Mini Component When turn-on, the display shows "HELLO" and then "PROTECT" then shut-down on its own.
  • RBen Mar 11, 2008
    Thanks for the responds, it could be the power output amplifier. Since I disconnected all the possible overload or short ckts, like the speakers, dvd player, and cassette players section still, the same message on the display. Maybe its time to bring it to the service center. Thanks again.
    Sergeant:
  • 247 Answers
Before sending it to service, temporarily replace the speakers and wires to see if there is a short. If it works with the replacements, you have a shorted wire or speaker that needs to be fixed.
Posted on Mar 10, 2008
  • 42 Answers
You could possibly have a simple overload on the unit, depending if it is like a HTIB w/speaker outputs or if it just a DVD player. Wires could be crossed. etc.
Posted on Mar 09, 2008
    President:
  • 3,130 Answers
That means the output circuit has a problem and you will need to have the unit serviced.
JVC MX-GT88 sound system showing protected them shut off why
Chances are that something is blown in the power output stages and units shuts down to protect against further damage.
Repair or replace, which ever is cheaper!
Dec 08, 2015 | JVC MX-GT88 CD Shelf System
Hello can u help me about my MHC-gzx55d sony hifi component, when you turn on the power, the screen display appear "PROTECT" what is the problem and what is the possible damage of my component. please help...
When it goes into protect mode it has been over loaded. Remove everything from the component and unplug the unit for a minute or two. plug it back in and see if it pops out of protect mode. If this does not work then you will need to do a factory reset or check the fuses on the inside of the unit.
Feb 20, 2015 | Sony Audio Players & Recorders
Protect comes on why
Hello
Protection display will come over this type of set, when it is overloaded or system confused condition. Just unplug the device from AC mains socket and replug it after 4 to 5 minutes, and see whether it shows any protect display. If it shows it again, just disconnect the output loads, ie, connected speakers, and check. Again it displays 'protect', the internal circuit, especially the output amplifier circuits has the trouble, and the system need service. if it does not show protect display, after disconnecting the speakers from it, check the speakers or its connecting wires for damage. OK.
Jan 20, 2012 | Sharp Audio Players & Recorders
When i turn the system on the display will read "hello" then "protect" then shuts off. Whats up ?
The "protect" function is shutting the syetm down to protect the electronic components inside it. Usually caused by a lackof earth in the plug or extension lead. Plug it straight into the wall and check it, if it is still the same then it could be a speaker wiring short circuit, disconnect the speakers and plug it in on its own and test it
Aug 27, 2010 | Samsung HT-Z310T Theater System
Says,''push power protect''
The display power protecct means that it is a safety shut off of the set to prevent further damage. It is possible that your output stage is faulty. shorted or malfunctioning. The protect cirrcuit can also create up this cut off. So you need to remove the speakers first and check if the speakers are short. If not check the putputs for the short, disccoonect the output drivers and check . if the set powers then it is confirmed that the driver is faulty replace and test. You will need a good multimeter and some basic electronics to probe into these circuits. Hope you try. Good day
Jun 02, 2010 | Sony Audio Players & Recorders
My receiver clicks on a off randomly.
Hello Fixya customer,
Thank you for your question.
Are you getting on the display, possibly a "P" or "Protect" that indicates it is in the protect mode?
Hitting the top of the receiver indicates a possible intermittent component or board connection. The receiver will shut down when the Microprocessor receives various fault conditions, including shorted speaker and wires, but if it develops an internal fault it will also shut down to protect itself and the speakers.
Remove all speaker wires and inspect th terminals for any stray wires shorting the terminals.
If it still shuts down, then a professional servicer would be required.
Thanks for using Fixya, and if I can help you further, please let me know.
May 01, 2010 | Sony STR-DE545 Receiver
PROTECT DESPLAY CAN NOT RESET ON SHARP MODEL CDK7000
protect display on my sharp mini component system, how do i fix this problem
Feb 21, 2009 | Sharp Audio Players & Recorders
Display says protect
check your low voltage fuses, the protect light up when a overload comes....
Jan 28, 2009 | Audio Players & Recorders
Power protect
The protect mesage indicates a problem with the final stage of the output amplifier. The unit shuts down to prevent further damage. Please update this with the make and model and I should be able to point you to the problem part(s).
Thanks,
Dan
May 26, 2008 | Sharp XL-ES50 CD Shelf System
105 people viewed this question
 Grubhead
Grubhead
