Question about Maxtor Hard Drive
Hard disk partition lost
Due to unknown virus I had to instal new windows on my pc. using a bootable disk, first I formated the hard disk drive C and E, after this I lost the partitions. I have applied partition tools such as Magic partition.., but I have not been able to fix the problem.
Your help is highly appreciated.
Esmail Amiri.
    Genius:
  • 3,587 Answers
This needs to be done via the bios/setup screen, since it's a root partition issue..F12 when you start up the machine.
Posted on Mar 08, 2008
Memory wipe wd3200bevt
Download MiniTool Partition Wizard Bootable CD 7.1 from Here.
Or Download Directly by Clicking here
This CD allows you to boot computer directly into MiniTool Partition Wizard to manage partitions without any limitations. You can rebuild MBR, Partition Recovery, Move/Resize Partition, Merge Partition, Change Cluster Size, Copy Partition, Create Partition, Delete Partition, Format Partition, Convert File System, Hide/Unhide Partition, Explore Partition and much more.
Burn ISO file onto a CD using any CD/DVD Burner software.
Set the CD-Drive to 1st boot device in BIOS.
Insert it into drive and reboot the system.
You will get Partition Wizard Boot Disc Menu.
What to expect from this bootable CD
Step 1: Choose boot disk
Step 2: Choose screen resolution
Step 3: Manage your partition
How Delete All Partitions?
  • There are two ways to start this function:
    1) Click on Disk in the top menu, click Delete All Partitions from the drop down menu.
    2) Click Delete All Partition under Disk Operations in the Action Panel.
  • Delete All Partitions will delete all the partitions in the present chosen disks.
    Note: May cause Windows to not start properly when used on partitions containing the boot partition or system partition.
For more information check the website Link
Hope this will be useful for you.
Best Regards
Nandu
Apr 04, 2012 | Western Digital (WD3200BEVT) 320 GB SATA...
Tip
Formatting an external hard drive with Mac OS X's Disk Utility
Formatting your new external hard drive is not as difficult as you may think. In fact, you don't even have to be a computer techie or uber-Mac geek to perform this procedure successfully.
The tool you would use, to format your drive within your Mac OS X system, is the built-in utility application called Disk Utility.
Disk Utility is Apple Inc.'s defacto utility application, for performing disk related tasks within the Mac OS X volume.
From creating new images, to burning CDs and DVDs to formatting hard drives, Disk Utility performs well enough to keep not only your Mac OS X volume on your hard drive error free, but keep your hard drive healthy and error-free as well.
I could go on in detail, admirably describing more features of this versatile Mac OS X tool, but the purpose of this FixYa tip, is to show you how to easily format your external hard drive. So that is where I will take you now.
There are generally two formats in Disk Utility that you can use to effectively format your hard drive.
Mac OS Extended (Journaled) - if you want a Mac readable hard drive only
MS-DOS (FAT 32) - If you want your external hard drive to be read by both Mac and PC.
--STEPS FOR FORMATTING YOUR HARD DRIVE WITH DISK UTILITY--
• First, make sure your external hard drive is connected securely to your Mac and is turned on.
•Next, from your desktop, click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
• From the Finder menu, click on Go, then Utilities from the
drop-down menu. This will take you to your Utilities* folder.
(*You can also get to the Disk Utility application via Applications > Utilities folder)
• Now, locate and launch the Disk Utility application.
When Disk Utility opens you will see a left side window, which will show
all connected hard drives and optical drives. It is here that you
should see your external hard drive listed in that window.
• When you locate it, simply select it and then select Partition
from the tabs on the right hand side.
• Change the Volume Scheme from Current to 1 Partition
• Make sure to provide a name for your new external hard drive.
• Select Mac OS Extended (Journaled) from the Format
drop down menu, for a bootable Mac only external hard drive.
• Or select MS-DOS from the Format drop down menu, for a bootable Mac & PC external hard drive.
From there, click the Options button, located toward the bottom of
your window.
This will open a partition scheme selection window as seen in this screen shot:
• Select GUID Partition Table for bootability on a Intel processor based
Mac.
• Or select the Apple Partition Map for bootability on a PowerPC based Mac.
• Click the OK button.
Finally, click the Partition button and allow Disk Utility to format your new external hard drive.
When this process is complete, you now have a newly formatted, ready to use hard drive.
Believe it or not, this process can be completed faster than you think.
Using this method with Disk Utility, I was able to format my new 1TB Iomega USB external in less than 20 minutes.
Final Note:
I used the external hard drive as the focus for showing you how to format and prepare your hard drive for use on your Mac, but this feature can also work with internal hard drives as well.
For more information about some of the disk repairing features of Disk Utility, here is a great support link for this nifty and quite effective Apple utility for the Mac OS X platforms:
Using Disk Utility to repair a disk
Thanks for reviewing my Mac OS X Tip!
