Question about LG LSC183VMA Split System Air Conditioner
ERROR CODE ON AIRCONDITIONER LG ART COOL INVERTER MODEL NUMBER LSZ244VM4
Hi we keep getting error code c6 on the inside unit, we have tried cleaning the filter and resetting the power which helps for about 5 mins then it comes up again and stops working, you cannot turn the unit off, via remote or via the button on the side of the unit. We have 2 of these units and they both have the same error code and will not work, the manual has nothing in there about error code C6. Can you please help as the weather is becoming unbearable, do I need to call someone in. We have only had these units for about 14 mths.
thanks  in advance. We bought a set of 20 units. 5 of the units have these split systems in them. The tenants have reported this problem with 5 out of 5 of them. The units are great until they turn themselves off and show the error code C6.
Haven't approached anyone before now and not in a situation to be experimenting with them. Don't know where to go for help on this one. Starting here.
  • Andrew 1964 Mar 22, 2008
    Rockhampton is the town in Queensland.
    Genius:
  • 3,422 Answers
The first thing i'll say is you will need to get it repaired by a technician and i strongly recommend you not to do it by urself.
Remote control units have diagnostic program in the
control, after 3 to 5 minutes of operating if the diagnostic
tools detect abnormal operation, then its shutdown the unit
to protect from damage. Thermistor sensor is one of the
parts that detect the operation of the unit. Out of range
or defective thermistor can shut the operation of the unit.
If your indoor and outdoor is clean start the unit in cool mode and monitor the outdoor pipes. If your suction pipe is icing or dry then your unit is under charge, but if your suction is cold and sweating then the system is ok and sure that the thermistor sensor is defective.
- Out of range thermistor sensor in both return air and freeze up sensor can cause the tripping “off “ the unit.
Goodluck..
Posted on Mar 22, 2008
    President:
  • 778 Answers
14 months old, may still be in warranty, and 5 out of 5 of your split systems exhibiting the same error code leads me to believe that yours aren't/shouldn't be the only ones with this problem.
Contact the retailer/wholesaler where you purchased them, as you should be considered a valued customer (considering you purchased 20 units) and I'm sure they will/should be anxious to correct this issue for you ASAP.
I searched the manual that IB4G2008 posted for you and found no mention of error C6 for your LG LSC183VMA systems there or any other troubleshooting resources for that matter (seems odd since you are having 5 for 5 with the same issue).
Good luck.
PS: I am an card holding EPA certified Refrigeration Tech. and believe IB4G2008 probably is also.
    Brigadier General:
  • 3,614 Answers
EC-06 = Indoor unit coil sensor fault. Disconnect from PCB measure resistance.
You need a service / repairman to this thing.
Regards
micro
  • 2,336 Answers
I found some more info here
According to this guide, it looks like you may need to call a service person to check them or you can try to do it yourself.
Good Luck.
Posted on Mar 08, 2008
    Genius:
  • 3,587 Answers
Oooooohh..this is a doozy...LG is really hard to get information from, and loads of locations DO NOT have trained service folks. Where are you anyway?
BLINKING SNOWFLAKE, FALSHING, CHANGED BATTERIES STILL FLASHING A/C DOES COOL
Try:
Check or clean air filter
Check or clean outdoor coil
Turn off power for 5 mins at the breaker and then turn power back on.
Not sure what system you have but I think you have a mini split ductless. The snow flake on the remote is blinking probably due to a trouble/error code from a fault in the system. If its a window unit, unplug it for 5 mins then try again. There are many ?'s on here that don't give us a model# & makers name/brand.
Jun 25, 2015 | Heating & Cooling
I get an error code e1 and have cleaned and replaced the filter. Runs for a couple minutes then shuts of with same message. Any ideas?
