AGP Help My computer when turned on says " your agp may have a problem ". I have taken out the card and cleaned it ect.. but no ideas on how to fix it.
  • snow_006 Mar 10, 2008
    It just wanted me to reset the default settings.
    Thanks Snowy
  • 81 Answers
If you find the error on the desktop your video card is ok. check the status of your hardware. explore>right click>properties and goto hardware tab> device manager> see if you can see some punctuation marks, then supply the right driver for the device. or you can go to your bios setup.(press del usually at pressing your power switch.) then look for load default settings and exit save. i hope this will help you.
Posted on Mar 08, 2008
Self having the following configuration on Home desktop PC. INTEL 1.7GHz, P4, D845GBV motheboard with AGP ATI Radeon 9000 graphics card, RAM is 2 x DIMM DDR2 266 Hz, 1 x 1GB + 1 x 512MB total 1.5GB RAM....
Power down and disconnect AC power from your PC. Remove the AGP card and DIMM again and use some "canned air" or dusting spray to get any dust off the contacts on your motherboard and your memory and AGP card. Wiping the AGP card contacts with some isopropyl alcohol (also known as IPA or "rubbing alcohol") and a clean, lint-free cloth can also help. When everything is dry, put your card and memory back in and try powering up again.
Mar 21, 2011 | Intel D845GBV (BOXD845GBVL) Motherboard
I install a video card nvidia fx 5500 agp in the computer ,set in auto for the onboard video,and when i restar the computer .the video card is not working .and the onboard card as well.when i remove the...
Enter BIOS and disable your onboard video card, shutdown PC, add your FX 5500 , Turn on PC....simple and easy. I hope this solution will be helpfull for you!
Apr 06, 2010 | Dell OptiPlex GX270 PC Desktop
I bought Foxconn 755A01-6EKRS Motherboard for my HP pc replacement. i install my AGP VsionTek x1300 graphic card and turn it on and nothing show up on screen...then i put the graphic card back to my old HP...
Your new Foxconn motherboard Primary Graphics Adapter settings in set to onboard vga that is why there is no display in your monitor. Do not install yet your agp video card. Use first the onboard vga of the motherboard.
Power up your computer and go to the BIOS settings. Locate in bios about the Primary Graphics Adapter settings and then select AGP. Save changes and the exit. Turn off your computer and now install the agp video card.
Dec 16, 2009 | Foxconn 755A01-6EKRS Motherboard
Black screen with sapphire 3850
took to dit computers and had them fit it. your man was no help.
Apr 09, 2009 | ASUS P4P800-VM Motherboard
Ati radeon 9550 agp with pinnacle pctv hd problem please help
Try to put it on another pci slot. if you are using the one right under the agp, then that is your culprit.  the agp and the top pci slot share video resources.  just put it on another pci slot, if you have to swap another non-video related card to the one just beneath the agp slot.  Hope this helps.
Mar 07, 2009 | ATI Radeon 8500 64MB AGP DVI/CRT/SVID...
AGP Video slot
the DDR doesn't matter.
your motherboard has a AGP x8 port, most if not all cards for agp will work!
buy a AGP x8 card. - I have no idea what you mean with series 1 or 2, that has never come up within the 10 years I've worked with computers.
You can learn about the AGP port here
http://en.wikipedia.org/wiki/Accelerated_Graphics_Port
May 30, 2008 | Acer Aspire T310 PC Desktop
Video Cards
there are difrent speeds of AGP port cards.
agp, agp x2, x4, x8
as the connector is difrent on agp 2x and on 4x you will need to look for a card that is made for agp 2x. Im not sure if they make 256mb cards for agp 2x.
Apr 25, 2008 | IBM eserver xSeries 200 8479
Ati radeon 7000 agp card not recognize by the system
Have you tried cleaning the AGP slot out with a combo of canned air & a clean paint brush? Set the bios for AGP 4X & connect power to the 7200 if power is needed. Still nothing. Try another AGP card.
Jan 13, 2008 | ATI RADEON 7200 (64 MB) Graphic Card
Grapics card
Most current AGP video cards are now 8X and they will still work with your motherboard but will just be limited to 4X. Trying to find a 4X might be time consuming whereas using an 8X downgraded to 4x would be comparatively easier and faster.
Additionally most Video cards will work under XP with the appropriate drivers but Vista has a limited list of compatible Video cards.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 08, 2007 | Nvidia GeForce2 MX200 64MB 4x AGP Graphic...
Compaq s4020WM AGP Questions
I don't think there's a 8x AGP card made that would not work at 4x, and any 4x capable AGP slot should handle an 8x card. AGP 1.0 (x2) signals at 3.3V AGP 2.0 (x4) signals at 1.5V AGP 3.0 (x8) signals at 0.8V
Apr 05, 2007 | Compaq Presario s4020wm (DK214AR#ABA) PC...
Computers & Internet Logo
Alun Cox
David Payne
David Payne