Regards,
-Mactechtrainer
on Feb 11, 2010 | Computers & Internet
Tip
Booting a bootable Windows CD/DVD for a fresh installation when the boot order...
There have been several times that people have been stuck with a virus infected or a corrupt Windows Operating System and are finding it very difficult to get a fresh installation because of a boot order problem. It could also be a clean working Operating System but the user just wants a new one. The PC, whether laptop or desktop, could be a gift from a friend or one that they have been using for some time.
In the case of a gift from a friend, it could be that a forgotten password has been set in the bios and all has been done by the user to gain access but to no avail. There are also situations whereby the boot order is set alright to boot from CD/DVD but the PC just fails to boot from the CD. In these cases, even thought the bootable CD/DVD is in the drive, the PC just boots straight to the unwanted Operating System but you know that your CD/DVD drive works fine.
Here's what to do:
Obtain appropriate screw drivers and carefully remove the hard disk from the laptop or desktop. Now Obtain an appropriate external hard disk connector for the type of hard drive you have. In the case of a desktop hard disk, you could easily connect it as a slave hard drive in another available desktop by setting the jumper to the slave position (could be primary slave or secondary slave depending on the drives in the PC).
Try and backup any important files from the hard disk or from the partition with the Operation System in the case where more than one partition exists on the hard drive. When that is done, then you will need a Hard Disk or Partition Management Software like Windows Disk Management(which can be accessed by right-clicking on 'My Computer' and selecting 'Manage' and the 'Disk Management' in the resulting window). You can also use a third party software.
Now delete the partition and create a new Partition (Primary Partition). Then format the partition (NTFS file system recommended). When this is done, disconnect the hard disk and fix it back into the PC. Now you are ready to install a fresh Windows Operation System. Turn on the PC, Insert the bootable Operating System CD/DVD (e.g Windows XP) and there you go: your PC will automatically boot from the CD/DVD.
Wish you all the best.
on Dec 31, 2009 | Computers & Internet
How do I partition a new harddrive when I cannot get to a command prompt? I can get to Bios, but not a cammand prompt.
Try to put in your Windows disk and boot from it and allow it to partition and format the new drive.
Nov 03, 2010 | Computers & Internet
How i can format wyse x90l
You can not format the Windows Drive (referred to as windows partition) while the windows is running.
CAUTION: FORMATTING A PARTITION OR HARD DRIVE WILL RESULT IN ALL THE DATA BEING LOST.
But you can format any other drive or partition, to format a drive or partition other than the windows', open My computer right click on the drive icon and click format, press all the OKs and your drive will be formatted in a while.
To format whole hard drive, even the windows partition,
CAUTION: FORMATTING A DRIVE WILL RESULT IN LOOSING ALL THE DATA AND THE WINDOWS AS WELL.
Now back to business, to do a complete format you need a bootable cd, If you have your recovery disk or even a bootalble windows disk you can format everything.
Lets assume that you have a windows bootable cd, insert the disk while the laptop is starting (make sure that the computer boots up with the cd), let the setup load its files, then follow the instruction until you reach to the point when you can see your hard drives and its asking for formatting press F to format the drive which is highlighted.
Thats it.
Please feel free to ask me any further.
Apr 07, 2010 | WYSE X90e - C7-M 1.2 GHz ULV - RAM 512 MB...
How i can format my laptop toshiba L300D can anyone tell me how to do it plz
If you have the windows install disk, just put it in and start a new install..there will be an option come up in the installation to format the drive.
If your laptop has a second hard drive listed that is very small that the recovery partition...go to it and run the recovery program
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Aug 27, 2009 | Toshiba Satellite L300D-ST3501 Notebook
Hard drive
You need to use a Windows install disk, or the computer recovery disk.
At startup of new windows installation, chose new installation and then chose the option Format hard drive.
Note: the windows install disk must be bootable, Upgrade install disk (non bootable) does not have the format option.
Regards
Nov 05, 2008 | Toshiba Satellite A135-S4527 Notebook
Installation off New hard drive
First tell me where you are going to install this hard disk whether to be primary or secondary disk and what is your pc configuration.
Old bios does not support large volume hard disk so you have to make it partitioned with the help of a new pc and then try to install the xp or use some third party utility to format and partition the hard disk (use or download part.exe) then make a bootable cd or floppy with Windows98 or XP then run this utility
Jul 04, 2008 | Acer Aspire 3100-1405 Notebook
Hard disk failure
Hi, assuming the hdd won't finish a format, it is possible that some sectors are damaged. If you still want to try and use the hdd even with these defects, you can try and partition the hdd. Guesstimate at what point the hdd stops responding and really guess where the defects end. With this info, partition the hdd into 3 with the middle containing the defective sectors. Format only the first and third partitions. For simplicity, Win98 might be easier to work with rather than XP. Hope this be of some help. Do post again and let us know how things turn up.
May 05, 2007 | Seagate Barracuda ATA IV (ST340016A) 40 GB...
Maxtor Hard Drive Logo
81 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
