Sound I have an old faithful Sony Trinitron TV KG 1684GE and the sound seems to have gone low even when it is on high volume. However when there is interference buzzing, the buzzing is loud! Do you have any suggestions Thanks so much, Lynda Davies Malaysia
  • 105 Answers
Service your IF IC beside tv tuner
Posted on Jun 20, 2008
  • 682 Answers
First clean volume button by contact cleaner from good brand from nearest electronic store or (radio shack).if the problem goen it is ok.
if it is excit ask for help from qualified sevice technician.
Posted on Mar 08, 2008
My Sony Trinitron volume goes from mute (1 bar) to loud (2 bars) - can increase to even louder but can't get low or medium volumes. The lowest volume is too loud for normal viewing. Any ideas about what I...
Hello
If you have some idea about the working of your TV, and some service experience you can do it by yourself. Your TV has electronic volume controls. That means, a gradual voltage rise or lower does the volume to go up or down. This voltage variation is done by an Ic which we call it as "System Control Ic", that every modern TV has; but differ in their type and number. You must know how to follow the schematic diagram of your tv to get the exact point from which the voltage orginates, and which point regulates the same.
At present there is some voltage, say 0.23VDC or so, remains at that control point even if you turned all the visual controls seem to be off; and that voltage suddenly goes up; say 3.05VDC or so when you adjust the volume to the near mid stage. Further saying 3.05VDC must come only after you have turned the volume bar to extreme high. Now you are listning your tv at is 1/4th volume at extreme low I thinks.
Looking for fault at system contol section must be done with patience, and should have schematic diagram of it, and some sort of skill. It is best for you to get service of an experienced service personal, otherwise the the faults will be rise in numbers. All sony tv has complex schematics even go to pages on a book, and have some difficut to follow even an experienced one you know. So think a little better and do the needy.
If you have confidence that you can reach the the above said points, contact me at my mail address which is given below. I will guide you. You must have the schematic digram of your tv also beside you. Ok.
gopakumarg43@ymail.com
Oct 19, 2010 | Sony FD Trinitron KV-28FQ75 28" TV
My Sony trinitron tube Tv 36" seems to be going (its 10 years old
no ....the tube will end up after 20 yrs in 10 yr old sony...
it is worth if u fix it. randomly going black means...horizontal driver trans former is the problem..or any loose contact with the 110 volt supply to that transformer,,or any loose contact with line o/p transformer.. (horizontal driver transformer may be gone
then tv behaves like this) if any other parts gone tv wont come back.... there may be a loose contact call a service pro..
Apr 02, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Buzzing sound wyen volume is high.
If you have a cable box on the TV, make sure the volume on the cable box is turned all the way up. If you do not have a cable box, some TV's seem to have a annoying buzz louder than others.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-27FV17 27" TV
SONY TRINITRON KV-2167MT power not on
Please replace Horizontal Output Transistor in KV-2167MT and TV will start function.
Nov 26, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sound is tooo low
Is this TV on a cable box ? The cable box does control volume so your TV may be alright
Jan 18, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Wega KV-27FS120
as no sound on certain channels it means no problem in your tv though it is old. the problem is in transmission line from where you get prog. it can be adjudted manually by vol.control if low sound is there at certain channels. you can also reset once.
Sep 26, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Volume is too low on my old Sony Trinitron KV-27S45
Volume is too low on my old Sony Trinitron KV-27S45 Can i fix it with out parts? no as it requires tech help as tv is high voltage device. would it be less expensive to just purchase a new tv? it would be less expensive. no need to purchase new tv. please get check 1 speaker paper cone might be hard or defective 2 loose contact in sound section 3 supply to sound might be absent. 4 connector loose. 5 any capscitor defective in sound section. 6 ic might be defective in sound section hope this will help.
Sep 25, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
High pitch sound for Sony FD Trinitron WEGA KV-27HS420 27" TV
The high pitch squeal you hear is usually caused by a coil vibrating, normally in the horizontal circuit. I've also seen the ferrite bead on the horizontal output transistor do this, but, it is rare. I normally will repair this by finding the coil and "tightening" it. To tighten a coil, technicians use different chemicals, such as, a hot glue gun, rubber silicone or even finger nail polish. I will find the coil that screams by starting with the usual suspects and using a wooden dowel, barely touch the coil and if the pitch of the noise changes, then, thats the coil that needs repaired. If you do not know your way around the inside of a television, I never recommend you do so, since, this procedure must be done with the set turned on and you poke your hands around the inside of the set by the high voltage circuit. Hope this helps your decision.
Mar 04, 2007 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sound Problem
There's a possibility that you may be experiencing problems with the audio output IC -IC404 - All serial numbers produced until July 2003 might use one of these defective IC's. So if your set was manufactured before this date, that is probably the culprit. If not, and you have it connected to a cable box that has its own volume control, it could be that its volume is turned down and by turning up the TV's volume too high that you are getting this distortion. Hope that helps.
Jan 20, 2007 | Sony FD Trinitron WEGA KV-20FS100 20" TV
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
