Question about Canon PIXMA MP150 All-In-One InkJet Printer
Paper feed when paper feeds in, it is getting pulled to the right hand side and jamming.i cant find where my manual is at the moment
  • 106 Answers
CLEAR PICK UP ROLLER WITH ALCOHOL AND COOTON
Posted on Mar 08, 2008
Paper feed jams on right hand side after I pulled bits of an A4 that came out ripped
Bruno:
You did not get all the pieces of that A4 paper out of the paper path. There is still a small shard of paper in the right side of the paper feed area. Use a flashlight to look carefully in the paper feed area and gently use tweezers to remove the piece of paper. If you pulled the sheet of A4 paper backwards out of the feed area, you may have dislodged the paper feed sensor (a small plastic finger that sticks down in the paper path to tell the printer that the paper has passed.) Be careful with the tweezers... if you break that sensor, there is no fixing it.
Jun 21, 2015 | Epson Stylus Photo R2400 InkJet Printer
How to load evelopes HL 2140
Brother Hl 2140 Printing on thick paper, labels and envelopes 2
When the back output tray is pulled down, the printer has a straight paper path from the manual feed slot through to the back of the printer. Use this paper feed and output method when you want to print on thick paper, labels or envelopes.
Open the back cover
Open the manual feed slot cover.
Using both hands, slide the manual feed slot paper guides to the width of the paper that you are going to use.
Using both hands, put one piece of paper or one envelope in the manual feed slot until the front edge of the paper or envelope touches the paper feed roller. When you feel the machine pull in the paper, let go.
• Put the paper into the manual feed slot with the side to be printed face up.
• Make sure that the paper or envelope is straight and in the proper position on the manual feed slot. If it is not, the paper or the envelope may not be fed properly, resulting in a skewed printout or a paper jam.
• Do not put more than one piece of paper in the manual feed slot at any one time, as it may cause a jam.
• If you put any Media (paper, envelope and so on) in the manual feed slot before the printer is in the Ready state, the media may be ejected without being printed on.
Jul 18, 2011 | Brother HL 2140 Laser Printer
Paper jam. paper pulls towards the right hand side and jams
Sound like you have something stuck in the paper feed path, check for a paperclip or similar, it may be that you have had a jam and torn off a piece of paper inside the printer which is now stuck, when removing jams from any nmachine allways pull paper in direction of feed never back on itself as it can cause this very problem
Dec 03, 2009 | Dell 810 All-In-One InkJet Printer
A paper is jammed in my printer and although it gives directions to open cartridge 1 and then take out paper cartridge then remove jam, I cant see any paper jammed, but I did hear it jam when it happened....
in right side of the printer one green color lock is there pull that luck ......paper feed unit will come out there you can see the paper ......
if you want manul send me your mail id anantakumarjena0@gmil.com
Nov 02, 2009 | Kyocera Mita FS 1900 Laser Printer
Paper jam
Use mirror and flashlight to look down paper feeder from the rear, gently pull paper toward the rear. An index card can be fed from the front to the rear to push paper out by turning the gears you see on the left side inside the front cover. Be careful not to force anything.
Jun 19, 2009 | Canon PIXMA MX310 All-In-One Printer
Epson stlus C88+ printer: paper pulled to one side during printin
Hi
Chances are the sensor for grabbing the paper on the left hand side is defective. Try to check if there are obstructions as well
Hope this helps
May 13, 2009 | Epson Stylus C88 InkJet Photo Printer
Paper is being pulled in on the right side and getting crumbled
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Apr 26, 2009 | Canon PIXMA MX310 All-In-One Printer
Printer 2480- my printer is pulling paper only on right side
Try this :
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Jan 16, 2009 | Lexmark X2470 All-In-One InkJet Printer
Paper pulling
Be sure your paper guides are tight against the paper. If so, then clean the feed wheels with a damp cloth (just water). If this helps temporarily, you might need to replace the feed wheels.
Jul 28, 2008 | Lexmark X75 All-In-One InkJet Printer
MP470, Paper jam on one side
There is something jammed in there....shake it upside down first.....if nothing then revese feed a paper through it manually......take left side off hold paper in front and roll wheel on the left side so the paper feeds back into the machine,,,,,,open top to see in there and when paper feeds under white rollers make sure it dosent jam where wite rollers are about an inch from the right there is a small rectangle hole with a black plastic piece in there pry it up carfullywith a paper clip and feed paper with the wheel under it at that point the paper push out a bobby pin into my back tray,,,,, now everything works great.......keep checking i didn't believe something was there either but there was..... also if your paper first starts to feed and stops pull out the paper and check for a bend or crinp in it mine kept doing that and that is exactly where the pin finally came out.....
Feb 01, 2008 | Canon PIXMA MP470 All-in-One Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
56 people viewed this question
old marine
old marine
