Question about Sony CDX-S2210 CD Player
No power how we can confirm the system ic faulty or not?
    Problem Solver:
  • 13 Answers
Check the fuse in the back 1st?then try a different unit in the car or plug it in to a 12 batt charger,make sure it 12v any lower and i wont work,any higher and you will cook it.if nothing happens check the wires are intact and conducting otherwise take it back and get them to test it?
Posted on Mar 08, 2008
My sony dav-dz260 will not power on looks dead
Possible that the main processor section is faulty . you need to check on the +5 to the processor, check the 5 volt regulator and if possible check for the crystal OSCillator working. If you are able to check the waveforms it will confirm the processor IC.
Oct 10, 2011 | Sony DAV-DZ260 Theater System
Tip
Standby timer came on while watching a dvd. light Sony KP-53XBR300 53...
<span>Please check the sections of the microprocessor to confirm if the IC is receiving the +5 voltage and there is no faulty soldering joints in this section.<br />A good observation on the power section and the outputs of the mother board will confirm if the fault is a faulty soldering joint </span>
on May 09, 2011 | Televison & Video
No sound from my home theater and when i power on only ward philips and then disk shown it cant power off until you remove power cable
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
Also check the +5 volt on the processor and if this section does not receive power or if the IC is faulty then the system can hang. check the processor input/ouput data .
Aug 17, 2011 | Philips HTS3410D/37 700W DVD Home Theater...
When i turn it on it sais protect and shots down. thanks
Hi sita72,
Protect is an error code for short and or overload. This will appear once the processor sense a malfunction either on the power supply or on the load (high chance is the output IC). DIY steps are as follow to determine where the fault is : 1. Allow the unit to cool down for an hour. Give proper ventilation and keep away all obstruction from the vent to have a sufficient air flow. 2. Disconnect one at a time the speakers, inputs, from the unit while powering it on.
If the unit back to normal again then you've confirmed that any of the above caused the error code. If #1 is the caused, you have to check also the exhaust fan, clean it as much as possible, replaced if faulty. If #2 is the caused (speaker) check the wire and speakers for short, (input) check the RCA cord for short or replaced if necessary.
If the above simple fix didn't cure the error code, you can try the next steps if you are an electronics enthusiast. Now after removing the cover, you have to concentrate first on the power supply board. Look for bulged electrolytic capacitor. Leaky capacitor will affect the regulation of the supply and will trigger the error code. Look for dry joints. Check it also in the pre-amplifier stage, main output board where a big heat sink is located. Next disable the output amplifier stage by disconnecting the supply. If the unit come out, make some re-soldering on the board, spot the cold solder and dry joints and then try to connect again. If the error code appear again, high chance that your output IC is faulty but still to be confirmed. Using the disoldering pump and soldering iron pull-out the output IC from the board then try the unit. If the error code disappear, confirmed that your IC is faulty.After trying the abovesteps-by-steps guide and still the symptoms persist this is the time for you to send it to repair shop. Remember that your unit has a lot of parts and only some basic steps have done, leave the expert to troubleshoot the entire unit.
Have a nice day!
Thanks for using Fixya.
Apr 03, 2011 | Samsung HT-Z310T Theater System
Htc55o display prot then turns off
If the unit back to normal again then you've confirmed that any of the above caused the error code. If #1 is the caused, you have to check also the exhaust fan(if installed), clean it as much as possible, replaced if faulty. If #2 is the caused (speaker) check the wire and speakers for short, (input) check the RCA cord for short or replaced if necessary.
