Question about Xerox Phaser 8550DP Printer
PHASER 8550DP Hi, my printer advised me that ink sticks were jammed. We removed them and restarted and now it says PRINTER ERROR code 09 037 45. Can anyone help? Otherwise we have to scap a low use machine, also I understand it needs to be reset, any ideas? Thanks Juliet
  • princess234 Mar 11, 2008
    Thanks I will try that.
    Many thanks Juliet
    President:
  • 2,072 Answers
Your yellow ink sensor is stuck
Testing the Ink Out Sensors Use this procedure to test if an Ink Out Sensor?s flag works correctly.
1. Remove ink sticks from the ink loader?s channels.
2. Place the printer in Diagnostics Mode by:
Service method
a. Turning on the printer and as XEROX appears on the screen, press and hold the Back and Help button until Beginning Service Mode Initialization appears.
b. Scroll to and execute test Monitor: Sensors
Customer method
a. While error code displayed, press UP arrow and OK key.
b. Scroll to Troubleshooting: Service Tools: Enter Diagnostic Mode. (Printer restarts).
c. Select test 82: Monitor Sensors. Press OK.
d. Scroll to 01: Exit Diagnostics and press OK to return to customer mode.
3. Insert the clean eraser end of a pencil thru the lowermost oval slot. (The eraser end of a pencil closely simulates the bottom rail shape of a Xerox ink stick.)
Slide the pencil down the white channel guide until the sensor is tripped. A sensor change is displayed on the control panel. When the flag is depressed, the front panel will read <color> Ink Present H. When released, the reading will change to L. The test will only display a reading when a sensor change occurs. If a flag is stuck, no sensor reading will be displayed on the front panel. If it doesnt change states you need to replace the ink loader
Posted on Mar 08, 2008
Error code 09038.46:72241
That code is a back stick count failure.
You want to look in your ink loader, see if there is a stick jammed, twisted, broken or in anyother way out of place or hung up in the slot.
Be sure you loaded a 8550 stick also, since the shapes on the different phaser printer sticks are all different.
You may have to carefully remove the black sticks and reload them. You can take a screw and screw it into the ink stick, slide it back and remove.
Most likely you will find a gap in the ink sticks causing the problem. Here are the Xerox support page instructions.
  1. Open and close the Top Cover to resolve the problem.
  2. If the problem persists, arrange the ink sticks until there are no spaces between sticks of the same color.
  3. Check for non 8500/8550 ink sticks jammed in the ink load chutes. If non 8500/8550 ink sticks, whether manufactured by Xerox or by a non-Xerox ink vendor, caused the ink sick jam, contact support to place a service call.
Mar 09, 2010 | Xerox Phaser 8560MFP Laser Printer
System Error code 09 038 46 24363
09,03x
35 = Cyan
36 = Magenta
37 = Yellow
38 = Black
The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error.
Turn off the printer.
Turn on the printer.
As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display.
Release the buttons, it will now come up in the service mode.
Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok.
Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Jun 09, 2009 | Xerox Phaser 8560MFP Laser Printer
Phaser 8560 Error Code 09,005.40.5185
Hi mark711:
Here is you problem.
9,005.49: Ink loader fault. The cyan ink melt heater is on, but the ink does not
appear to be dripping.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Are the ink sticks all Xerox ink? Go to
Step 2.
Advise
customer. Run
clearISCfault
test to clear the
error.
2 1. Manually verify that the ink stick is able to
advance in the ink loader chute.
Go to
Step 3.
Remove any
blockage and/
or replace the
ink stick.Run
clearISCfault
test to clear the
error.
3 1. Run the appropriate Ink Melt [1, 2, 3, 4]
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
2. Did the test pass?
Replace
the
printhead.
Replace the ink
loader
assembly. Run
clearISCfault
test to clear the error.
Hope this helps
Apr 23, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8550 printer error 09,037,45:23780
This means the Yellow ink sticks are jammed in the machine, open up the top of the machine and check if the sticks can slide freely up and down and remove any broken sticks.
Niallbt
Mar 31, 2009 | Xerox Phaser 8550DP Printer
Printer Error 09,037,45:41334
That code means one of your ink sticks is stuck and not advancing all the way down into the ink loader. Open the area where you load the ink, see if one of the sticks is obviously twisted, cracked or just stuck and not moving down into the loader. If you have to remove them, the best way I found is to take a screw, Like a dry wall screw, twist it into the ink block and back it out. Then reload the ink. That should resolve the issue. But that code means the machine did not detect that one of the ink sticks did not advance in the loader.
Mar 18, 2009 | Xerox Phaser 8500/DN Printer
ERROR PROBLEM
Do not use the ink sticks if they have a hairline crack in them. They eventually crack and jam the printer. So far I've only noticed this with the black ink sticks. 5a7294b.jpg
Jan 21, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8500N Printer Error 09,037.45:9085
Hi Signrite: This should help out. It looks like you are having a problem with yellow.If you are using a third party ink (non Xerox) then you may be having a printhead.
9,035.4x through 9, 038:
Fault codes associated when ink count flags are stuck
after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41, where x= 5
for cyan, 6 for magenta, 7 for yellow, and 8 for black.
1 1.
Step 2.
Advise
customer. Run
clearISCfault
test to clear the
error.
Go to
Step 3.
Remove any
blockage and/
or replace the
ink stick.Run
clearISCfault
test to clear the
error.
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
Replace
the
printhead.
Replace the ink
loader
assembly. Run
clearISCfault
test to clear the
error
Nov 24, 2008 | Xerox Phaser 8500N Printer
That is a yellow ink stick fault.
One is most likely stuck. cracked or otherwise not advance to the front of the ink loader. Check the sticks
May 27, 2008 | Xerox Phaser 8500/DN Printer
Error Code 09,038.46:103468 help!
Mar 20, 2008 | Xerox Phaser 8550DX Laser Printer
Xerox Phaser 8550DP Printer does not recognize the ink it has
Nov 16, 2007 | Xerox Phaser 8550DP Printer
Xerox Phaser 8550DP Printer Logo
442 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
