Question about Epson ACULASER CX11NF All-In-One Printer
Copies and prints but won't scan
When running Epson Scan on its own or from within another programme such as Photoshop, I get the error "Epson Scan cannot be started". When running Epson Scan Settings, I get the error "Scanner is not ready".
If your scanner is on a wireless network, you will need to make sure the scanner address in epson scan settings matches the address your router has assinged to it. The DHCP address. Log on to your router by typing or some variation thereof into your window internet explorer address bar. or find out how to log on to your router via the manufacturer of the router. When you do that find the DHCP client list and see what address your router has assigned to your scanner. Once you have this address open epson scan settings and delete the current information there, then add a new scanner by manually entering the address you got from the router.
I have to do this all the time!!!
email me at if you want more help
Posted on Mar 10, 2008
Updated the drivers in Device Manager. For some reason they had been unistalled.
Posted on Mar 08, 2008
How do you scan a document using a pc?
The printer can be used for scanning without a computer in sense of the scanner offering a copying facility - in B+W or Colour just by pressing the appropriate button on the printer. However, for scanning via the computer, if you are using a Photo programme (like say Adobe Photoshop or virtually all such programmes) normally you will find under the FILE menu (when programme is open) that you should see a menu item on the drop down menu when you click on FILE something like IMPORT - and the Epson printer will be seen listed in the menu that pops up. If you click on that, the Epson scanner programme will start. Normally there is a simple mode but you can change that to the PRO (or may be called Advanced mode) when you can do things like PREVIEW - which will then scan the document or photo in the scanner - and you can in the PRO mode change such as the resolution, what type of documents and so forth. When the Preview runs, you will see the document appear after the quick scan in the main RH panel. You can use a select tool to select the bit you want to scan if not the whole - most into on this will be in their manual - which you should have on the CD that came with the printer. Anyway - always worth ensuring you have the latest drivers, etc. so go to this link on the Epson website, click on Scanner Driver and Scanner Utility and download and install. Whilst on the Epson website, download the manual for that model as it will answer many queries for you as regards printing and scanning. All such info and software for downloading is under SUPPORT area - you select the region in the World where you live, then search for your printer model. The Epson website will normally auto-detect your computer's operating system to ensure you get the right version of Printer Drivers, other software and so forth. If you have no Photo Programme as yet - get Faststone Image Viewer (free) as an excellent programme.
Jun 25, 2014 | Epson Stylus Multifunction Inkjet Printer/...
Epson scanner cannot communicate
My solution was that Epson Scan was set to connect via network instead of local. (All was working fine, then it quit-something changed this setting) Try this, go to start, choose all programs, choose Epson folder, choose Epson Scan, choose Epson Scan Setting. In the pop up box set the connection to local or network, whichever is appropriate. Close the window and open photoshop and all works fine. It could be that your problem is the opposite of mine- I try switching this to the other setting even if the change is wrong, then switch it back to see if that works too.
Good Luck.
Jan 05, 2013 | Epson WorkForce WF-7520 Wide Format...
My HP6110xi All-In-One doesn't want to scan
First, scans and copies don't really use the computer. Can you print a document from your printer. If not, then your problem is within the computer.
If it does print then....
Try using the scan feature within the HP solution center. It works on mine but the scan button on the printer does. Also some art programs have and "ACQUIRE" feature under file to scan with. (Sometimes called TWAIN.)
Hope this helps, so you can start scanning.
good luck
Feb 21, 2010 | HP OfficeJet 6110xi All-In-One Thermal...
Epson Perfection v200 stopped working on my imac
Try to scan using epson scan to isolate the issue. You can launch epson scan from applications. If you can scan using epson scan, call adobe to troubleshoot further on photoshop.
If you get an error epson scan cannot be started or if it won't launch. It could be connection or driver issue.
To uninstall/re-install twain on mac, follow the instructions:
- go to applications. Trash epson scan and epson scanner monitor
- Go to library then application support. Trash epson scanner module.
- Go to library then image capture. Trash twain data sources.
- Go to the hard drive. Click on user. Click on the name of your computer. Click on library. Click on preferences. Click on epson. Trash epson scan.
- Empty the trash.
- Restart your mac.
- Log on to Type in v200 in the search box on the top right corner of the page then click search. click on the first search result. Click on the drop down box and select macintosh operating system instead of windows. click on the second driver down, epson12527.dmg then click on download now. Select no thanks, i prefer not to receive this information then click accept. Install the epson scan installer after the download.
- Then try to scan using epson scan.
If epson scan won't launch or you get an error, try a different usb cable.
sherlyn c.
P { font-family : Verdana, Geneva, Arial, Helvetica, sans-serif; font-size : 10px; } .boldBlue { color : #2A57A5; font-weight : bold; } .qatable { width : 390px; } P { font-family : Verdana, Geneva, Arial, Helvetica, sans-serif; font-size : 10px; } .boldBlue { color : #2A57A5; font-weight : bold; } .qatable { width : 390px; } P { font-family : Verdana, Geneva, Arial, Helvetica, sans-serif; font-size : 10px; } .boldBlue { color : #2A57A5; font-weight : bold; } .qatable { width : 390px; }
May 21, 2009 | Epson Perfection V200 Flatbed Scanner
Our Epson Scanners do not work from Photoshop CS4
Try using a separate scanner utility to do yr scans - not ideal but sorted my problem. I use the EPSOM scan utility with a Perfection 2400 scanner.
Apr 17, 2009 | Epson Expression 1640XL Pro Flatbed...
Scan functionality problems.
I have a problem error 90 for Epson stylus CX6000 All-in-one Printer
Sep 18, 2008 | Epson Stylus CX6000 All-In-One InkJet...
Epson stylus photo rx510,after replacing ink cartridge screen keeps saying "error must replace light cyan"
My rx512 when it copies the copies come out light. Any ideas?
It prints ok. Also when you scan to pc info box comes up and says old version of twain . where do you get update.
Aug 30, 2008 | Office Equipment & Supplies
simple go to photoshop
in file menu import and go to scanner
then scan and thats all.
Apr 03, 2008 | Epson Stylus DX6050 All-In-One InkJet...
Microsft Vista doesn't support 4990 negaives scanning
trash and reinstall the epson scan software and download latest driver for your devices use this link and download drivers for win vista.
Apr 01, 2008 | Epson Stylus RX425 Multifunction...
Epson ACULASER CX11NF All-In-One Printer Logo
305 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
