Question about Refrigerators
Fridge frequency Purchased Daewoo FRS2411S fridge in middle east some years ago, yet to use it (still in box) now home in Australia, box says 220 volt 60 Hz - Australian Hz is 50 Hz. How will this affect the running of refrigerator and can parts be changed to comply with frequency here ?
    Novelist:
  • 155 Answers
AC voltage (alternating current) rapidly changes from +ve to -ve and back again. The frequency with which it changes each second is measured in Hertz (Hz for short).
The speed of an AC motor (which is what you have in the fridge's compressor) is dictated by the AC frequency.
What this means is that if you connect a motor designed for a 60Hz supply to a 50Hz supply (which is what you'll be doing) it will only run at 80% of its intended speed.
Whereas running it faster than intended might cause damage to the motor, running it slower is highly unlikely to.
The only real effect that you will see is that the fridge will take longer to initially get cold and the compressor may run for longer periods to maintain the temperature. There is a slim chance that the fridge may also struggle to achieve the coldest setting.
Changing the compressor is not a simple job and needs to be done by an expert as it involves re-gassing the system.
Personally, I would just use it as it is and see how you get on.
Hope this helps,
Matt.
Posted on Mar 08, 2008
Top box purchased in australia/should it work in NZ
If the power source is 220-240 volts it should work. However the problem will be that you will have to go into the menu program and reset the area format. You will find pal and several other names with nz next to it . Contact a repairman and find out the tv reception format for NZ
Apr 28, 2013 | Computers & Internet
I have a Toshiba laptop I bought while working in the Middle East. How do I get the Laptop to work when I go back to the USA? The Laptop is 220.
Check the power adapter, it may have an variable input voltage 110 to 220 AC volts, then you only need to get a travel mains voltage converter to suit the US mains outlet.
Otherwise you need to buy a new Toshiba power adapter that operates on 110 AC volts.
Mar 26, 2013 | Toshiba Satellite Computers & Internet
I just bought KitchenAid Artisan Stand Mixer KSM150PS with 110v and 60Hz online and received it today and realised I cannot use it on australia. Can I use transformer which I can get here to convert 110V...
You need a Step Down Voltage Converter (also called a Voltage Transformer)
which steps down 240, 230, 220 volts to 110 volts and
allows you to use 110 volts Devices from USA in 220 v / 230 v / 240 v Countries
Aug 10, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Can the epson projector 8700ub be used in Australia with our power suppy being 230 volts? Thanks. Mr Tay thengtay@hotmail.com
Rated frequency 50/60 Hz AC Power supply 100 to 120 VAC:
3.1 A (Home Cinema 8350) 3.3 A (Home Cinema 8700 UB) 200 to 240 VAC:
1.3 A (Home Cinema 8350) 1.5 A (Home Cinema 8700 UB) Power consumption 100 to 120 VAC: Operating: 272 W (Home Cinema 8350) 297 W (Home Cinema 8700 UB) Standby: 0.2 W 220 to 240 VAC:
download the manual for this model
Techbelkin
thanks for rate me.
Jan 08, 2011 | Epson Power Supply 110/200 VAC Switchable...
Does this model support PAL color system? I misplaced my user manual and i am unable to change settings.
Where did u bought this LCD tv,if u buy it in the US,Mexico or Canada no it only work with a NTSC signal frequencies.If buy in Europe,Asia,Australia,Middle East or Africa.Yes,it will work with PAL signal frequencies.
Dec 06, 2010 | Televison & Video
I have COBY TF-TV1902 and I'm wondering if it would work in Europe. Many thanks!
If this DVD player was bought in the Middle East,Australia,Asia all used the PAL signal frequecies same as Europe,than yes.If this was bought in the US,Canada or Mexico,than no they used NTSC signal frequencies totally diffrence from Europe.
Nov 29, 2010 | Coby Televison & Video
I HAVE GLEM GAS COOKING RANGE PURCHASED 6 YRS BEFORE FRM SAUDI ARABIA. NOW IN INDIA CHENNAI. PLS LET ME KNOW THE SERVICE CENTRE DETILS
Please give me details of Glem gas cooking range service centres in Kerala . My id -mecentpl@yahoo.com
Nov 14, 2010 | Ovens
Purchases a makita compound sa wUSA can i use it in AUStralia
The only obvious problem is that a saw purchased in USA will have a 110 volt motor. Mains voltage in Australia is 220, so you would need to purchase a transformer in Australia to step the voltage down to 110.
Dec 29, 2009 | Makita 10" Dual Bevel Sliding Compound...
Where in Sydney can I purchase a replacement lamp for a Daewoo KOC 984 Microwave oven.
Normally a grocer or department store or hardware store will sell replacement bulbs of this type.
You can take the old one with you.
Otherwise, try:
Daewoo Electronics Australia PTY. Limited. (DEA)
Unit Q5, Regents Park Estate Princes Road East, Regents Park NSW 2143, Australia
Tel: 61-2-9738-5111
Fax: 61-2-9738-5511
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 25, 2008 | Microwave Ovens
Refrigerators Logo
98 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
