Question about Zanussi ZI921 / 8FF Bottom Freezer Refrigerator
Zanussi Quattroporte Hello I have had my fridge freezer for about 6 years and it has been trouble free.....unfortunately I have lost the service books during several house moves.......suddenly on the control display panel a triangular red light with an exclamation mark is now flashing and the freezer seems to be making a 'roaring noise'....can you please advise....the freezer seems to be working properly and the fridge too.....hope you can help....kind regards Bunty Bradbury
5 Suggested Answers
SOURCE: Zanussi Electrolux frost free fridge/freezer - freezer defrosting
My husband left the freezer door open a couple of months ago, causing ice to form. The loud rattling noise was the fan hitting the ice. The reason why the temperature started to rise but the noise stopped was because the fan had got stuck in a block of ice and was no longer working. Simple solution - defrost the freezer for 24 hours. Touch wood, it is all working fine now!
Posted on Sep 01, 2008
SOURCE: fridge doesn't work but freezer does
i have had the same problem, it was the fan which needed to be replaced.
Posted on Oct 07, 2008
  • 242 Answers
SOURCE: Fridge on Fridge freezer not working
Ok there is a drain pan under the evap. coil under the fan that may be clogged and full of ice there is a 3/4" hole the water drains out of that needs cleared if there is a puddle of ice over it , the ice will also effect the airflow traveling down the duct to the fresh food section of the unit.
If there is no ice puddle at the bottom of the refrigerator then make sure the unit is cooling well by making sure it has been running for 10 min. or so and checking the coil in the freezer , it should have a small layer of frost on it showing its getting cold the whole way through it. Let me know how this works.
Posted on Jan 02, 2009
  • 219 Answers
SOURCE: Fridge on Zanussi ZX56SI has stopped working but freezer fine
check in your frezzer on the back wall if its all frosted up u have a defrost problem u can unplug and let thaw fgor 4 or 5 hrs plug back in and wilkl work till u can have it serviced if no frost u might a bad fan or a damper control
Posted on Mar 19, 2009
I have Zanussi Frost free fridge freezer 3 years old. Bottom of freezer compartment below shelf is filling up with ice. The freezer appears very cold. The fridge seems less cold.
There is a timer which defrosts fridge daily . Put on manual . replace switch . check door closing , defrost , check defrost element .
Apr 08, 2014 | Refrigerators
Trouble with my Samsung RSH1NHMH fridge freezer
I have a Samsung RSH1NHMH fridge freezer unfortunately the fridge part will now only go down to around 6,7 degrees we have defrosted the unit but this has had no affect can you help.
Regards Sean
Aug 27, 2009 | Samsung Refrigerators
Fridge freezer
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Sep 23, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Fridge doesn't work but freezer does
Aug 30, 2008 | Zanussi ZEBF277W Bottom Freezer...
I have an unexplained smelly zanussi fridge/freezer model Model zx99/5si? I have a zanussi frost free fridge/freezer model Model zx99/5si which is just 4 years old and it is now giving off a revolting...
Hi - we had this problem, and it was in fact where some blood from a defrosting pice of meat drained into the compressor condensation tank and began to decay!
I agree the smell is terrible, so a good clean up is needed but this solves the problem immediately!
Kind regards,
Aug 14, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
The freezer is working but the the fridge
same here. have the znb 4051s refridgerator. freezer works fine but fridge does not. there is no sound eminating from the fridge either...any ideas? its 1 year old!
Apr 13, 2008 | Zanussi ZEBF277W Bottom Freezer...
I have a zanussu fridge
Re. Zanussi ZK87/46EFS Fridge Freezer
The same symptom occurred in our fridge freezer. The fridge compartment warmed up whilst the freezer compartment continued to keep temperature.
The cause of our problem was diagnosed as a frozen sensor that controls a flap, that controls the flow of cold air from the freezer compartment up into the fridge compartment. We were advised to power off the fridge freezer (removing all food and trays from the freezer unit first), and to leave it to defrost for 24hrs. We needed to place a few towels on the floor of the freezer compartment to soak up the melt water. After 24hrs we followed the power up instructions in the manual (versions are available online if you have lost yours). Within a few minutes it was obvious that the fridge compartment was being cooled – Problem solved :)
Apr 13, 2008 | Zanussi Refrigerators
Zanussi frost free fridge freezer
if problem happens every fewhours it is possibly the defrost element
Mar 20, 2007 | Zanussi ZEBF277W Bottom Freezer...
Zanussi ZI921 / 8FF Bottom Freezer Refrigerator Logo
117 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
