Question about Protron PD-800 DVD Player
Says disk not recordable (even new ones) or disk is empty that were recoded on. i also get the fist. in short, this new player recorder does not work at all.i
Does not record or play.
    Genius:
  • Protron Master
  • 1,550 Answers
Clean the laser lens.
Posted on May 28, 2008
I have one mds e 11 end dont record .apears protect on the display
Most likely you have the tab in the minidisc set to protect preventing the recorder from recoding on the disk C11 is the same as Protected.
Slide the notch on the minidisc to the other side to record. You cannot record on pre recorded minidiscs. You have to remove the disc from the recorder to do this.
If you open theprotect tab the recorder may write over what you already have on the minidisc.
Feb 01, 2012 | Audio Players & Recorders
My olympus vn-8100 flashed system error and stopped working
Ok, try this, works for me:
- Remove the batteries- Insert its again- Connect the recorder via usb to pc- Copy one by one each archive you need to recover, after copy delete them from the recorder- Copy SYSTEM, RECORDER AND MANUALS FOLDER to pc- Format from the pc the recorder (i use a mac - disk utility) yes it is, ERASE!- Copy again the folders: SYSTEM-RECORDER-MANUALS- Unplug the recorder, remove the batteries, insert again- Turn on the recorder, it will display a different error, format the recoder, it will restore and reset the systems files.- It works for me!-
Jan 10, 2012 | Olympus VN8100PC Voice Recorder
Disk formatting fails every disk. I used new dvd+rw..
What do u mean by formatting?U can't formatted the DVD+RW disc to blank again,after the disc been recorded and used.DVD+RW recodering mean something are recorded u can recorded some elese in it replaced what was there,that all u can do to it.U can't wipe out what in the disc data was there.
Aug 04, 2011 | Cyberhome DVR 1600 DVD Recorder
Recording dvd- i try to record and it says cannot record on this disk. its a blank -r/-rw disk.
Hi there, original firmware supports only dvd up to 4x. If you will try speed more than 4, recorder refuse them.
Try to insert 4 x DVD, note even 4 speed dvd will not work all - depends on brand.
There is new firmware available, you have to call customer service before upgrade, they will tell you everything about...
With new firmware you will be able to record all speed and type dvd...
Aug 30, 2009 | Emerson EWR20V4 DVD Recorder/VCR
So Frustrating!
Some brands od empty DVD's will not work on every DVD recorder.Maybe Sharp has a software update for this problem.
Aug 23, 2009 | Sharp DV-RW340U DVD Recorder/VCR
Sanyo DVD recoder doesn't play if I let record run to end of disk
most dvd recorders have setting to finalize at the end of a timer generated recording, or to fianalize when the disc reaches the end and runs out of room, check for one or both of these settings in the setup menu of the recorder
Mar 31, 2009 | Sanyo DRW-500 DVD Recorder
Philips DVDR615/69
Take, if good  batteris from the remote controller and recycel the unit, and by a better one. I have the  same problem, recordings will stay on the dvd only a short thime readable and later the disk is empty.
Sorry my english.
Sep 26, 2008 | Philips DVDR615 DVD Player
Symphonic DVD recorder wfr205
I have the same Symphonc DVD- VCR Combo wfr205. I can't get it to work either. I called Syphonic support 2 years ago about it, they told me to clean it. I did. It will recognize DVD's sparodicly, but will not finalize them so that I can play them on anything else. I tried 3 different brands of DVD-R all with the same results. I called Symphonic a 2nd time. They do not offer replacement and have never acknowledged the recoder has a problem. I finally bought a Sony DVD recorder. I can use it along with the VCR portion of the Symphonic. The Symphonic was a waste of cash.
Aug 12, 2008 | Symphonic WV806 DVD Player/VCR
Sony MDS JE-320 not recording
This is a common problem with the overwrite head on these units. There is a two wire connection going to it which fails after a couple of years of service. Or for some reason the overwrite head does not make contact to the MD disk surface, it is suppose to when recoding or writing the TOC.
This overwrite head assembly is very very delicate, provided you feel comfortable to work on it you can probably fix it. Or find a local electronics technician to help you with that.
Do some reading on the Minidisc Forum
Hope this helps
Apr 15, 2008 | Audio Players & Recorders
My dvd recorder keeps ruining blank dvd+r's.
I have suffered the same problems as you describe here. What I believe is this unit suffers from inadequate ventilation. After having this problem I examined the unit and noticed it was hot. What I've done is put 2 small flat blocks on each side of the unit, to basically suspend it so that it can get airflow under and over it, now staying much cooler. Nearly all problems now have gone away. Seldomly, I find it will still exibit the problems mentioned. Frankly the only solution I've found from there is to unplug it for a short while and, upon plugging it back in, and trying again it works flawlessly.
Feb 25, 2007 | iLO DVDR05 DVD Recorder
Protron PD-800 DVD Player Logo
46 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
