Samsung LCD TV not receiving PC signal
TV isn't accepting PC input.
What I've tried.
I have connected my computer to my Samsung TV via the VGA input.
I have also pressed the Menu button and highlighted the Source option. However the PC field is still grayed out and can't be selected.
I have connected two different notebooks but it is still not working.
TV model code: LA32R81BDX/XSA
Serial no: AHCS3MKPB00502K
Version: CM05
  • 5 more comments
  • Anonymous May 31, 2008
    I've got the same problem with my Samsung Television.
    In my case I have split the signal between the monitor and the VGA output...it seems that it isn't a resolution problem it's the absence of a signal problem.
    Is there some reason this feature would be disabled on certain models but the vga port and the menu option (although grayed out) would still exist?
  • nick315 Aug 22, 2008
    I have the same problem and I have checked my resolution, I have cloned the display, I have even checked the signal on other monitors. I have used all types of resolutions (at 60hz) and it still doesn't show up on my samsung monitor. The pc option is still grayed out. I know it is sending signal and my Sony VAIO even recognizes what kind of TV it is, but the darn TV doesn't 'get it.' If it is seriously this hard I don't know what samsung bothers putting the port on the TV. Then again maybe mine is defective. It does work with HDMI, but I figure I can get the correct resolution and a more crisp picture with the VGA cable...
  • Quiki Dec 23, 2008
    I have problem with Samsung LE37M86BD.
    I got it like 9 months ago and when I got the HDMI cable I started to have problems. Once I fixed it just by shutting down my computer and television and starting them in different order. Boom it works!! Then comes the time when I need to move my PC and that means disconnectin every cable that it is on.
    After I did what ever I was doing with computer (moving it, going to lan, or just cleaning it) I put it back to my room and connect cables. After I put it on and I put TV on. TV cant find HDMI2, but computer finds TV and names it "Samsung"
    I had this problem now 3 or 4 times :) and now I have it again.
    Though im getting so bored with this and I want to know why it is doing things like this, because there is no logic in this.
    I can start to turn computer and tv again and again and again, and not knowing will it work or not.
    So as I assume it is TVs problem?
    My PC:
    Core2Duo 67xx
    XFX Geforce 8800GTS ALPHA DOG
    2GB ram
    xxxxGB.
    My TV
    LE37M86BD
    HELP PLEASE!
  • Fireknackers Jan 20, 2009
    my sony viao laptop dosent connect to my samsung LCD tv, i have checked the cable with my pc and connects automatically, therefore its defo the laptop ! any suggestions ?
  • honingdauw Mar 07, 2009
    I have the same problem. Samsung LE32a330 lcd television is not receiving my pc. We connected through VGA. As we are using a mediacenter we really want to make this work.
  • manishboya Mar 08, 2009
    i have tried to connect my samsung lcd tv with 5mtr. long vga cable but could not do so.my tv model is LA32A450C1LXL
  • Karl Whisenand
    Karl Whisenand May 11, 2010
    have you set the computer resolution to 1024 x 768 60hz refresh .
    and doe the tv need you to define the inputs first in the menu setup?
Check your vga cable. Some cables have only 14 pins, some have all 15. The missing pin is pin 9, in the 15 pin cable it carries 5v from the graphics card to the screen. Without that 5v signal most LCD and Plasma television screens won't recognise a PC input. I had the same problem and only managed to fix it when my girlfriend swapped a cable over for me and as she did so glanced inside and said "it's got a bit missing" The cable that came with your PC most likely only has 14 ins as that is all a monitor screen needs.
You can buy a 15 pin cable at most PC or electronic shops, just check that isdoes have all 15 pins befiore you buy it. The cheap ones are just as good as the expensive ones unless you are buying 20 foot cable. For 6 foot cable the cheap ones are just as good as the expensive ones.
Posted on Sep 20, 2008
    Scholar:
  • 76 Answers
You more than likely are not SENDING a signal FROM your PC so the option is not available. Get your computer set up for TWO displays and select CLONE if that option is available so what you see is what you get.
Posted on Mar 08, 2008
Hello!
This Samsung LA40C350 TV requires all pins are connected from D15 D15 VGA cable
Some cables what they sell in market dont have all wires connected. Only RGB, Grounds and Horizontal and Vertical sync but missing other connections
Samsung uses those other pins detect if PC is connected or not.
Next time you buy VGA cable, take multimeter with you and check that all pinns are connected through, before buying cable.
Best Reg: Eero
Posted on Jan 31, 2009
Check this forum out - the problem is potentially due to the PC/ VGA input being set to autodetect.
http://forums.cnet.com/7723-21577_102-376048/52-lcd-tv-does-not-recognize-vga-input/
Posted on Feb 04, 2013
Working cables are available on ebay. Search 'samsung hdtv pc cable'.
Posted on Sep 21, 2009
How do I change source resolution on my TV?
connecting PC to Tv through VGA - Tom's Guide
www.tomsguide.com/answers/id-1891563/connecting-vga.html
Nov 20, 2013 - Q: Can I connect the TV to the PC via a VGA cable...bearing in mind the .... Forum; SolvedI'm trying to connect my Sony bluray player home ...
Connecting my Plasma to my PC via the VGA port. - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - Ensure that the VGA cable is working properly using other methods. Perhaps .... I am trying to connect my pc with my samsung tv. .... I'm very sorry to hear that has happened, and I apologize for any inconvenience this may have caused you. Connection between Dell laptop and Samsung TV
Jun 11, 2015
How to connect computer to tv with sound and picture?
