Question about Zalman Tech (ZM460B-APS) 460-Watt Power Supply
Comp will not restart
I reset comp while i reset router(lost connection i reset and comes right) and it closed fine but when it rebooted it got asfar as windows vista symbol and it reset it self and did this 3 times so hit power button to stop it and left for 5 min but now it will not power up at all, have psu on a gigabyte GA-965P-DS3P board with 320gb hdd +500gb hdd 2x dvd drives and a expertvision 8600gts graphics card. was playing WOW at the time and lost connection that is why i reset all
  • 1 more comment
  • coeXXist Mar 09, 2008
    Nothing happened at all there definitely is power on lead (i'm a sparky) , is there a way to test power supply with multi meter ? or could it be motherboard?
  • coeXXist Mar 10, 2008
    The fan on the PSU does not turn at all. Thank you for help. :)
    i will let u know how it goes.
  • coeXXist Mar 11, 2008
    just to let u know it was PSU my supplier tested and she no go. they replaced but i swap for a ZM600-HP :), i told them what i had an they reckon it was on the verge of being to much for it, hence the bigger PSU. THANK YOU VERY MUCH FOR HELP you were very helpful.
    Genius:
  • 1,554 Answers
Unplug unit, press power button , plug in, power up.
if it still will not power up .
see that the fan at least jiggles ,saying its trying to startup.
Posted on Mar 08, 2008
  • Karl Whisenand
    Karl Whisenand Mar 09, 2008
    if the fan on the power supply is running and the hard drive is turning you have correct power,
    if the fan does **t jiggle at all the (you have to watch closely) then it is dead.
    if it jiggles then.
    I would reseat the memory and video card.
    if still ** mb post then pull all cards and drive cables ,
    leave only one stick of memory and video card and power,
    Reseat the CPU .
    if still ** post you have to switch cpu/motherboard/power supply.
    if you want to measure voltage on the power supply the yellow is 12 and red is 5v black is gnd.
    if you pull the video card does it beep,
    if you pull all the memory does it beep .
    though some boards have a new bad habit of **t beeping.
How do i get into admin setting when pass word has been lost
i think u might have to go into setup .when you computer reboots to reset the password asfar i know..
May 20, 2012 | Computers & Internet
Printer intermittently goes offline, will come back at random. Restart does not bring it back online. It will come back online at random, no set period of time. May be online for days, or off for days. I...
I suggest that you investigate the router. You did not specify how the printer was connected, often wireless is an issue, if you are wireless, change the channel to 11. Many land line cordless phones, with the extended range, interfere on most router default channels.
The restart of the router is a pretty large clue, also connections in and out are suspect.
Feb 12, 2011 | Computers & Internet
Can my comp be too old for a router? it works on one comp but not other. maybe bad cables?
no computer is not old for any router
try to reset your router and then try again
Press reset button at back of your router for 30 seconds,use pen or pin to press that reset button for 30 seconds
restart your computer after reset and refresh your network list
and connect it again
Jan 10, 2011 | Cisco Linksys E2000 Advanced WirelessN...
I m using a toshiba L310 laptop & it was fine with a wireless internet connection but suddenly it lost connection & its not connecting anymore. what can I do now?
restart your comp and your router, if that doesnt help try and update your drivers to your wireless card in your comp., if everything is updated and the wireless in you comp is searching then it might be the router, they commonly overheat for heavy use
Sep 18, 2010 | Internet Computers & Internet
Wireless Connection Problem
try uninstalling reboot then install again
hope this helps
Aug 01, 2010 | 2wire (2701HG-B) Wireless Router
I reset my belkin router by pushing the reset button in the back now i cant access the internet on my comp or on my xbox what can i do to fix it
If they are wireless connections, you have to input the "new" WEP/WPA code.
Reboot your modem, after it syncs up, then reboot the router. This can make sure hardware is leased to the right addresses.
Jun 17, 2010 | Computers & Internet
WRV54G Linksys router right out of box setup and for 5 min no prob then...hell broke loose neither computer had internet access(2 comps and an iTouch) connected via bypassing router and worked fine...
Do you have DSL or cable? Try resetting your router. Press the reset button on the back of the router and hold it it for about 5 seconds. When the router comes back up type in the router address: 192.168.1.1. If your ISP is using cable, make sure that you have DHCP enabled. If DSL, you will have to put in your username and password given to you by your ISP and you will have to enable PPPOE on your router.
Jun 11, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
No internet Connection
this is something simple
2 things you will have to do
the router when a problem like this happens again
unplug router for 1 minute this is packet build up and then plug back in i found this out by service provider that its a build up of packets it relieves packets
now the other thing since you went threw all the little areas of trying to reset modem go in remove your network connection
delete it and build a new network connection threw the network setup wizard then your done restart comp everything should be back to normal and you wont have to ever reset network settings again
just unplug the router let sit for minute and plug back in
Jun 01, 2008 | D-Link AirPlus DI-524 Wireless Router
Router issues?
If you haven't made any changes and suddenly your wireless connection has stopped working than these are the signs that your router is offline.
Now first of all check that on your router have you got the dsl or the internet light solid if it's not solid then it could be a problem with your broadband line...check with your isp whether the signals are there on the line or not.
Now, if the signals are there then...
1) Do a complete power cycle of your router unplug all cables from your router replug them then check....
if still you are not able to open up any pages on ie...then reset your router to default settings...
in order to reset your router at the back of your router you will find a small hole that is the reset hole press the pin in that hole for 10secs that will reset your router....restart both of your comps....
Now, if you are using windows xp then
click start>control panel>in control panel click on switch to classic view>after that click on network connections>
in network connections you'll find wireless network connections....right click on wireless networks..
then click view wireless networks you'll get an option of belkin wireless network..select it and press connect....
once it says connected close all the screens and run the router installation disc that you got with your router .....you will be able to connect..
If you are on windows vista then
click start>then in start menu click connect to you'll find belkin network select it and press connect once connected run the router installation disc...
Feb 12, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Zalman Tech (ZM460B-APS) 460-Watt Power Supply Logo
124 people viewed this question
Top Zalman Tech Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Zalman Tech Computer and Internet Expert? Answer questions, earn points and help others
