Question about Microsoft Office 2003 Basic Edition English (s55-00066) for PC
Access 2003 i have access97 data base and when i convert it into access2003 and make the tables in two databases and the the forms and quires in other databases depend on the name of the program "all databases are about accounting" every thing is working good, but when i try to open the same database from the network "other user" it gives me this message "indicates that the bath of the database is not valid" although the shortcut is correct with the right bath . and if i relink tables from the user pc inside the date base it gives me a new message " the database has been placed in stat by user admin on machine DC01 that prevents it from being opend or locked
Page setup problem in access 2003
Posted on Mar 12, 2008
How do I easily repair corrupt or inaccessible Access database file?
Why to depend on anyone else suggestion. You may download one of the best access recovery tool which will repair your inaccessible access database file. This tool work on windows 10 & below versions also best thing is that free version of this tool will preview all your records after repairing your database. So you may preview your database and can easily review that your data is recovered and to export it you have to use full version. Try this access recovery tool. Access Recovery Tool Repair and Manage MDB or Accdb Database Files
Sep 09, 2015 | Computers & Internet
Access database 2003 problem with a copy of database file. How to fix?
You say corrupt, in what way exactly? Do you get any specific error numbers/messages?
Have you tried Access repair program? Compact and Repair. If not, use it. But ensure that you made a backup, it is necessary because all the recovery tips can make the damage even worse.
Also try Jet Compact Utility. This tool created by Microsoft and it is much like Compact and Repair, but more successful in repairing.
If no one of above advice helps, then perhaps you need more powerful solution. In this case try to run a good third-party. I would recommend Recovery Toolbox for Access. It must help you. https://access.recoverytoolbox.com/
Feb 23, 2015 | Microsoft Access 2003 for PC
What is the extension file name for a microsoft access file?
According to Wikipedia:-
Access Project .adp
Access Blank Project Template .adn
Access Database (2007) .accdb
Access Database Runtime (2007) .accdr
Access Database Template (2007) .accdt
Access Database (2003 and earlier) .mdb
Access Database, used for addins (2,95,97), previously used for workgroups (2). .mda
Access Database Template (2003 and earlier) .mdt
Access Workgroup, database for user-level security. .mdw
Access (SQL Server) detached database (2000) .mdf
Protected Access Database, with compiled VBA (2003 and earlier) .mde
Protected Access Database, with compiled VBA (2007) .accde
Windows Shortcut: Access Macro .mam
Windows Shortcut: Access Query .maq
Windows Shortcut: Access Report .mar
Windows Shortcut: Access Table .mat
Windows Shortcut: Access Form .maf
Jun 03, 2010 | Microsoft Office Access 2003 (077-02871)...
Access database was copied now no tables in dropdown list
Your version of Access may require slightly different menus and clicks than mine, but the procedure is straightforward and should be very similar to what you will need to do. Read the whole post first!
Make sure you have permission to modify the database, then go to the form (I assume the drop-down table is in a form) and go to design view.
In design view, click once on the dropdown box you are having a problem with, and a properties screen with several tabs should pop up; click on the data tab, and look at 'data source'. In the list look for 'row source type' to see if the source of your data is a) a table or a query, b) a value list or c) a field list. Most dropdown boxes use either a value list or data from another table or a query (based on a table).
Check the source of data by going down to the next line in the list titled 'Row Source' (this is the list on the data tab that popped up when you clicked on the dropdown box in design view).
If the source is a table/query type you should see some code in the Row Source box like "SELECT....". Without changing anything, click once immediately to the right of the box, and whatever source the rows are coming from should pop up--if a query, for instance, it will pop up the underlying query in design view.
You should be able to troubleshoot the underlying query to see why no data is given in the dropdown box.
Another point where underlying query or table is used: If the table was based on a query that pulls data from the records in the current database, the drop down list will be blank until new records are added so the query has something to list.
And if the source is a 'value list', the values should be included in the row source box below, separated by semicolons. If not you simply need to add them in.
If your source is a field list, go back to whomever copied the database and tell them you need help with the copy they gave you...
Sep 13, 2009 | Microsoft OFFICE 2003 BASIC OEM ENGLISH MS...
Want to populate a form with data from a table, the Id number is keyed into the form and once it's matches with the Id in the table I want the other fields on the form to be populated with the data from...
Create a Form from the main table with a subform based on the other data you will want populated. You put the fields in the subform that you want populated from the main form. Go to the properties for the subform and select the data tab, In the data tab, select the Link Master Fields and choose the field you want linked. When you type the ID number in the main form, the other firlds you have in hte subform should populate from the data inthe table.
May 14, 2009 | Microsoft Access 2003 for PC
Hi all i want to launch a form when i click the data base file in MS access 2003 (the form is created inside the mdb file of access)
hi,
on MS Access 2003:
goto Tools Menu --> Startup --> select your form for "display form/page" dropdown
uncheck the "display database window checkbox and display status bar checkbox
Hope this helps.
Thanks.
Apr 01, 2009 | Microsoft Access 2003 for PC
Ms-Access
this discussion could go on for days (month? a semester at least?) but data is any piece of information you want to capture and save. a name. an address. a phone number. (actually they are examples of pieces of data - and whether you capture and save them or not they are still pieces of data). data "forms" a database when you save it (in the dataabase).
the database usually has tables representing related pieces of infomation.
Example:
the CLIENT table may have the following fields:
Client Number
Client Name
Address
Phone
Contact name
etc., etc.
the ACCOUNTS_RECEIVABLE table may have
Client Number
Invoice Number
Invoice Date
Invoice amount
etc., etc.
Notice how the CLIENTS table is "related" to the ACCOUNTS_RECEIVABLE table by the Client Number - hence the term you may have heard RELATIONAL database.
any more in depth please ask.
Mar 04, 2009 | Microsoft Computers & Internet
How to use passwd character in a table in ms-access 2003
When you create table where you want to store passwords, go to Edit Table, then select a field where the password will be stored, go to Input Mask field in Properties and type Password in that field. That will set up the field needed for storing passwords.
Aug 18, 2008 | Microsoft Office Access 2003 (077-02871)...
Accessing data
Dear reader
Place an ADODC control on your form in VB.
In the properties of the ADODC control goto the TAB General.
click "Use Connection String. With the button Build you can point to your database.
Thats it.
With the following code you can connect to db:
With Adodc
.RecordSource = "SELECT * From YOURTABLE"
.Refresh
End With
Now you have the table in the adodc control.
you can now do this:
Label1.caption = Adodc.Recordset!YOURFIELD
YOURTABLE = the name of your table in the database.
YOURFIELD = the fieldname in YOURTABLE you want to show.
Kind regards Fred.
Jul 04, 2008 | Microsoft Office Access 2003 (077-02871)...
Update record with two table
have an Access 2003 database that appears to be very corrupt.
I was having a problem and did a compact and repair on it, and I
lost my network connection during the process. Now when I try
to open it (or access it via DTS, VB, anything I can think of),
I get
"The Microsoft Jet database engine stopped the process because
you and another user are attempting to change the same data at
the same time".
I have rebooted the machine that was accessing it, and no
help. I can't reboot the server now because it's a 24/7 file
server. Is there any way to get this database open? I have
searched and found a bunch of demo programs that will
"uncorrupt" it and show some data (but not save it), so I know
it's possible, but is it possible without buying one of those
programs?
thanks
Jan 08, 2008 | Microsoft Office Access 2003 (077-02871)...
Microsoft Office 2003 Basic Edition English (s55-00066) for PC Logo
48 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
