Romoving mislead paper
The copier is Panasonic Workio DP C264. When trying to make a copy, it says J03 Remove mislead paper. There is no mislead paper and it is stuck on that screen, what do i do?
  • 682 Answers
You must check for proper function of all microwitches in paper path and check for good condition of it is levers and no foregin object dropped inside and activate the lever of microswitches(pins-staplers)
Posted on Mar 08, 2008
HOW CAN I CHANGE PAPER SETTING IN PANASONIC DP-C264
It is a little more difficult to explain. If you send an email to LBrown18062@hotmail.com I will send you the manual that has a step-by-step picture guide that will guide you thru this process. Please put "panasonic dp-c264" as the subject.
Jan 31, 2012 | Panasonic DP-C264 Copier
I need drivers for my Panasonic WORKIO DP-1520P Multifunction 15 PPM Digital Laser Copy Machine MFP Copier / Network Printer
Click here Click on above link and download driver for your os and install. Let me know if you need further assistance. Thanks for using FixYa.
Jun 13, 2011 | Panasonic WORKiO DP-1520P All-In-One Laser...
I am getting a u18 error code when trying to copy a colour paper
You have reached your limit on color copies that the key operator has established for your code.
Mar 06, 2011 | Panasonic DP-C264 Color Copier
Panasonic DP1820E check printer E02-02 red spanner
yep!
e2-02 means there is a machine error of lifting motor assembly for tray #2.
For sure this time you can't use your tray #2.
you may check it sometimes there's just a paper clogged at the rear of the paper tray. just remove your 2nd tray to see if there is a paper clogged inside. Otherwise the cover/case of the lifting motor is damaged and you will need a service technician to fix and replace it.
Mar 14, 2010 | Panasonic Workio DP-1820E Copier
What is the recommended copier maintenance for Panasonic DP-C264?
120K and 240K are the big ones? as for the price call around?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 17, 2009 | Panasonic DP-C264 Copier
Panasonic workio 1820 how do i fix code J 45
1st machine on then is it ready? if you are ready then change your paper claugh unite
Jun 29, 2009 | Panasonic Workio DP-1820E Copier
Panasonic Workio DP-2000 j33 problem
The sensor arm just below the registration roller has dropped the spring to return it to it's home position.
Mar 27, 2009 | Panasonic Workio DP-2000P Copier
Paper jams at finisher when making multiple copies. Using 20 lb. paper. Any suggestions? Copier is Panasonic Workio DP-4510 with detached finisher.
first try to eliminate the finisher. turn off main power switch and unplug from the power outlet. Now unplug the finisher cable from the rear of the copier, then slide the finisher out of the way. Check to see if you still are having jamming issues. if not then yes the issue is with the exit of the paper or the finisher.
Many possibilities try to narrow it down.
Good Luck
Sep 27, 2008 | Panasonic Workio DP-4530 Copier
Panasonic DP150 FX Workio information screen is saying "Warming Up"
remove the paper drawer and check at the back of the mc where the cassette was for paper
Mar 21, 2007 | Panasonic Workio DP-150PA Copier
52 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
