Help me remove the Guide Plus Grid on my RCA television
We just moved and chose to go with DIRECT TV. Our RCA television has a Guide Plus Gold (Gemstar) component.
When we were using Comcast at our last house, we just punched Enter on our remote and the Guide Plus grid (that covered the TV picture) went off after a couple of seconds. On the new TV the Direct TV istaller was unable to figure out on the Direct TV remote how to make the Guide Plus grid go off. He finally figured out that if you get up and go to the TV and punch MENU the grid will go off in a couple of seconds. But punching MENU on the Direct TV remote will not make it go off. How do we get rid of this Guide Plus system so that we can use the TV without having to get up and walk to the TV everytime we turn it on? Thank you. Beckie Johnson
  • Anonymous Apr 12, 2009
    i have the same trouble and with the addition that my son destroyed the remote so now we have no recourse i can figure but to have to get up and turn it on. new universal remote won't even eradicate the guideplus gold. Any ideas?
  • Anonymous Apr 28, 2009
    HOW DO YOU PERMANANTLY REMOVE THIS STUPID GUIDE.....I PRESS CLEAR ON THE REMOTE AND A FEW SECONDS LATER HERE IT IS AGAIN!!!!!!!!!!
    CANT EVEN WATCH A MOVIE .........
Simply enter 00000 for the zip code and complete the set up process; if you're in Canada, select the USA as your country and use the zip. However, you MUST complete the set up, including allowing the TV to search for appropriate code. In the long scheme of things, location and codes don't really matter because you won't see the GUIDE again.
Posted on Jan 21, 2011
  • Patricia Burns
    Patricia Burns Dec 11, 2013
    Thank you that fixed my problem
  • Merlin Morris Aug 09, 2015
    Thank you also. I should have known.
I have Direct TV and am able to use the exit key to remove the guide. You have to program your Direct TV Remote to the correct code. I finally found code 11147 that worked. Other codes will turn the TV on and off, but only 11147 let the exit key work to remove the Guide Plus Menu. I have to hit the exit key two times to make it work.
Posted on Dec 19, 2009
  • 3 Answers
Using your RCA tv remove, press the TV button then press the CLEAR button - the grid then disappears from the screen. I have DishNetwork and this is what works for me.
Posted on Apr 19, 2009
  • Carol Apr 19, 2009
    Using your RCA tv remote, press the TV button then press the CLEAR button - the Guide Plus grid then disappears from the screen. I have Dish Network and this is what works for me.
    Can you tell me how to completely remove Guide Plus?
I have about the same problem, Our remote to our RCA quit working and it is an aggravation to have to get upn and turn the tv off and on in order to clear the Guide Plus screen. How can I remove Guide plus permanently without a remote? I also have Direct TV
Posted on Jul 22, 2009
If you have DISH NETWORK using your remote programmed for the TV. HIT the CANCEL BUTTON on your DISH NETWORK REMOTE.
The annoying stupid useless screen goes away, but it will come back next time! A full remove feature is not there what a poorly designed system this is!
If you have DIRECT TV, try all the buttons maybe it will work.
CANCEL EXIT something of that nature might do it!
You can also Turn the tv off and on manually with the button on front of TV it will remove the guide screen. But this defeats the purpose of using a remote!
Also, a RCA Universal remote will work completely with most if not ALL RCA Products!
Posted on Dec 17, 2009
  • cokerewards Dec 17, 2009
    Sorry, I missed a step! For DISH NETWORK, You must press the TV button first on your dish remote & then hit cancel for it to remove the guide. :O)
Volume broke
yes. unplug. wait 2 minutes, plug back in. turn on. with factory remote control for tv press.....menu, 7, 1, go-back, tv....... easy
Nov 13, 2009 | RCA Televison & Video
Picked up tv from friend and cant get it to work
yes. you need to reset guide plus+. with factory tv remote, press.... menu, 7, 1, go-back, tv........ then press menu, 7, 1 , go-back, who-input....... then it will ask you to set up tv with your zip-code.
Nov 09, 2009 | RCA Televison & Video
Using RCA P61939 without Guide Plus
Guide plus still works even if you don't have the wand hooked up. In the setup section of the guide plus there are several questions that must be answered properly or it won't function as you would like. It maybe labeled as options as well. Thanks
Oct 02, 2009 | RCA P61939 61" Rear Projection Television
Our TV is stuck on a guide plus screen
i actually dont know what that is...mindboggling, right? call your tv company.
Jun 29, 2009 | RCA R52WH73 Projection Television
Guide plus on my rca p52937 tv
You are right, the Guide Plus is transmitted to your tv over the air. If you have a cable company supplying your programs, your Guide Plus will not receive a signal to set up. You will need to get a two-way splitter. It has two connections on one side and one on the other. The side that has one connection goes to your tv. The side that has two connections will connect to your cable supplier and the other to a rabbit ear or outside antenna. Then the tv has to be off over night to restore your Guide Plus.
prs1c-2266633t98.jpg 2-Way Gold-Plated Bidirectional Splitter pixel.gif Model: 15-2587 | Catalog #: 15-2587 pixel.gif
Use this 2-way gold-plated bidirectional splitter to divide a signal to feed two devices, such as TV...
Jan 30, 2009 | RCA P46924 46" Rear Projection Television
RCA Gold Plus+ Guide problem
go to menu and find the automatic set up of your channel
May 27, 2008 | RCA 32F531T 32" TV
RCA TV f27422 TURN OFF THE GUIDE PLUS
Remove your zip code, I had the same problem, when I removed the zip code it went away.
Feb 09, 2008 | RCA F32650 32" TV
Rca guide plus gold 32'
pull the ac plug for about 5 min and start your set up again paying atention to the features you want and don;t.set the menu to suite your requirements.
Jan 16, 2008 | RCA 32F531T 32" TV
RCA F32450 TV
Question?
Whenever I turn on the television, the GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes on.
Answer:
The GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes up when you use the TV button on the remote to turn on the TV. There are several ways to turn off this function if you wish, depending on your model.
Option A:
Select the GUIDE Plus+™ Menu from the Main menu.
Select Setup.
Select Options.
Select Off.
Option B:
Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
Select Off.
Option C:
Press GUIDE on your remote control.
Select the Menu bar.
Press the right arrow button to select Setup.
Choose Review Options.
Select Off.
I know Option C worked for me!!
Given the many TV models, it's possible that accessing control of this feature in the Program Guide menu may differ on your TV. For specific instructions for your model, see your owner's manual.
Oct 27, 2007 | RCA F32450 32" TV
RCA Guide plus gold gemstar T.V
I have a guide plus gold gemstar tv and I cant program my direct tv remote or Innovage jumbo remote to operate the tv, can anyone help?
Oct 22, 2007 | RCA F32450 32" TV
Televison & Video Logo
5,019 people viewed this question
Top Televison & Video Experts