Jun 5, 2015
PC Audio won't play through connected Samsung LCD TV
Jun 4, 2015
Connecting computer to TV
Jan 18, 2008
More results from www.cnet.com
My custom built PC will not connect to my TV via VGA cable ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Jun 28, 2013 - 5 posts - ‎2 authors
Jan 31, 2016 | VIA Computers & Internet
Viewsonic HDCP LCD & DirectTV HD receiver
connect it with HD RCA's....then youll have both HD and Working cable.
Nov 12, 2007 | Zenith HDSAT520 DirecTV DTV Receiver
How do I convert a Westinghouse 22" LCM-22w3 DVI/VGA LCD Monitor into an HDTV?
Dear Amy,
Normally, monitors do not have tuning electronics for capturing TV signals.
Therefore, consider the monitor as a "dumb" unit that only displays information coming from your computer. Also, this unit does not have a HDMI input, but only VGA.
So, you are fated to have this monitor connected to your computer, always.
Now, you may find good software that will "tune" the TV signals from streaming at the Internet and show whatever is being broadcast. The same way you can access YouTube and watch videos these TV tuners will get the streaming signals the TV stations send via Internet (not all do that) and watch the channel in your PC/monitor
Since I do not have additional information about the computer you use I cannot give you other ideas
I hope I have helped you.
May 18, 2014 | Westinghouse 22" LCM-22w3 DVI/VGA LCD...
Connect pc to tv
You will need a cable that connects the tv to the pc. If you pc has a vga connection and your tv has a vga connection, then you would purchase a vga cable and connect it. If the computer and the tv have 2 different types of connections you will need some type of adapter between the two of them.
Once you get them connected with a cable you just turn the tv on and Select Input (Select either PC, Computer, HDMI) of where the tv should receive the signal.
On the pc if you just reboot it most times the image will appear on the tv. if not you can Press and Hold your FN function key at the lower left portion of the keyboard then hit the correct F1 thru F12 key that toggles the display. The correct F1 thru F12 key will have LCD/CRT on it or it will have the icon of a display.
Apr 28, 2012 | Computers & Internet
How to connect Acer Aspire 5530 to TV
If your TV is liquid crystal, or with VGA interface of the TV, the computer also WITH VGA interface don't need to buy TV card.Otherwise not only buy TV card, still need to buy a VGA connections, five meters. But VGA connections only transfer video, not transmit audio. So, you need purchase another audio signal lines, according to TV and computer their audio interface situation choose, both prominent circle mouth speakers audio signal lines. , 5 m.Also you can buy take S terminals output graphics CARDS, but it also requires TV also have S terminal input interface.
just have a try,I do not know if useful!,source from autodvdgps
Jan 09, 2012 | Computers & Internet
I have a Samsung Series 6-650 LCD TV (Model # LN46A650A1F). I am trying to connect my Laptop to use the TV as a monitor and have done everything to make it work, using a VGA/HDMI cable, but the TV refuses...
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Feb 28, 2010 | Samsung LN46A650 46 in. LCD HDTV
I have a Samsung LCD TV, model # LN40A450 with a PC input. I connected my Dell Vostro 1310 laptap to the PC input and I consistently get a "Mode Not Supported" message on the TV screen. Why? I had a...
You TV will only accept specific signal formats (modes) through the PC input. Check you user manual for compatible modes. You then need to set screen 2 (your laptop VGA output) to 1 of the compatible formats (PC display settings). A common format/mode example would be 1024 x 768. Try it out and see if you get a picture. You can then increase the resolution 1 at a time to find the best format/mode for your purposes. I hope this was of some assistance.
Dec 29, 2009 | Samsung LN40A450 LCD TV
When I switch my 22'' lcd monitor on it displays a message '' disconnected '', I have just bought it secondhand.
The message "disconnected" shows that the LCD not receiving signals from the input source.
Verify that the source is working properly.
If you are using this LCD as a PC monitor, connect it to the PC's VGA out via a VGA cable. Make sure that your PC's display output is working (are you able to use another monitor?).
Also try using another VGA cable to check if your old one is faulty.
After making appropriate connections, turn your LCD off and then back on after 10 seconds.
If your problem is still unsolved, it may be a sign of a faulty component inside the LCD but the chances are rare.
Nov 03, 2009 | Computers & Internet
Why won't my tv display my computer screen
Hi. The best way to hook your computers display to your LCD screen will be to use the VGA input socket. If your video card can support both S-video input and VGA, you can use either one but, the VGA is best for optimal resolution. This is the easy way to do this. Step one, connect the VGA cable to the computers video card and then, run the other end of this same cable to the VGA input slot on the LCD screen.Step 2, next you will make sure that the LCD's input selection is selected to show what is being transferred from the CPU video card by using the input button on the lcd remote control. The lcd(your tv) should be on VGA or PC input signal. Step 3, now, you Will have to also make sure that your video card is set to transfer this signal as well by pulling up your video cards software window and switch to the proper options. once this is done, you should get a signal. Be sure to use the VGA input/output ports on both the lcd television and your cpu for optimal transfer of the video stream. Here is a pic of your back panel. use the input port labeled I for good PC input quality.
Mar 24, 2009 | Proscan 32LB30QD 32 in. LCD TV
Televison & Video Logo
7,407 people viewed this question
Top Televison & Video Experts
Electro Med Services...
