Question about Casio Exilim Zoom EX-Z700 Digital Camera
"Card Error" When I place a memory card into my camera, it says, "Card Error." I have used this card before, and it worked perfectly fine, but now it does not. I have tried using other cards, but they also do not work. How can I fix this?
  • Anonymous Feb 03, 2009
    i just brought this camera and its not working with the Panasonic memory card.Every time i turn it on it says "card ERROR" is there any other way to fix this problem then buying a new momory card?
  • 374 Answers
You MUST FIRST format ANY memory card that you plan on using with this camera. Otherwise we can't guarantee that they will work. Also, Casio has only tested 3 brands of memory cards and can say for sure that they will work with their cameras.....those brands are Toshiba, Panasonic and Sandisc. If it is neither of the above I would recommend getting a different card and making sure that you format it WITH THE CAMERA BEFORE USING. :)
Posted on Sep 12, 2008
Xd picture card will not click into place on Olympus e-420. Results in prompt "card reader error."
Are you sure it is a xD card and not an SDXC?
Then there should be a little arrow, pointing in the direction it should be going while inserting.
Try to eject the card and reinsert the card.
If you never used a xD card, and nobody else ever tried to put something in the slot, the card should go in smooth.
After placing the card, don't forget to format the card in the camera.
Sep 18, 2014 | Olympus E-420 Digital Camera
Memory card error
Hi. It sounds like the pins are bent. Use a flashlight to see IG you can see them. If they are bent, try and use something flat to push back into place. If not you may have to send it in for service.
Feb 25, 2014 | Pentax Optio 430RS Digital Camera
SD card won't stay in the slot of my Panasonic Lumix DMC-SL80
is the lock on the card by chance. also depending on how old the camera is and how big the sd card is in gb. the lumix may not be able to handle that size of card, too many gb. My lumix would only accept up to 4 gb, so when I moved to 16 they did not work.
Oct 04, 2017 | Nikon Coolpix S210 Digital Camera
THE CAMERA BRINGING A NOTICE ON A SCREEN ERROR CF.WHAT IS POSSIBLE THE PROBLEM.
Digital Camera: How to Fix Compact Flash Memory Cards ErrorIt is not very typical for compact flash memory cards to give you an error. If you do receive an error, it most likely means that a pin within your CF card slot is bent, or your CF card has become corrupted. Unfortunately, if your CF card has become corrupted, you will need to reformat the memory card, which means that you may lose any pictures that were located on the card.
Fixing Your Flash Memory Card
You will want to remove your CF card and the batteries. Take a look inside the CF card slot to see if there is a bent pin. If you find a bent pin, you can correct this problem using a very small and skinny flat screwdriver. Moving very slowly, use the screwdriver to bend the pin back into place. You do not want to use enough force to make the pin back in one shot.
The pin does not have to be perfectly straight, but get it as close to straight as possible. Insert your CF card back into the slow very slowly. You should see the in align itself with the card. You can turn your digital camera on to verify that the compact flash memory card is now working.
Mar 11, 2011 | Cameras
I have replaced the battery and memory card, the camera keeps saying I need to format the card, but then it says it is formatting, then gives another message saying the card needs to be formatted....
If the memory card replacement is an SDHC model card the Kodak z740 will not work with it. The memory card has to be a standard SD card of 2 gig size or less to properly function. Take card out and turn on camera. See if you get same error. You should get missing card error but otherwise be able to operate camera controls such as zoom, flash, etc. If that is fine find old card you used and place back in camera... or purchase a standard SD card from Walmart for 10 dollars
Jun 11, 2010 | Kodak EasyShare Z740 Digital Camera
Takes perfect pictures then shows read error or memory card error & freezes
format the memory card and then try!! if this doesn't work buy a new memory card ...
Sep 26, 2008 | Fuji Cameras
Card error on my memory card
i have sold kingston sandisk and pny cards for years-sandisk excellent pny fine kingston is ****-made by pny but just not the same-switch card out asap and change brands-cards are slow and unreliable
Nov 20, 2007 | Casio Exilim Card EX-S100 Digital Camera
Camera won't work if the memory card is inserted
Don't know if that works for you.
I just use another memory card.
I have 1 card my P505 doesn't work with.
Others are fine.
Hope this helps.
Rosi
Oct 16, 2007 | Casio Exilim Pro EX-P505 Digital Camera
Camera will not read memory card
Make sure you format your memory card before you try to use it other wise it will save the pics to ur internal memory instead of the mem card.
May 01, 2007 | Casio EXILIM ZOOM EX-Z10 Digital Camera
Casio Exilim Zoom EX-Z700 Digital Camera Logo
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
