Question about RIM BlackBerry Pearl 8100
Call forwarding? i cant receive incoming calls, all calls go to my voicemail but the call forwarding is off
  • shelley0115 Mar 05, 2009
    I have a Blackberry, which was given to me by a friend. If I cannot answer a call within four rings, it goes over to voicemail. How do I get this off. I am on pay as you go with O2
  • 47 Answers
Contact your network who will be able to turn off/ reset your voicemail. There may have been a few network faults that have meant the settings dont match what it should be, this is an easy thing for them to check and correct .
Posted on Mar 14, 2008
Cannot receive calls anymore on lg p506
dial #002# send, then ##21# send. that should cancel all forwarding.
Nov 13, 2011 | Cell Phones
Incoming calls: When we receive an incoming call,
Extension call forwarding is controlled by a timer, and they put these things in the manual. If your CF after 2 rings is from a call to a specific extension, from that extension, dial *713 and a 2 digit number from 00-99 seconds on the intercom. Start with 18.
If your call forwarding is from intercept, then you have a system programming issue and need to look in the installer's manual or check with your system programmer.
Carl
Dec 01, 2010 | Panasonic KX-T7633 Corded Phone
LG CHOCOLATE: identify phone number of incoming voicemail
try transferring the calls from ur mobile to the voicemail when u r not available....
in call settings u might have an option of forwarding the incoming call after so many particular number of rings... forward the calls to ur voicemail numbers using this and then u ll have the numbers in ur recieved calls list.
this might work but is only a temporary solution
Jun 15, 2010 | LG CHOCOLATE VX8500 Cellular Phone
Voicemail is not picking up for incoming calls...
Sounds like you need to set the call forward no answer to the VM pilot DN for the set with the new mailbox.
May 26, 2010 | NorStar Startalk Flash 2 Phone
What is the feature code for forward to Voicemail? I want to forward incoming calls to the mailbox without the phone ringing.
Try FEATURE 9 8 4
this forwards all calls that ring on your phone to your voicemail. To shut it off FEATURE # 9 8 4
Oct 02, 2009 | NorStar T7316E Corded Phone
HTTC 6800 Not receiving calls in sleep mode
You want to make sure your callforwarding is on. Sometimes when you select sleep mode, the calls will divert directly to Voicemail. Plus, ensure you have signal. Without signal, by default the calls go directily to voicemail. We won't wanna miss a call here. You can follow these steps here. start
settings
phone
services
call forwarding
get settings (wait for a while)
forward all incoming phone calls (check the box)
OK
OK
Exit
In the option to forward calls, there should be an option for the amount of seconds the phone RINGS prior to forwarding directly to voicemail.
IF your HTC device doesn't have the option for voicemail, and your calls are routed else where, contact your carrier for the voicemail number. This is very important!
Cheers!
Jan 30, 2009 | HTC PPC-6800 Smartphone
INCOMING CALLS
Hi there, it is possible that you have the G1 set into "always Forward" state, which means when receiving calls the phone will forward the caller to your voicemail.
To Check and change these settings. goto the G1's Home screen, Click the "Menu" button, and then click on "Call settings". Then from here click on "Call Forwarding".
From here, the top setting should say "Always Forward" If this is set to Enabled, click on it and select Disable. This should now allow you to receive calls correctly ! if the Always forward function was disabled already, i would suggest calling T-Mobiles Customer support line to see if they have a remedy to this situation !
Hope this helps ?!
Oct 27, 2008 | HTC G1
Iphone can't receive calls
check in settings/phone to see if you have maybe turned on call forwarding and it is being forwarded automatic to your voicemail box number
Jul 17, 2008 | Apple iPhone Smartphone
INCOMING CALLS
upgrade the phone to WM6 with A3.5 @ ppcgeeks.com --> apache forums.
that will upgrade the phone's firmware at the same time as upgrading the ROM to WM6
Aug 02, 2007 | Audiovox PPC 6700
RIM BlackBerry  Pearl  8100 Logo
399 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Jerry Greenberg
Jerry Greenberg
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
