Question about KitchenAid Architect Series KEMC308KSS Electric Double Oven
DOOR ASSY My micowave door broke is the SS door where the handle is, Does anyone knows where to order the SS door?. Marcone has the glass an rest of parts, but can not get me the actual SS door. Anyone?
  • KitchenAid Master
  • 2,651 Answers
That particular door (if your model is indeed kemc308kss-- micro/ oven combonation) is not available as an assy you would need to replace the components that are broken indvidually.
Posted on Mar 09, 2008
The black tinted outer glass of my univa stove broke in pieces, can you replace it or make another glass the same?
Go to and put in your model number and look up the glass. They will give you the price. I know on most models u can order the glass without buying the whole door.
Apr 23, 2014 | Maytag Ovens
Taking apart a NEFF oven door
The inner door glass is held on by two clips at the bottom (hinge side) and two slides near the handle side. Remove the door from the oven and lie it the worktop flat with the hinges uppermost. Near the hinges you will see the glass is angles leaving a triangle of metal frame either side near the hinges.Rest the outside of your hand on the metal for purchase and then pull on the glass along the bottom edge (reasonable tug required) this will disengage the bottom clips and then slide the glass down about an inch to remove completely.
Mar 21, 2013 | Neff U1661 Double circotherm super...
Oven broiler or bake doesnt work glass burners work clock doesnt work keeps beeping and trying to lock door
Hi, Mrsatow, Sorry, to give you some bad news. Your Clock Module/Oven Control Assembly is bad
and needs to be replaced. This item probably will cost you in the neighborhood of $200.00 plus labor to install You will have to provide your parts dealer such as Marcone Appliances or Sears with a model number in order to order this part. Hopes this help! Handy Henry
Apr 09, 2011 | Kenmore Ovens
My glass on the inside of the oven door broke. can I still use the oven?
You will run the risk of break the rest of the glas....
get it replaced or replace it your self...
Range/Stove/ Oven Door Glass Replacement
Aug 08, 2010 | Ovens
I need to replace the glass door front on my GE Profile 27" double wall oven JK955. Other than the outside glass being broken the rest of the door is fine. Can I purchase replacement glass?
Yes, but i believe it comes with the door handle already attached. Full model number, upper or lower and color is needed for looking up the part number. Expect to pay $210-280
Mar 03, 2010 | Ovens
Broke the glass front to my Dacor CPO230B wall oven. the manufacturer no longer makes the part. What would the solution be to this problem.
If you dig deep enough on Google, you'll find someone who has the part. As with all manufacturers, none of them make the entire product. Bic makes pens for "off brands", Staples products come from a myriad of manufacturers, Kirkland, the house brand for Costco, all come from various sources. Hopefully, the part that's ordered will fit. We've also located the entire door. So just in case the front glass is not available, the door is, and that's an expensive alternative. I've also considered going to a glass company to have a piece of tempered black glass cut to size. My entire dilemma stemmed from changing the interior bulb in the bottom oven, when putting the door back on, it slipped in my hands and the rest is now history.
Dec 01, 2009 | Ovens
Whirlpool under counter oven, inside glass door broke.
To get to the glass on the inside of the door you need to do the steps listed.
1. Open door 4" and pull straight up at that angle
2. Lay door on flat surface with the handle down to surface.
3. Remove all screws that you see .
4. The inner housing should be removable now.
Then you should see the glass. Reverse the steps to put back together.
Good Luck with the fix.
Dec 17, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Door Glass
The only solution seems to be ordering a custom glass piece matching the dimension of the glass on the oven door. However, since my oven is white I would like the door to be white too. Although I have found glass guys who can tint the glass door dark, I have not found anyone who can color it white. Let me know if anyone knows such a glass vendor.
Mar 14, 2008 | Amana AOGD2750 Gas Double Oven
KitchenAid Architect Series KEMC308KSS Electric Double Oven Logo
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