THIS SHOULD RESET IT
1 DISCONECT THE POWER PLUG FROM POWER SUPPLY 2 CLEAN FILTER 3 HOLD DOWN THE POWER ON/OF BUTON ON THE UNIT AND PLUG THE UNIT KEEP PRESSING UNTILL IT EMITS A BEEP SOUND FOR APROX 5 SECONDS 4 DISCONECT POWER AND PLUG AGAIN
IF THAT DOES NOT WORK 1 DISCONECT UNIT 2 HOLD DOWN THE MODE KEY ON THE PAD OF THE UNIT AND PLUG THE UNIT KEEP PRESSING UNTIL IT EMITS A BEEP SOUND APROX 3 SECONDS THE UNIT WILL START. 3 STOP THE UNITS OPERATION BY PRESING ON/OF 4 RESTART UNIT.
BEST OF LUCK
May 31, 2011 | Sharp AF-R120FX 12,000 BTU Comfort Touch...
Amana PTAC unit will not cool or heat. Tried reseting, checked supply voltage, ohms checked the heating element, voltage checked off of circuit borad (power everywhere except the two heater terminals)
Compressor working ?
Please follow this tips:
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Please specify, if any error code..........
Thanks. Helpful?
Jan 19, 2011 | Heating & Cooling
Our Evaporative A/C stops and we get Error C5 can any body help
Hello
Error c5 is a communication error,between the inside and outside unit.
Check your condensate pump operation,float should move freely and unit should not be full of water.
Another possibility is faulty wiring from your outside unit to the inside.
Try taking all power away from unit for 5 min and then turn on to see if it will reset.
If this doesnt work call for service.
Jan 31, 2010 | Heating & Cooling
HP 3310 all-in-one printer spilling black ink inside unit
Hi ok gave it a go I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jul 07, 2009 | HP Photosmart 3310 All-In-One InkJet...
C6 error code on LG art cool
Try turning the power off at the fuse box, waiting 5 minutes turning the system back on and spray some water on the vents on the side of the outside condenser. If the fan isnt spining get a twig and spin it in an anti-clockwise direction after 1 or 2 spins it should start spinning on its own. continue to hose the vents with water for another 5 minutes. Its important to have the fan spinning as it extracts the heat from the condenser box.
Jan 03, 2009 | LG LSC121PMA Split System Air Conditioner
Kyocera Mita KM 1500
Still sounds like there is a problem with the fuser unit. The technician that replaced the parts should be able to troubleshoot the problem.
C6 = Fuser error. The unit is not heating up due to a bad Fuser lamp, fuse, or thermostat, or bad thermistor.
The circuit is open, and the machine won't work til the problem is repaired. Once open circuit is repaired/closed, the machine should reset on it's own after you power the machine down and back up.
Does the machine flash the C6 right away as soon as you turn it on OR, does the C6 show up after about 3-5 minutes?
If you get the C6 right away, then the circuit is open, and that needs to be fixed.
If you get a c6 after 3-5 minutes, then there is a good chance the lamp is bad.
Hope this helps.
Good luck
Feb 08, 2008 | Video Cameras
Air conditioner
- If your indoor and outdoor is clean start the unit in cool mode and monitor the outdoor pipes. If your suction pipe is icing or dry then your unit is under charge, but if your suction is cold and sweating then the system is ok and sure that the thermistor sensor is defective.
- Out of range thermistor sensor in both return air and freeze up sensor can cause the tripping “off “ the unit. The resistance of both thermistor is 8 to 10k ohms@25 deg. C temp. , so can test by using ohm meter.
- Try also to check the voltage in you area if normal, loose ac outlet.
- Be sure that unit is clean no obstruction in your air out and air in.
- Unplug the unit to reset the c6 error.
Jan 10, 2008 | Heating & Cooling
Error C6 on lg cool art is common. you guy need a new CAPACITOR. cost $7.05c aud. it's 6uF 450vac.
take about less than 10min to install.
my lg model is lsz244vm-4, it's run well now.
Jan 02, 2008 | Heating & Cooling
LG LSC183VMA Split System Air Conditioner Logo
2,279 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
