Question about Panasonic Televison & Video
Set up new panasonic th-37px80b tv last night. Its connected to a v box via scart and hdmi and dvd player via scart. It is not connected to an aerial so only watch tv via the cable box. The problem is I have a messgae reading CHK D: 44 DB moving up and down on the right hand side of the screen which I can't get to disappear. Only if I press subtitle button on remote does it go but then I get subtitles on. How can i get rid of the chk message.
The set is in the service mode. TO EXIT THE SERVICE MODE PRESS VOLUME DOWN ON THE SET AND THE OK BUTTON ON THE REMOTE F0R 3 SECONDS.WHEN SELF CHECK SCREEN APPEARS UNPLUG THE UNIT. Solution found on Fixya by QTV1 posted on Nov 20, 2007
Posted on Mar 08, 2008
How to besto connect this unit to record from Sky plus box
SCART from Sky box to SCART input on Pana. SCART out from Pana to TV to monitor results. The Pana SCARTs should be marked, one for external source such as Sky box, one for TV
Oct 26, 2013 | Panasonic DMR-E65 DVD Recorder
No audio input from TV on DVD Home Theatre
U have audio signal incompatibility. If the audio output is digital it may not work with an analog input, etc.
May 08, 2017 | Audio Players & Recorders
HDMI STOPPED WORKING PANASONIC TH-42PV500B
I had a same issue with my Panasonic TH-42PV500B plasma television. I tried everything which is written above and can be found on different websites. Finally I decided to replace the HDMI Board itself. I was able to buy a used one on ebay, it was only 13 pounds with postage.It is relatively easy to remove this HDMI Board. You should just unplug the TV and remove all of the screws form the back which are fixing the back of the TV to the frame. There are plenty of screws. You should remove all of them! Remove the backplate of the TV. After this you can remove another metal plate from inside, which covers this HDMI board - 4 screws. After you can remove the HDMI Board - only one screw holding it to the main board. Replace the new one back and put back the cover plate and the back of the TV. And it is working. 10_19_2012_3_10_22_pm.png Panasonic 42 Plasma TV TH-42PV500B Part HDMI Board Order number: TNPA3626
Apr 11, 2012 | Panasonic Televison & Video
TH-37PE30 - DVD picture now lousy (herringbone?)
Do you have an S Video cable connection on the DVD player? I'd try that If you have one or component (red green blue) cable or even the composite (yellow) connection. The SCART connection on the input PCB of the tv could be damaged. The cost of this board may be pricey so if you can use the other type of connections with the DVD player I'd recommend that or get a DVD player that has one of those. Your model does not have HDMI so those are your only other options. Hope this helped
Feb 08, 2010 | Panasonic TH-37PE30 37 in. Plasma...
I want to connect a Virgin HD box to my Panasonic TH-42PV500B TV currently connected to a Panasoniv DVD recorder On Scart AV1. How do I switch between Virgin and existing equipment which I would like to...
what you need to do is obtain an HDMI cable for your Virgin HD box. Leave the rest on scart (you can probably even add a another box now that you've freed up one port). Basically just press the button on your TV remote, saying 'Source' and you can flick through all your scart soxkets and HDMI ports. Simples.
Oct 24, 2009 | Panasonic Televison & Video
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
Sound but no picture
Your player has several outputs and you might want to start with the basic Video Audo Left Right output first.
Set your with your plazma to see if you can change the input types to accept the video and audio input which will probably be labeled AV 1, AV 2 and so on.
My guess is that you have it set for Component Red Blue Green which his a high def (just before HTMI) and requires a separate audio cable. Your player, depending on the age of the unit, probably will not have Red Blue Green picture output.
Next if you have an HTMI output from your player hook that to your Plazma in the HDMI 1 position and select it on the TV's setting. Audio and Video are both carried in the HDMI cable.
Good luck, my name is Eric Kirkhuff
Feb 23, 2009 | Toshiba D-VR4 DVD Recorder/VCR
Hdmi connection
you need to connect to your tv via scart untill you have been into the setup and enabled hdmi
Dec 29, 2007 | Panasonic DMR-E80H DVD Recorder
Vhs dvd combi panasonic dmr ez47
If you select the HDMI channel to watch a dvd does it do it then, if not disconnect both ends of the scart lead and reconnect or replace. If the scart lead is not in properly this could happen, when you switch on the player and play a disc your tv will automatically switch to the AV/Scart channel, but you are better off manually turning the TV over to the HDMI Hi-Def channel for DVD.
Dec 24, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
80 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
