Question about Compaq FS7600 17" Flat Glass Monitor
Sound My speakers work, but there is no sound on my computer. my computer do not have mixer device in the system i was told to apply a audio drivers and i will be able to listen to music on the computer could you tell me what to do to get volume.
    Sergeant:
    Champion:
  • 277 Answers
Go to cmos setup and enable sound device
then go to device manager and remove all auknown software,
restart the computer,
reinstall sound driver.
Posted on Mar 08, 2008
I installed windows 7 home premium; now the sound card, previously used with XP, will not work .
Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers. Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software. Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers. Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker. You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply Hope this helps
Dec 27, 2012 | HP Pavilion a1640n (RC663AA) PC Desktop
No sound from my speakers after i pluged the into a dell desktop
Look for speaker icon in task area (right side of task bar). If there is a red x on it it means the speakers are muted or the sound device drivers are not loaded or the sound device is disabled. Click on speaker icon and go to mixer. Check for muting. If it says sound device is not present then open Control Panel by clicking on Start or Windows button in lower left corner, go to Control panel, often abbreviated "CP" then click on system then on device manager and see if Sound, video and game controllers has an audio device listed. If not you'll have to acquire the drivers from the dell driver download site and apply them. If it does and device shows disabled, then click on it and enable it. If there is no sound device then check for an "Other device" entry in device manager. It'll usually have a yellow ! on it. That means a device was identified by plug and play but the system could not find a driver for it. Go to windows update service in CP and run find updates. If Windows finds an upated sound driver, install it. It will install and plug and play and set up device. Otherwise off to www.dell.com with the service tag number of the computer---found on back or top of system. This will lead to the downloads and drivers page for your specific box. Look down list for Sound drivers, download and install them. Usually with dell it downloads as an executable (Rnnnnnn.exe) and all you have to do it click on the file name to run and install it. After download If in Vista or Windows 7 I always right click on file name and chose "Run as administrator" whenever installing like that. That makes sure you have adequate permissions to do the install and have to install correctly.
Also it goes without saying to make sure you have plugged the audio in lead to speaker set into the correct sound plug on back plane of system (usually the green one).
Feb 20, 2012 | Boston Acoustics BA735 Computer Speakers
Have Koss hd-50 (hand me down) would like a diagram, have no sound, running winxp on dell xperion 8400, says "no active mixer devices"
i will go through the process of setting up sound on your computer
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
if you need more help with this post a reply
hope this helps you
Sep 21, 2011 | Koss HD 50 Computer Speakers
Mixer turns on, but no sound on any channel... If I move the slider up and down I hear scratching and popping noises from speakers but no music... Any idea what the problem might be or can you tell me if...
The list is too long to post here... and you have not told us the configuration of your system. There are hundreds of mistake an operator can make... and you don't tell us what the "speakers" are you are mentioning... I ASSUME that these are NOT just computer speakers. From the main outputs you should have BALANCED cables (TRS or XLR) cables tying to your amplifies or powered speakers. Put a signal into channel 1 and make sure the mute button is up for that channel... move the main fader up and some sound should go through. When tied to a PC you have to have drivers installed and WIndows configured to use the mixer for VOICE input and SOUND recording in "Sounds and Devices" in the Windows control panel. Use headphones to verify the audio is going through the mixing buss portion of the mixer.
Aug 16, 2011 | Behringer XENYX 2442FX Mixer
I'm using my mixer with my computer and just tried it for the first time yesterday and can't get any sound. I have a mic plugged into the mixer and the mixer connected by USB cord to the computer. ...
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it hope this helps
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Jun 24, 2011 | Peavey Computers & Internet
No audio device, mixer device, sound device for my matsonic 9158E+ motherboard possibly loss from a previous formatting. please send me free download for said problem. tanx
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer dont forget to vote
hope this helps
Feb 02, 2011 | Matsonic MS9158E+ Motherboard
No sound in speakers everything is correct
Hi there
You need to update your sound drivers,to do this go to start menu on your computer and type in the word "device manager",select it from a list of options and click on it you will see a list of components/devices that are working with your computer select the "sound" component.
Click on it and you will see your sound driver,right click the sound driver and you will see a list of options select "update driver software" this automatically search for updates,download them and install it in your computer.
You will have to restart your system for the update to work properly.
Sep 02, 2010 | Microsoft Windows XP Professional for PC
I can't heard no music why?
Several possibilities come to mind: speakers have failed (self-powered speakers have bad power brick, cable damaged, etc), speakers plugged into the wrong port (audio in instead of audio out), audio card or driver has failed.
If you recently had to restore your OS (or do a roll-back to a "known" good configuration), check your audio device (make and model) and make sure you have the latest driver installed. (Look at the website for your computer if it is a prebuilt system or look up your motherboard if it is an on-board audio device.) The device manager might have a yellow exclamation mark on the audio device if this is the issue (access from the Windows Control Panel)
Check for bad speakers by trying another set of speakers or plugging them into another computer. (Swap cables if that is possible.)
I hope this helps.
Apr 23, 2010 | Dell Inspiron 530 Desktop Computer
I am not getting any sound from desktop speakers..i have sony driver installed
Onboard audio is disabled in the BIOS
The BIOS Setup program is accessed by pressing the <F2> key after the Power-On Self-Test (POST) memory test begins and before the operating system boot begins. Go to the Advanced > Peripheral Configuration menu to make sure onboard audio is enabled.
Audio settings in the sound mixer are incorrect
Check your audio mixer software to ensure audio is not muted or the volume level is not turned too low.
The speakers or headphones may be connected to the wrong jacks
Make sure you connect all speakers to the correct jacks. If you connect them to line-in or microphone jacks, they won't work.
Audio drivers are not properly installed
Check Device Manager under the Sound, video and game controllers section for any errors associated with the audio driver. Reinstall the audio driver if necessary.
Audio to back panel is muted if front panel is connected
Check your audio mixer software for a setting that mutes back panel audio if you have plugged headphones into a front panel audio solution. Uncheck this setting to allow audio to both the back and front.
Sound Playback is set to wrong device
In Control Panel > Sounds and Audio Devices, go to the Audio tab. Check the default device for sound playback; there may be multiple selections. Select the desired device, either rear panel or front panel.
Mar 06, 2010 | Office Equipment & Supplies
Logitech
1.
Lets start with the obvious. Make sure the volume mixer control is not muted. This is usually a speaker icon at the bottom of the screen. If you do not see this then go to control panel, sounds and audio devices, and make sure nothing is muted.
2.
check device manager. This can be done in Win XP by right clicking my computer, properties, hardware, then click device manager. Alternative way to enter device manager is by clicking start menu, control panel, system (performance and maintenance), hardware then device manager.
In the deice manager window see if any question marks or exclamation points are visible.
If so, see if it the mark is for an audio device.
If it is an audio device, uninstall the device.
Next, try to install the sound card driver again. If that fails, the enter the device manager and uninstall the sound card again, restart the PC, ignore the hardware manager, and try to install the sound card driver software again.
Jul 09, 2009 | Logitech X-530 Computer Speakers
Compaq FS7600 17" Flat Glass Monitor Logo
90 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
