Question about Dyson Flowcheck CRO1 Front Load Washer
Machine saying close outer door but its closed
Dyson came out on wednesday and charged £95.00 to put a new door catch on the outer door because it had broke. ive since done 3 loads of washing and its now saying close outer door but its closed and nothing seems broken. i have rang dyson and they wont be able to come out till the end of next week and i desperatly need it?
  • KANDTRSLY Jun 22, 2008
    We managed to replace our inner door handle on our own and this worked fine for months.
    It has just now started saying 'Close Outer door' when we have tried to start a wash even though the door is closed.
    When we fool the system by manually depressing the sensor for the Outer Door so it is fooled into thinking it is closed we then get an error message saying that the inner door needs to be closed.
  • conaty Jun 30, 2008
    I close the outer door and press start and the machine responds with close the outer door
I'm not an washing machine engineer but I do tend to do all my own home repairs - had to fix this fault this morning,
Quite easy to fix as long as there are no broken parts in the interlock and the solenoid isn't jammed.
UNPLUG FROM MAINS
Remove the top - 2 Philips or flat blade screws - pull backwards.
Remove front door - large flat blade inserted into gap in lower door hinge at back and gently twist to widen gap while pulling the door forward at bottom.
Remove 4 torx type screws (not sure what size) and 2 long torx screws from behind the hinge.
You may want to remove the coin trap door now - it makes the job of removal and refitting the front panel easier. Remember to put a tray underneath!
Unplug the ribbon connector for the front panel from it's socket and the clips - unplug the little pipe from the middle of the front panel.
Gently lift the front cover pulling the bottom edge forward a bit to ease removal. It is not necessary to fully remove the front panel so you can leave the mains switch connected.
Unhook the emergency release strap from the pivot arm.
2 Torx Screws above and below the door latch hole secure the latch assembly. Unplug the latch from a socket past the little foam block on the front - just inside the machine.
You now have the latch. Operation is quite obvious. The door loop pushes an angled plate that swings a hook into the loop. The solenoid when activated pushes a bar down to lock the hook in place and push down on 2 micro switches wired in series as the interlock.
To strip down the assembly unplug the micro switch plugs and push a small screwdriver into the top and bottom catches.
You can now lubricate the latch and check the function of the micro switches using a meter. They a easily replaced if you can find the correct type. (Unofficially - for a home repair - if one is not working you could always bypass one - but I wouldn't condone that obviously)
If you are careful enough - the operation of the solenoid and latch can be checked and observed by plugging the unit back in and pushing the door loop into the latch - be careful of the exposed wires etc - not sure what voltages are there!!
If it's unservicable then a replacement is about £35 online.
Reassemble in reverse - nothing to point out and is quite straghtforward. Dont forget the little pipe on the back of the control panel - it's easily missed.
Hope this helps.
Darren
Posted on May 31, 2010
  • 27 Answers
I have taken several machine to bits and repaired them
it sounds like the door interlock needs replacing
i had this problem and found the internal parts kept jamming
no parts available separately
will need to call dyson to fix or try ebay for spare parts
Posted on Nov 15, 2008
Hold down the Start button, temp button and the soil button all together this should clear the code.
Posted on Sep 22, 2008
    Problem Solver:
  • 12 Answers
It actually sounds like an error on dysons behalf something come loose.Let them fix there mistake.
Posted on Mar 10, 2008
Where to find a Dyson washing machine engineer in the Weston-super-Mare area?
Dyson no longer manufacture or supply the parts. Your only hope is to get a second hand part. Not hard to fix.
Apr 29, 2014 | Dyson Washing Machines
The programe wont stars
Dear Sir:
You must fit very well the door catch. The switch is the elements most important for to run the dishwasher. Otherwise you must waste your time.
See the diagram attached, and you will the switch door must be close for to close the starting relay for RUN the main motor.
sincerely. God bless you
May 04, 2012 | Baumatic 23 in. BDW13 Built-in Dishwasher
Message saying close outer door although it is closed and will not start
There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 09, 2011 | Dyson Flowcheck CRO1 Front Load Washer
Outer door won't close message. The door is closing but doesn't seem to be full into the catch
Your gasket on the door has probably came out of it's groove,try that. Or the gasket is bad and not right on the door and won't let the door close or the hinge or the latch is misaligned.
Apr 05, 2011 | Washing Machines
Outer door is open but machine thinks it is closed cant now close & machine also thinks it is on a cycle - which is isnt. I have tried to cancel it but it will not cancel because the door is not shut!
Sorry to hear you're having difficulties with your Dyson Contrarotator. It's probably best if you get in touch with us directly, so one of our experts can run through some troubleshooting over the phone, and provide the information and assistance you need.
You can call us free on 08002980298 - our Helpline is open from 7am until 10pm, 7 days a week. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Mar 01, 2011 | Dyson Flowcheck CRO1 Front Load Washer
Wont start keeps on saying close outer door
your door switch is broken. needs to be replaced
Sep 22, 2009 | Dyson CRO1 Front Load Washer
Outer door dyson washing m/c
try turning screw under detergent tray?
Sep 05, 2009 | Dyson Memory CRO1 Front Load Washer
Close inner door
That is a problem with the door latch.
To start move the cycler to the end to ternminate the cycle, and turn off the appliance.
Then unplug power cable, or trip circuit breaker, cutting power for five minutes.
If when you restart the machine you still get close inner door message, then that means that the door latch must be replaced.
Mar 01, 2009 | Dyson Flowcheck CRO1 Front Load Washer
Washing machine outer door
The solution was on your website, someone had already had same fault and posted the solution.
Thanks
Tracey
Nov 23, 2008 | Vacuums
Dyson Flowcheck CRO1 Front Load Washer Logo
1,621 people viewed this question
Top Dyson Washing Machines Experts
Starnley Johnwells
Starnley Johnwells
Gerry Harvey
Gerry Harvey
Are you a Dyson Washing Machine Expert? Answer questions, earn points and help others
