Machines
Beko WMA 1715s - won't respond
door lock switch could be your problem..
Aug 30, 2008 | Whirlpool LCR5232H Top Load Washer
Washing Machines Logo
344 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
