Hello to all. In my church we are having a problem with the fact that we need more AUX channels on our board. The mixer that we have, is a (RQ4332). I can't seem to find an AUX mixer available from Peavey. Any ideas?
  • Graeme Ross
    Graeme Ross May 11, 2010
    Hi there. The desk you are using has 6 aux sends already. Can you tell me what you need/plan to use additional aux channels for?
    regards
    Graeme
  • 1,512 Answers
Feel fee to get back to me about your requirements for extending the AUX capacity of you desk, I have extensive experience with all types or mixers and consoles for recording and front of house sound reinforcement. Just need some more information to be able to advise you correctly. God Bless
regards
Graeme
Posted on Mar 16, 2008
I have a AH GL2400. We are hearing a high amount of hiss on Aux 2 channel. Aux 3 is also starting to get noisy. Could this be a internal issue or componet failure?
First thing is to check your grounds and cables. The next thing is to put a different component on it and see if you still get the hiss. If both of these check out then you can start checking into the mixer itself. The channels do go bad.
Nov 23, 2014 | Mixers Allen-Heath GL2400 Series 24...
The 2tk signal won't output through the monitors
First check you knobs. if you are feeding out of an AUX out, make sure the AUX OUT MASTERS are turned up, not just the individual channels. Secondly, check the channels individually for a PRE/Post switch. The switch needs to be in PRE to be unaffected by the channels' slider position, otherwise when you fade the channel up and down on the fader, it will affect the volume of the feed to the AUX out, and the monitors.
Feb 05, 2014 | Soundcraft EFX8 8Ch Multipurpose Compact...
How to connect Echo/delay/repeat to mixer that enable me to setup/control all 12 channels on my mixer
You have built in effects that you can use - if you're trying to connect off board effects as well you need to use one of the aux send/returns.
Oct 23, 2013 | Behringer XENYX 2442FX Mixer
I have a Behringer sx2442fx mixer,and when i try to use my aux 1 and 2 channels for monitors it doesn't seem to be working. I sthere a chance that i have a button or something on the board thtas p
Make sure that you have enable the main monitor volume at the end of the mixer. They are labeled AUX1 and AUX2 as well located under the last channel of the mixer. If those are on 0 your monitors won't work
Jan 19, 2012 | Behringer Sx2442fx Eurodesk 24channel...
I have a midas venice 320 mixer, there is no output on the four auxlilary sends, but i have an output on other outputs and headphones.
You must have aux sends on each individual channel and each AUX MASTER turned up for output and each of those outputs must be going to separate amps.
Apr 12, 2011 | Road Ready Mixer Case for Midas Venice 320...
I have a behringer 16 channel board . the 2nd aux send in not working as of last week. What's the general problem that happens when an aux send stops working?.................
I don't believe this board has an "Aux send IN" jack. There are "Aux Send" and Aux Return.
The Aux returns are TRS jacks.
Make sure ALL interconnected equipment are powered from the SAME receptacle or source to avoid damage to equipment.
You might clarify the exact name of the in or out that is not working. I have schematics to help troubleshoot the problem.
Dec 18, 2010 | Behringer XENYX 2442FX Mixer
I have a mackie 24 channel mixer , I am trying to hook up my monitors. I need help I don't know how to do it. Recently lost our sound tech guy here at the church.
Decide if you want to use the AUX's or the SUB's for your monitors. (usually use the AUX).
Connect TRS cables from the appropriate AUX sends to thee amplifiers you use for your monitors or your powered monitors whichever you have.
Adjust the level using the AUX level controls for each channel to set your minitor mix.
Normally use the PreFader AUX's so monitor levels are set independent of the slide fader positions.
Here is a big hint for you: Search YouTube.com for "Soundboard" or "Soundboard setup". There are good videos there that might be different than your particular board, but there is enough commonality that you will soon be an expert!
Sep 21, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
We've got a signal on the mg32fx14 mixer from the microphone. There is no sound from the speaker. We tried the Group out there is no sound. So where do we connect the output from the backpanel of the mixer...
mg32fx14 monitors intermitently cut off, smoke comes out the back . aux 2 changes aux 1 and aux 2 at same time. 1 channel will over drive then change channels without changing enything else and its ok eny ideas or do i have a boat ancor
Apr 02, 2009 | Yamaha Mg3214fx 32 Channel Mixer With Fx...
43 people viewed this question
 Grubhead
Grubhead
