Click the "Windows" button and then type "eMachines recovery management" into the search box. Click on "eMachines recovery management" in the results list and then click the "Restore" tab.
Click "Password Settings" and then type a new password into the text box.
Click "OK" and then click "Restore System to Factory Default".
Type the recovery password into the "Password" text box and then click "OK". Click "Next" To start the recovery process.
Click "Finish" and then wait for your computer to restart.
This procedure could take several minutes. Once your computer has restarted, you'll be prompted to create a new user account, enter the date and time and set up the internet settings.
or if you are running XP
If you set your machine back to eMachines factory settings, it might help you for a short while but if you don't have effective virus protection your problems will return in short order.
You should get rid of this virus with an effective virus remover.
You can run Bitdefender's free online scan which doesn't need to be downloaded http://www.bitdefender.com/scan8/ie.html
If you know when you got the virus, you can do a system restore to a time before the virus was on your system. This article tells you how to run it from safe mode http://bertk.mvps.org/html/safemode.html
Your best protection in general is a complete internet security suite such as Bitdefender or Norton internet security 2009.
More information here http://www.ask-the-computer-doc.com/comp...
If you need to totally rebuild your system and you don't have a recovery disk, contact eMachines to get one.
You might also try a Windows repair install if you have the operating system disk. Follow the directions here for XP http://www.michaelstevenstech.com/XPrepa...
Source(s):
hope this helps
Use a memory device such as a rewritable DVD or external hard drive to back up the data you need to save from your eMachines computer. Any data that isn't saved to an external source will be erased when the computer is restored to factory settings.
Remove any discs that are in the optical drive and unplug the computer's peripheral devices, such as an Ethernet cable or scanner. Do not disconnect the keyboard and mouse. Bring up the "Start" menu and choose "All Programs."
Navigate to "eMachines" and then "eMachines Recovery Management." Click the tab labeled "Restore," which is located at the top of the window.
Click "Password Settings" if you have not already set a recovery password. Type a new password in the text box and then click "OK." Click "Restore System to Factory Default."
Type the recovery password and click "OK." Click "Next" to wipe the eMachines computer's hard drive and begin the recovery process.
Select "Finish" and wait for the eMachines computer to restart. Use the series of installation prompts that appears on the screen to create a new user account for your operating system, set the system date and time, and set up your Internet settings.