If the above simple fix didn't cure the error code, you can try the next steps if you are an electronicsenthusiast. Now after removing the cover, you have to concentrate first on the power supply board. Look for bulged electrolytic capacitor. Leaky capacitor will affect the regulation of the supply and will trigger the error code. Look for dry joints. Check it also in the pre-amplifier stage, main output board where a big heat sink is located. Next disable the output amplifier stage by disconnecting the supply. If the unit come out, make some re-soldering on the board, spot the cold solder and dry joints and then try to connect again. If the error code appear again, high chance that your output IC is faulty but still to be confirmed. Using the disoldering pump and soldering iron pull-out the output IC from the board then try the unit. If the error code disappear, confirmed that your IC is faulty.After trying the abovesteps-by-steps guide and still the symptoms persist this is the time for you to send it to repair shop. Remember that your unit has a lot of parts and only some basic steps have done, leave the expert to troubleshoot the entire unit.
Give a thumbs up if you find it useful.
Have a nice day!
Feb 17, 2011 | Samsung HTC550 Theater System
The word protect is on my stereo and i cant seem to use cd,tape player,or radio. and the power will not go off
Hi Anita,
If the above simple fix didn't cure the error code, you should need help from friends that can perform this steps. Now after removing the cover, you have to concentrate first on the power supply board. Look for bulged electrolytic capacitor. Leaky capacitor will affect the regulation of the supply and will trigger the error code. Look for dry joints. Check it also in the pre-amplifier stage, main output board where a big heat sink is located. Next disable the output amplifier stage by disconnecting the supply. If the unit come out, make some re-soldering on the board, spot the cold solder and dry joints and then try to connect again. If the error code appear again, high chance that your output IC is faulty but still to be confirmed. Using the disoldering pump and soldering iron pull-out the output IC from the board then try the unit. If the error code disappear, confirmed that your IC is faulty.After trying the abovesteps-by-steps guide and still the symptoms persist this is the time for you to send it to repair shop. Remember that your unit has a lot of parts and only some basic steps have done, leave the expert to troubleshoot the entire unit.
Have a nice day!
Feb 11, 2011 | Sharp CD-BA200 CD Shelf System
At power on, displays F61 code and switches off
F61 is an error code.
It will automatically shuts down your unit.
This is very common on your unit.
Try to checked if the fan is working or not.
I have repaired some unit before, this is the caused why f61 appeared.
The symptom is shutting down the unit after a few minute.
If the fan is not working it will shuts off automatically to avoid further damaged to your output I.C. from overheating.
If confirmed that the fan is working then I've suspect that your output I.C./pre-amplifier circuit is faulty.
This is quit technical and need to send to repair shop to isolate the faulty parts.
The output IC of your unit is RSN series and quite expensive.
Pls rate my help.
Thaks for using fixya...
Jan 21, 2011 | Panasonic SC-HT75 System
Standby timer came on while watching a dvd. light has been blinking for 2 days and cant find manual. thank you
A good observation on the power section and the outputs of the mother board will confirm if the fault is a faulty soldering joint .
Dec 11, 2010 | Sony KP-53XBR300 53" Rear Projection...
The sound on our unit will flip off after a minute or so. Then, the sound becomes a low-bass reverberation. Any ideas on how to resolve this would be appreciated.
Possible that the Audio output IC is faulty as the set is changing the frequency after powering up.
But it will be important to open and do a audio signal test to confirm onthe fault of the IC.
If the signal to the IC is analysed then the fault is confirmed speccially if the audio output is clean when fed to an external amplifier.
If not the audio processing canbe faulty either inthe preamp or the SIF.
Sep 24, 2010 | Dell W3706MC 37 in. LCD HDTV
The internal speakers/sound have quit working. I can hear the sound if I put my ear right next to the speakers but it does not respond to volume control or nay other controls in "settings". Any Ideas?
Maybe the sppeaker is faulty or the output audio amplifier IC is faulty.
You must remove and check first the speakers , if Ok then check for main voltage tot he IC, if not check power supply, If yes then the IC can be faulty.
You can easily use an audio signal to test and confirm
Sep 23, 2010 | Polaroid 1911-TLXB 19 in. LCD TV
Sony CDX-S2210 CD Player Logo
100 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
