Question about Sony Xplod XM-1652Z Car Audio Amplifier
Problem with amp?
Ok, i have a xplod 1000w amp,with a single kicker cvt 12, and at low, very low volume you hear a low sound of distortion, this a new sub, and the old did not do this, at high volumes,the noise goes away and sounds good, this is only at low sounds, any advice would be appreciated
Give that new sub a chance to "break in". New speakers require a few hours of use before the voice coil(s) and spider break in and began operating at their best performance. Is the box within the operating specs of the sub? Is this a ported box; if so you will here some turbulance type noise from the port. What type of distortion are you hearing? Alternator noise(dentist drill like sound) would only be noticable through a sub at lower volumes due to the frequency response of a sub. Is the amps lowpass crossover turned on?
Posted on Mar 21, 2008
Kicker solo baric l7 12" has distortion at low volume. What could cause this?
It sounds like the cone is distorted. If it's a paper cone, it may have gotten wet. If it's a poly cone, it may have been exposed to too much heat (sunlight?).
Also check the wiring; anything loose may make a rattling sound.
Last, the problem may not be in the speaker at all - it may be a problem with the amp.
Jul 29, 2014 | Car Audio & Video
Speaker blown?
disconnect the amp and do a "pop" test with a 9v battery, it should be clear and no rattle... if it rattles sub is blown
Jan 29, 2014 | Kicker Comp CVT 12 Car Subwoofer
CAN I USE THE AMP FOR TWO 12" KICKER CVT SUBS SINGLE COIL
yeah if u want to use a 2 channel just connect the outside - form one to the amp then the middle + and - together then the other + to the amp
Aug 11, 2010 | DB Drive SPA1000.1 Car Audio Amplifier
Best way to connect a 15'' kicker cvr15 4 ohm dvc [single sealed box] and a volfenhag zx-4712 1000w 12'' 4ohm+4ohm dvc to my pyle 885 1000w 4 ch. bridgeable amp and how to wire the voice coils that are in...
best way is to just run the volfenhag with a set of wires for 2 channells(one set per coil) left and right @ 4 ohms per channell. The CVRs you can parallel the coils(2 ohms) and run a set from each sub to the amp in stereo left and right. This will give the kickers a little more juice than the 12 but should be fine.
Jan 25, 2010 | Rockford Fosgate Car Audio & Video
Distorted sound.
try to set up again may be cable instalation not properly to set
Aug 13, 2009 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
What duz level adjustment do
The level control controls the input level coming from your head unit (receiver) to the amp.
Your Sony users manual is a little vague on how to best adjust the level and other controls.
Here is one method that some installers use and works well with most amps.
Most 10" subs sound best between about 80-100hz and below, so start out by setting the LPF at about 80hz. The HPF will not be used. Next turn the bass boost and gain all the way down. Turn on the radio and set all tone controls, bass, midrange, treble to flat, usually "0" on most head units. Turn the volume up to approximately 3/4 volume level or just until you begin to hear distortion. Now, back the volume down until the distortion is gone. Next turn up the gain control on the amp until you hear the subs start to distort then back the gain down until the distortion disappears. Next turn the bass boost up again until the subs begin to distort, then either back the bass boost down or back the gain down until the distortion is gone. You may need to play around with the bass boost and gain controls to get exactly the sound you prefer.
Hope this helps.
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Will this give me what I want
I perfer a sound stream reference 500, it is a great amp. I had 4 Kicker comps 12", and man the boooom. What you have is good, if you have them bridged.
Jan 15, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Distortion from an unboxed 12''
hook the leads up to a wire connected to a 120v wall outlet and the problem wont bother you any more.
Jun 01, 2008 | Sony 12" Single-Voice-Coil 4-Ohm Subwoofer
Sony Xplod 500w green power light no sound
try running the system with a cross-over configuration.
So your left + will be left + and your right + will be in the right + but put the right (-) where the left (-) is and left (-) where the right (-) is. If that doesnt work, then that means that you shorted out your audio out channels. the only way you can fix that is if you have good soldering skills. But other than that I'de say scrap it, unless you have the high outputs and then buy another amp, some mids and highs and connect the mids and highs to the xplod
Feb 23, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
1000 watt amp sony xplod
That's not a 1000w amp. It's a 400 watt amp when loaded to it's lowest rated load. If you have one speaker per channel (the only safe load if you have single 4 ohm coil speakers), you're only getting 165 watts/speaker. It's probably distorted because you're driving it to clipping.
Jan 01, 2008 | Car Audio & Video
Sony Xplod XM-1652Z Car Audio Amplifier Logo
115 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
