Question about Kodak EasyShare Z700 Digital Camera
Kodak Z700 not firing up
Kodak Easyshare Z700 - batteries are fully charged, but the camera switches on and then turns off - the screen for setting the Date and Time briefly shows. Camera doesn't show when connected to the PC via USB cable.
  • 3 more comments
  • daisybev7 Jul 22, 2008
    My camera doesn't turn on either. At first it happened slowly,
    batteries would last for shorter amounts of time. Eventually it
    just wouldn't turn on. I tried to remove the memory card and bend
    the battery connectors, but neither worked.
  • Anonymous Aug 06, 2008
    turn on and goes red off
  • mcrbradley Oct 20, 2008
    Tried a new battery, bending the connectors and taking out the memory card as suggested - nothing works.
  • dkrk819 Mar 22, 2009
    It will turn on but when I try to move it to other settings, it shuts off but does not close down. When I put setting all the way back to off, it does not operate until I then move it to auto again. Once it is on auto, the lens closes up, then opens again. I can't seem to take a picture on any of the SCN settings.
  • Anonymous Mar 21, 2014
    Camera is totally out. Cannot turn on at all.
When this first happened to mine, removing the memory card seemed to help. Later nothing.
What seems to work is bending the contacts on the battery compartment to fit tighter. (my camera has had a lot of use)
The older the camera gets, the more it seems to require very fresh batteries.
Posted on Jun 03, 2008
I have the same problem. Removing the memory card and then starting up seemed to fix it; the camera would then start up ok even with the card in.
Posted on Mar 11, 2008
    Problem Solver:
  • 5 Answers
Guest is right. Clean the contacts, bend the contacts with a small flat head screw driver upwards "GENTLY". This should work. Might have to repeat every couple of months. Forget regular batteries. Use the rechargeable ones. MUST be fully recharged.
Posted on Sep 24, 2008
I have a Kodak easy share Z700 that shuts down the minute you turn it on. It has fully charged lithium batteries. I have tried all of the solutions that I have read. Love this camera but is of no use now.
If your batteries are old, they may have lost their retaining power. Therefore, even if you recharge them fully, they will drain quickly.
Try using new batteries and let us know if the problem is not solved.
Sep 15, 2011 | Kodak EasyShare Z700 Digital Camera
Sound on the zoomlens and writing error # 45
To remove the error, follow the instruction.
1) Turn OFF the camera.
2) Remove the memory card from your camera.
3) Reinsert the memory card, then push down on the card until you hear a click. check the memory card is firmly fitted in your camera.
4) Turn on your camera.
This will clear the error. For noise install a fully charged battery or new battery in your camera.
Rating the solution in highly appreciated.. Good Luck
Mar 02, 2010 | Kodak EasyShare Z700 Digital Camera
When I turn my camera on it stays on for a few seconds and then shuts itself off. I even put brand new batteries in it and it does the same thing
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 14, 2010 | Kodak EasyShare Z700 Digital Camera
Kodak easyshare M893 IS will not stay on. The battery has been charged and replaced, however, when the camera is turned on the green light comes on, the "Kodak EasyShare" screen appears for a second or...
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 23, 2009 | Kodak EasyShare M853 Digital Camera
I go to turn my kodak easyshare m856 on and it shows the kodak logo and music and then goes to a black screen
Here are the steps:
If issue persists, call 1.800.235.6325 for repair.
Thanks.
Neerak21
Sep 29, 2009 | Kodak EasyShare M853 Digital Camera
Kodak 10.3 camera lance wont fully extend when
Here are the steps:
clean cloth.
Thanks.
Neerak21
Sep 25, 2009 | Kodak EASYSHARE M1063 Digital Camera
Same problem as described above. Fresh batteries, turn it on, see the Kodak screen for a second, then it just turns off. I found that if you swith it to the favorites icon (the only one below the Off position) it stays on and I can review photos. But no taking new photos! Help!!!
May 28, 2009 | Kodak EasyShare Z700 Digital Camera
MY KODAK CAMERA WON'T FLASH WHEN IT IS SET ON THAT!
As a first step, make sure the batteries are fully charged and check in the Shooting menu if you have switched the flash to 'off' mode. Then check the shooting mode. In some shooting modes (like landscape), some cameras do not fire the flash. To check if the flash is working properly, change the mode to 'Night Portrait' and try to shoot. This mode is sure to fire the flash if everything is well with the camera. If still the flash is not working, take it to the nearest authorized service center.
Jan 28, 2009 | Kodak EasyShare One Digital Camera
Kodak Easyshare Z700 Camera
You will probably have to send it in for repair.
Jan 14, 2008 | Kodak EasyShare DX6490 Digital Camera
Kodak EasyShare Z700 Digital Camera Logo
338 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
