WRITE PROTECTION trying to delete files from my seagate(st3100203u2-rk)and a write prtection error pops up.how do i turn the write-protection OFF!
    Genius:
  • 1,554 Answers
Might be you need this
http://seagate.custhelp.com/cgi-bin/seagate.cfg/php/enduser/std_adp.php?p_faqid=3901
Posted on Mar 08, 2008
  • 185 Answers
There are a number of reasons why you are unable to delete files and you need to be sure that the file is no longer required before you delete it. If a file won't allow you to delete it, it can mean a program on your computer is using it.
However, you can try the following...........
The simple way is to reboot your computer in "Safe Mode." To do this, reboot your computer, as the computer is booting, repeatedly press F8 until the option to select safe mode appears. Select safe mode and allow the computer to fully boot. Safe mode only loads all the critical and vital software to support your operating system and not all the programs installed on your computer. When the computer has booted, look for the file you want to delete and try to remove it. If you are able to delete the file, you can now reboot the computer normally, simply by restarting.
If this does not work a more complicated way of removing the file is to use DOS or Command Mode. This will definitely allow you to delete the file but is tricky if you have not used Command Mode before. Command mode will allow you to delete the complete folder so if there are other files in the folder that you want to keep, be sure to either put them in a different folder or move the file you want to delete into its own separate folder. Using command mode is irreversible so be sure you don't delete anything you are likely to need.
I will call the folder you want to delete FRED, just to identify it. Make a note of exactly where it is located on your hard drive, for example
C:\WINDOWS\Resources\FRED
Restart the computer pressing F8 like you did for safe mode.
This time select 'Command Mode.'
This will open a screen that looks old fashioned and there will be a prompt that will say something like
C:\Documents and Settings\Your_name>
Type del C:\WINDOWS\Resources\FRED
This will delete the folder called FRED which will remove your write protected file.
Then just restart you computer normally, the file will have been successfully removed.
Driver won't install
Make sure your computer is up to date with the latest MS service pack. If it is then find the driver you need download it and run it.
Jan 27, 2014 | Seagate (ST3100203U2-RK) (ST3100203U2RK)...
My 320gb hard is showing only 100gb.
You bios is limiting the hard drive. If you can update your Bios, the update should correct this. Very common in older IDE based XP installs.
The other option is that you set a partition size on it and just need to make the partition larger.
Feb 17, 2011 | Seagate (ST3100203U2-RK) (ST3100203U2RK)...
I have a seagate external harddrive that my father gave me can it be locked? the harddrive is 160gb it is about 2yrs old gray and black casing
When you say lock the drive are you asking to lock access to the drive entirely when you disconnect it from your computer no one can access your files if they find the drive and try to put it on their computer and open it,
Apr 18, 2009 | Seagate (ST3100203U2-RK) (ST3100203U2RK)...
Problem regarding the write protection of pendrive
please look for a button or a slide switch in both sides of your drive...try switching it to other side and delete files again..
hope this helps. please rate.
if you need further help, please post back.
Feb 09, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Extenal hard drive
then use a data backup utility and back your data
Sep 02, 2008 | Seagate (ST3100203U2-RK) (ST3100203U2RK)...
Write protection error on pendrive
Look for a small/tiny white switch on either the bottom or side of your pendrive and switch to the other side. there should be a tiny white switch on your pendrive...
Hope this help. dnt 4get to rate pls
Apr 09, 2008 | Computers & Internet
Write protection in pen drives
hi,
could you mention the brand of the pen drive.
anyway for deleting the files . try this--> right click the file and click properties. now check you "read only" (ie. dis-select it ) and select file or folder is ready for archive.
now try to delete it.
hope it helps. and after knowing your brand and model of your pen drive more information can be given.
regards
bzoy
Jan 09, 2008 | Electronics - Others
Seagate hard drive
Is this internal or external drive?
Jul 19, 2007 | Seagate (ST3100203U2-RK) (ST3100203U2RK)...
Tool to remove bottom plate
The screwdriver you need is a Torx T10 screwdriver. Just get it from a hardware store, ask for a Torx (size T10) screwdriver. Good Luck!
Jun 19, 2007 | Seagate (ST3100203U2-RK) (ST3100203U2RK)...
Computers & Internet Logo
196 people viewed this question
Alun Cox
David Payne
David Payne
