My e-machine desktop wont start, and makes a weird noise plus the monitor is blank
  • 2 more comments
  • damarise12 Mar 08, 2008
    it sounds like tata, tata, and when it starts, stays on for couple of hours, it doent respond with when I press the mouse, or the keyboard the only way I cant turn it off is by disconnecting the power suply
    thank you you know the fans turn on, really the only thing I want to do is save some files that I have there
  • damarise12 Mar 09, 2008
    Thanks for your help, the model #is T2042
  • cjain007 Apr 11, 2008
    i also have a same problem of memory dumping. monitor is blank and nothing is working.
    President:
  • 2,351 Answers
Try to describe the weird noise a wee bit better. Does the weird noise sound more like a series beeps?
While standing in front of the PC case. Remove the left side case panel. Look closely in to the case while it attempts to start up. Do you see any fans & are they spinning? Most Pc's give off warning beeps when there is a problem. Beeps like, (1 short & three long) is a code that can tell what part may be failling.
It would help if you listed your operating system & the model number of your Emachine.
What was the last thing you were doing or (software installed) before the PC started making this weird noise.
Anything else that you may have heard or remember will also help.
Please post back as I do a bit of searching.
Thank you.
Posted on Mar 08, 2008
  • Mike Peluso
    Mike Peluso Mar 08, 2008
    Hello again damarise12,
    Using your description it may be the hard drive's spindle. That does not mean you can not get your data off of the drive.
    Each time you turn on the PC your wearing down the hard drive. Soon you may not be able to remove your data. Suggest you pull the drive from the system. If it is an IDE drive, (it's connected with a 40 or 80 pin data cable). Slave your hard drive into another computer. Set your drives jumper to function as a slave drive.
    Once in another system the odds are you'll be able to pull some & maybe all your data off. (hopefully).
    If you can not get access to another PC to do this, than buy a new drive for your eMachine. damarise12 you did not mention the model no# so I am unable to suggest another drive & do not know if the system takes a serial ATA SATA or an IDE drive.
    There is no guarantee that your data will be retrievable.
    It's a shot worth taking though.
    Sergeant:
    Champion:
  • 277 Answers
Try to check the memory
Lenovo c355 monitor wont come on at start up
I recommend turning the computer off then double-checking all connections to the monitor. Additionally, if you have another monitor, you could connect it, to see if it works.
Sep 02, 2014 | Lenovo C355 20" AIO AMD 4GB 1TB
The computer has a pink screen and wont do anything
Pink screen is usually either
Broken video cable to the monitor
Broken video card
Broken monitor
Try the machine with a different monitor cable and a different monitor. What happens?
In terms of troubleshooting can you provide more detail
What specifcally happens when you boot the machine up. Does it have a black screen that has typing on it which then changes to pink later? Do you see any writing at all while it is booting?
Does the hard drive make the usual noises during the startup?
Jun 24, 2014 | iBuyPower Extreme 915SLC Desktop 2.66GHz,...
The PC gives a stable yellow light when turned on and it also gives a weird noise.Nothing appears on the monitor . The CD Rom works though
If it gives continuous beeps(weird noise) than your Memory(RAM) failed. you have to replace it, your computer wont Start
Apr 26, 2011 | Computers & Internet
My dell plex gx620 will turn on make some weird buzzing noises and stay on but it will never display anything on the monitor and there is nothing wron with the monitor
I have the same problem. I think it might be that the computer is not powering on all the way do to overheating. Try replaceing the CPU fan.
Jun 30, 2010 | Dell OptiPlex GX620 PC Desktop
Have a problem with my machine T3092. The monitor
Stop using the restore disc, try installing the OS instead and make sure you have your driver software
Dec 18, 2009 | E-Machines eMachines Desktop PC
No screen picture
You should first try to find out if it is a screen problem. Turn the machine down, and plug a monitor to it. Turn monitor on, power up the computer and see if you get anything on the monitor. If you get something (like the boot screen) on the monitor then it is not your screen. You will be able to troubleshoot further by going into Bios Setting.
Hope it gives you a statring point.
Aug 28, 2009 | Toshiba Satellite A135-S4527 Notebook
Weird rubbing or mild grinding noise when in spin cycle.
It sounds like the bearings on your tub are going. This is an expensive and difficult job to do. (approx $450 parts and labour and you may do more damage trying to take it apart)
Feb 07, 2009 | Kenmore HE2 Plus Front Load Washer
Monitor Buzz on start -up
Try a different monitor or this monitor on a different computer. If it makes same noise on different machine or new monitor makes no noise on your machine you need a new one.
Dec 24, 2008 | Computers & Internet
Computers & Internet Logo
289 people viewed this question
Alun Cox
David Payne
David Payne
