Question about Cooktops
COOKTOP THE DUAL ELEMENT BURNER NO LONGER HEATS THE OUTSIDE RING. HOW DO I TEST THE SWITCH AND THE BURNER WITH MY VOLT/OHM METER TO DETERMINE WHAT IS BAD?
  • jpmoorhead Nov 03, 2008
    Switching the wires around still left me with the same problem...outer ring does not heat up, only the inner ring. I'm going to attempt to replace the element. My stove is a Maytag glass top model MER5870AAW. Any suggestions?
  • sukhaid Jan 30, 2009
    The dual burner on my General Electric Profile JP350 cooktop does not turn on. How do I take the cooktop off to troubleshoot?
    President:
  • Cooktops Master
  • 2,651 Answers
Its been my experience that the dual burner switch is far more likely the culprit, unless you can physiclaly see the outer ring is broken( visual inspection works wonders. as far as trying to ohm out i generally look at theelemnet itself (4 wires lead to the elemnt you can trace 1 to the outer portion of element, and 1 to the inner portion.WITH POWER OFF Iswithc those 2 wires and the restore power try element ad watch for outer ring to work inner ring no good. now i know its the switch not sending power. reset wires and order new switch
Posted on Mar 11, 2008
The left top element is not working, the control knob lights up but doesn't heat. Is it the element or the switch? Mod#JED8430BDB Ser#1414040011A Schott Ceran
It could be either. The only way to properly check is by dismantling the cooktop and checking the circuit with a volt meter or test lamps.
Feb 11, 2011 | Jenn-Air JED8430 Electric Cooktop
One burner (left front) heats up too much. You cannot regulate the temp. Everything heated on this one element burns.
This is usually caused by the infinte switch. You will need to disassemble to acess the switch. The switch is easy to test and replace. Here is a link showing how to test an infinte switch http://appliancehelponline.com/infiniteswitchvideo.html
You can also enter in your model # for diagrams and illustrations of your specific model.
Aug 25, 2010 | Maytag MEC5430BDS Electric Cooktop
My Jenn AirCooktop Model CVE3401 burner problems
The part you need to replace is the switch. The switch is housed under the top and connects to the dial you are turning.
The switch for the dual burner is 12002125, and 74011242 for the single burner.
The single burner switch runs about $20.00 and the dual runs about $50.00 for the parts
Apr 24, 2010 | Jenn-Air 30 in. CVE3401 Electric Cooktop
I need a dual burner switch for my Amana cooktop model ak2h30hr
Fit two switches. Although this might be as expensive as a new cooktop.
Mar 27, 2010 | Cooktops
JEC9530, dual element burner(right front) does not work the light does come on, the burner does not and the knob has play in it.
This coulb be either the switch or the burner. Either can be tested with an ohmmeter if you can read the wiring diagram. Hope this helps!
Feb 26, 2009 | Jenn-Air JEC9530 Electric Cooktop
My Viking VECU105 electric cooktop has one burner which will not regulate the temperature. It can be turned on and off with the control knob, but after that, there is no temperature control. Any ideas on...
It will need either a dual infinite or infinite switch, If the burner has an inner an outer element then it requires the dual.
Firstly turn power off at breaker.
The unit needs to be removed from the cut out and the cover removed from below the swtichs. the knob taken off and the secureing screws removed, then take note of the layout of the wiring and the poistion of the switch, then swap the wires, reassemble test and then re-install
Feb 18, 2009 | Viking 31 in. VECU105 Electric Cooktop
Electric cooktop burner malfunction
The outer ring of the element is most likely broken. You'll need to replace the element.
Apr 06, 2008 | Cooktops
Replacement dual burner Gaggenau CK594
You have 2 line, 2 load, and if there is an indicator light, 1 for that and 1 ground. The other guy may be right about the 2 grounds, if not, the indicator light may have a connection for hooking it to another light in series. The tech cannot understand the schematic? get someone who can.
Jan 15, 2008 | Gaggenau 47 in. CK 594 Electric Cooktop
Cooktops Logo
455 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
