Question about Electronics - Others
Driver whenever i insert my USB pen drive in the port at any computer it says "hardware not recgnised".Please tell how can i access inside the pen drive
  • Anonymous Mar 19, 2014
    when pen drive is inserted the display distracted or the computer restarted
  • 75 Answers
Try with reinstalling usb driver by your mother board cd,and install chipset INF,
check in other pc to check weather your pendrive got faulty
regards
prasanna
Posted on Mar 08, 2008
I have kingston 2GB pen drive. when i insert this its shown found new hardware yyyyyyyyyyyyyyyyyy............yyyyyyyyyyy USB device when i click on it its gone for driver installation. when i click for...
These kingston pen drives should load without having to find a driver on anything newer than xp and up. try it in a different port on the rear of your machine if possible and make sure you fully seat the stick into the usb port, as this will sometimes cause this problem. once inserted you should be able to browse the kingston drive on "my computer". if not look for a damaged socket or try the key in another computer to verify if it works properly
Aug 29, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
PEN DRIVE NOT OPEN
what problem you are facing with your pen drive? are any error message you are getting when you try to open your pen drive? please send us your problem in details.
Apr 13, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Whenever I insert my pen drive into my pc,it restarts computer. what is the problem ?
if this is only happening on 1 usb port, there is a short in that port that is causing you PC to shut down. Your motherboard BIOS is probably set to reboot on power loss which means it will boot right back up if it shorts out.
If it happens on every USB port then your pen drive is faulty and I would refrain from inserting it anymore before you damage your hardware.
If the pen drive works on someone elses computer, then it sounds like the SOUTHBRIDGE chip (chip on motherboard that controls USB, PCI slots, firewire ports, etc) is going bad or is faulty.
Oct 01, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sandisk 8gb pendrive not detected
You can try using another usb port, or it might be that other things conncected to the usb are interfering with it. Try disconnecting things attatched to other usb ports (check in the back of the computer) but be sure that they're not important before you go ripping out cords.
Aug 21, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Pen drive is not detected by the Pc
go to my computer property then hardware then device manager then uninstall usb drivers then right click any driver and clik on scan for hardware then it install automatic usb drivers.
then restart computer then connect pen drive to computer then check if still face problem try all usb port of computer.
also check your usb port of computer are working fine.
Thanks for using fixya.
Please rate solution if it helps you.
Jul 23, 2009 | Electronics - Others
Pen drive not getting detected? how to work it?
first go to my computer propery then hardware then device manager then go t ousb controller uninstall all usb drivers from there then just right click on any driver then click on scan for hardware changes then it automatic install usb drivers .
Connectyour pen drive to usb port check all port.
then if its not working check with other usb device is working with usb port?
Jul 15, 2009 | Iomega REV ATAPI HDR B/U KIT CA 6 REV...
How to install drivers of pen drive
your pen drive is not recognize by the usb port onyour computer, remove the pen drive from the port and insert it to another usb port on your computer, if you still having problems, restart the computer and try again on a different port.
USB drives do not drivers for it to work.
Jul 03, 2009 | SanDisk 8GB microSDHC Memory Card with...
Pendrive is detecting but not showing in my computer
when i plug my pen drive into usb port then usb mass storage show my pen drive without any drive letter like (F:). please help to save my pen drive
i am very thankful to all you
Feb 23, 2009 | Pen Drive IVO MP3 Player
Pen drive not showing in my explorer.
Its a common problem with the pendrive, in windows. some time it doesnot detect or not showing clearly that device. you have to check your pendrive manufacturer and driver details. and also check it out driver signing.
Do you have mapped network drives on your computer? If you have this may cause your problem. When you insert the PEN Drive into USB and the "safely remove hardware" icon appers try to right-click on it and choose "eject" or "remove" (don't remember :), then pull the PEN DRIVE from the USB and connect it again. Go to Windows Explorer and try to open all your mapped drives, then the content of your PEN DRIVE must be loaded into your Windows Explorer. This is happened sometimes, because PEN DRIVE try to assign the first free drive letter after your phisical drive letters, and if you have a mapped drive letter, the PEN DRIVE assign one of them.
Jul 22, 2008 | Microsoft Windows XP Professional With...
My pen drive get detected and when click to open it shows the message: " PLEASE INSERT THE DISK INTO DRIVE I"
my pen drive get detected but i am not able to format and copy things to my pen drive
Mar 26, 2008 | Pen Drive IVO MP3 Player
Electronics - Others Logo
49 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
