posted by theataband on Mar 08, 2008
my secondary ide is not letting me play music or open files
i get a invalid win32 application
i have tried everything but to no avail
i hear i can set my ide to 32 bits
how?
im useing a7s333 motherboard with a amd 1900
pc desktop
running windows xp pro
730mb memory
2-40gb hd
sound blaster live
10/100 ethernet nic card
everything works except the secondary ide
also it appears to work when i place it on the primary
i dont want to do this as i have two hdd's
Comment by theataband, posted on Mar 08, 2008
i already did this
there are no problems with any of the parts or the motherboard
does any one know how to set the bios to 32 bit for the IDE
Comment by theataband, posted on Mar 10, 2008
just because you havent a board of this doesnt mean i have to automatically format the harddrive
i would expect that from a newbie or an unexperienced tech
as well
the ide connector was already dected by the bios
there was and is an update on the computerand mb
i formated the harddrive and even installed a new hd
i even aquired the manual
i even tried to put a 40 80 ide ribbon and still got the same results
i wont need further comments to this post as the main cause is the ide connection not the south bridge
as well
Best Solution
Format system and reinstall oprating system
if problem still continue so update bios
download from www.asus.com
Comment by hvpatel, posted on Mar 10, 2008
not any other solution because ide connector directly attach with
south bridge your bridge may be faulty so i will advise you purchase PCI TO IDE card .
Rating Locked! (?) theataband has rated this solution as Inappropriate
Suggest a new solution for this problem
Post a New problem for ASUS A7S333 Motherboard
Email this problem
Email this problem
Can you Help with these Motherboards problems?
Repair Service
Find Motherboard Repairman Near You:
